CrownVic
Members-
595 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by CrownVic
Nice color. Clean install
Here are a couple pics I'll get more later there in reverse order. Heres where I had to drill into the trunk. wires running under the car. The pic of the port is to show where the carpet got melted when I was painting it then it exploded . This is why everything is hard, its been about a week since the burn.
Thanks man. Im lookin for the camera now.
I did the chassis to battery ground of the big three tonight. What a pain that was, nothing would just work right. Now my voltage sits at 14.1 though. I also got my sub secured and wired up to a 1 ohm load. I still need to find a good ground spot for the amp and add a engine to chassis ground, but hopefully im off work tomorrow so I will have time, I wanna have everything done when the amp arrives so all I have to do is set it and plug it in. There will be videos when the amp arrives, hopefully my voltage will stay decent.
That guy cant possibly have a life. Hes like chlamydia for youtube.
Don't second guess your confession now by blaming it on a non-existant sibling.
I havent heard alot of Trae's stuff but what I hear I like. Most the songs Ive heard got good bass lines also. Im into more Memphis stuff since thats where I am but i like some houston stuff to. I usually hate that NY and West Coast shit. Its all about the South
Well i did some work today and got back on schedule. I ran the power wire under the car to the trunk, and also got new battery terminals and installed them. All I need now is to do the grounds for the big 3 and run the ground for the amp! Also the amp should be here Friday the 13th. So 2 more days Edit: Fixed my computer so i can post pics but lost my camera. Ill find my camera and post pics tomorrow. Also with the positive of the big 3 ran my voltage sits at 13.9 idle with air off.
If you follow my build log you'll see I'm gonna be running an aq 2200 to an 18 btl at 1 ohm. My car has a 135 amp alt but I'm pretty sure ill need some batts. I have room for 2 large batteries but I'm unsure of what kind. Would 2 of the everstart maxx batts from walmart work? Or do I have to use a deep cycle battery? Also do I have to replace my batt under the hood? Also do I have to match my batteries in the trunk with my main battery? Big 3 will be done all wire will be 1/0 also. Thanks if more info is needed please let me know.
asian hooker told me.
GOOD GROUND amplifier heating up
CrownVic replied to BASSnoob's topic in Amplifiers / Head Units / Processors / Electrical
Do your lights dim? Only way to know is to get a DMM and check your voltage. -
Running new wires for H/U
CrownVic replied to BanginGMC's topic in Amplifiers / Head Units / Processors / Electrical
I would think all you would need would be a constant 12volt, ground, and another 12volt thats only on when the key is. You could tap in to the fuse panel for the power wires then just run a new ground. Dont forget the antennae though. -
Well what are your goals no one can help you if we don't know what you want. I dont know much about the AA sub but i know the Q is more of a SQ sub so if getting loud is your main goal there are better choices.
That dome light trick is pucking epic!
Best way to learn how to install your own car audio
CrownVic replied to Smitty's topic in General Audio
The best way is to do it yourself with a knowledgable set of eyes to guide you. Or just read the instructions try it yourself. -
What is the fastest you have gone
CrownVic replied to bassahaulic's topic in Automotive and Performance
158mph in my dads 55 chevy clocked by my cousin (a cop) late at night on an empty highway. I wasn't driving though. -
need suggestion for amp
CrownVic replied to SiMmER's topic in Amplifiers / Head Units / Processors / Electrical
I suggest re wording your topic using proper grammar so we can understand what your asking. -
They build that van with all that audio equipment to play that gay ass song
batt question
CrownVic replied to CrownVic's topic in Amplifiers / Head Units / Processors / Electrical
Ok so battery relay not isolater. Im guessimg im going to need around a 200amp relay? Also what size fuse should I use for the power wires 250 amp? Edit: I just called literally 12 autoparts store with no luck they said as soon as they take em off the shelf there gone. -
batt question
I believe you that's just one of those things I never would have known if someone wouldn't have shared it. I'm definately gonna call and ask all the local part stores. Another thing I was wondering was if I get an isolator for playing music with the car off will the battery automatically recharge when the engine is running? Is an isolator really necessary or should I just wire the extra batts to the main batt and wire my amp to the batts in the trunk. I plan on purchasing 2 extra batteries to put in the trunk and keep the original main batt. Also space really isn't an issue because there are two large battery shaped spots on eitherside of the box. -
batt question
That sounds like a great deal. I gotta water the money tree for a little bit before i cant get one though. -
batt question
Where are you gettin optimas for $30? I found a stinger SP2150 on Clist the guy is asking $300 I think its 91 ah Is that even a good buy used for $300? -
batt question
Also do i need an Isolater? -
batt question
Thanks. So do I need a G31 type? What specific type of batt would be best or does it matter because if not ill just get 2 of those big ass everstart batteries from walmart for $80 each. -
Thanks man. Also I talked to a local AutoRadio store today and to my suprise they didn't know anyone with a TL . Also the manager/owner informed me that the AQ 2200d would only put out around 1kw at 1 ohm .
