ANT LAY
Members
    166
Everything posted by ANT LAY
  1. ANT LAY
    those either a tahor or Yukon
    I put tape over the inside and outside of the vent and I can definitely feel more pressure and air movement but its hard to say if it's "louder", so now I'll probably go ahead and block them off permanently edit *... btw no more fart noise
  2. I've heard of people blocking off the rear cabin vents ( behind the vent caps) to gain loudness in the cabin anyone here dine it or does anyone know if it works because with my system turned up if you walk to the back you can here a farting noise coming out and also you can feel the air coming out
  3. ANT LAY
    Yea I've took off the cover and checked it out, I'm thinking I'm gonna try it...
  4. ANT LAY
    My New Toy
    Agreed, it takes a lot of car to take a bike (even a stock one), especially in twisties. Given that the person riding knows how to ride lol. A lot of anything comes down to rider/driver skill. Makes me my r1 ... im actually thinking of getting another r1 for trackbike....nice bike man I've always liked that bike.....dunno if you know about it already but check out r6 forum...great forum as well as the r1 forum ..lots of good info and people on their...again nice bike
  5. ANT LAY
    Alpine + Onstar.
    Yea..that's a good price...and yea id bet that the os-3 may word but I wouldn't chance it..id go ahead and get the os-4 from your link
  6. ANT LAY
    Alpine + Onstar.
    I just checked the pac website and that is only for 07-08 silverado ...but it may work but according to their application chart the one a linked earlier is the one you need ..os-4... I think 07 08 09 10 are all the same truck. 06 was different and early 07 gm calls 'classic' That's exactly what i was thinking ..which I know they are but im just going by their word...like I said im just trying to look out for ya bro!
  7. ANT LAY
    Alpine + Onstar.
    Yea id agree...although mine hasn't arrived lol...he's just gotta firgure out the correct model
  8. ANT LAY
    Alpine + Onstar.
    Check their website man, id hate to see you make a $170 mistake if the os-3 don't work, im sure you could return it but that's just more "downtime" either way
  9. ANT LAY
    Alpine + Onstar.
  10. ANT LAY
    Alpine + Onstar.
    Lol...nice ... yea I got that...also op, im sure andrew through argent audio can hook u up, if not check around....I had to get one for bose and onstar and I got mine for 1#0... it's a pac....would of definitely ordered through andrew if I knew he carried them
  11. ANT LAY
    Alpine + Onstar.
    yes. thats the point!!! I think he asking because you can save some money and get the one that bypasses onstar
  12. ANT LAY
    Alpine + Onstar.
    According to op he uses it daily...but i would probably go ahead and spend the extra for the pac...seems that scosche is pretty similar for a good bit less money...I guess its cheaper for a reason from what reviews I read for mine...I just ordered a pac interface for my 05 yukon with onstar and bose ..and had to make the same decision ...sorry andrew if I would of known you were a dealer I would've hit you up
  13. ANT LAY
    Alpine + Onstar.
    cost even more then the PAC May wanna check my link from pac.... pac is $50 more
  14. ANT LAY
    Alpine + Onstar.
    http://www.scosche.com/products/productID/1520 The scosche version....
  15. ANT LAY
    Alpine + Onstar.
    http://www.pac-audio.com/productDetails.aspx?ProductId=384&CategoryID=26 I think that's the one.... according to the info
  16. ANT LAY
    Alpine + Onstar.
    Thanks Ant. ill check it out. No problem, what was the pac model you needed?
  17. ANT LAY
    Alpine + Onstar.
    Gotcha...check scosche website as well...there products look almost exactly the same as the pac, but a little cheaper....
  18. ANT LAY
    Alpine + Onstar.
    If you have the factory bose its more than that ...I went with the METRA interface.. but im pretty sure it was fd up so I just ordered the pac version ...haven't received it yet to give a report.....
  19. ANT LAY
    Problems with alternator whine after new h/u
    Its a 05 yukon and the only ting I've changed is the headunit, and it does have stronger preamps, I can't adjust the gain because its the factory bose amp and speakers but I did try grounding it straight to the battery and completely bypassing the factory ground with 16 ga wire and its still there, I even unhooked all of the big 3 and reground it to a (seemingly) better spot, and that did nothing, if there is anything im missing let me know and ill check it.
  20. I installed my kenwood kdc x794 in my 05 yukon with factory bose system so I had to use the metra gmos 04 adapter to keep chimes and factory amp untill I get money go upgrade all components, also I installed the metra aswc and now when the radio is on but turned all the way down I get some alternator whine out of only one speaker and I never had the whine before the gmos04.... I've took it apart twice and re wired and still can't get rid of it.......help please
  21. ANT LAY
    I thought it was only one until I started listening closer, im lost I've tore apart and re wired like 4 times and still have the same problem, I read somewhere else that it could be a sign of my alternator going out?... the guy that owned it before me had the same problem with double din kenwood, he just ignored it..but he had a different interface
  22. ANT LAY
    Well that's one thing I forgot to mention...its not just one speaker it's at least toi if not all of them...it seems to br varible which is the reason im thinking the interface
  23. ANT LAY
    Ok so I got home ran ground from battery and still had the whine....im beginning to think that its definitely the metra interface because it is also is causing my warning systems to go crazy when its hooked up...un hook it and turn key off and back and its all good....also when the chimes go off for door it crackles and pops...im lost! The only other change I've made to truck is big 3 so far and if it did whine then I don't remember it...any ideas besides get another interface?
