vladd
SSA Regular
    20,393
  • Days Won
    2
Everything posted by vladd
  1. vladd
    Best Install Options
    I don't know how much reupholstering costs around you but usually it's way more practical to get a set of seats from a junkyard. Not familiar with firebirds but I wouldn't think they'd be too limiting on seat choices (usually if height and width isn't a limiting factor just about any seat will fit with minor work).
  2. vladd
    The Random Funny Picture Thread
    Not sure if I'd consider these NSFW, but if you're at work you shouldn't be on a funny picture thread, get back to work!
  3. vladd
    "I fucked your best friend" is correct, why did he say *you're? If you're going to be a smartass at least be correct.
  4. If it's so basic I would love to hear the reason why you shouldn't use a smaller fuse if your circuit won't pull the amperage your wire is rated for. Everything I've ever read uses wire size for maximum fusing and I see no reason to put the maximum size fuse I can in my circuit. The smallest fuse you can use is always safer than the largest one you can use. By all means if this is not correct info, give me a source or even a good reason why. http://www.bdfuses.com/derating.php http://bluesea.com/viewresource/1441 http://www.antonine-education.co.uk/physics_gcse/Unit_2/Topic_8/topic_8.htm http://www.littelfuse.com/data/zh/Product_Selection_Guides/Fuseology.pdf that's the 4 that I found quickly while avoiding wiki's and forums.
  5. Just to clarify, it's not pointless, just provides no advantage over a 150A fuse, while a 150A fuse does provide advantages over a 300A fuse....allowing less unwanted current through the circuit. Yeah my wording was a little strong. I just meant that the 300 amp fuse is not REALLY doing its job as it may allow the amplifier to exceed its limits while staying fully intact, thus defeating the purpose of fusing at all. The 300A or main fuse won't help the amp from exceeding its limits, that's what the amp fuses are for. The fuse at the battery simply serves as a fuse closest to the source of the electricity in an attempt to eliminate the chance of a short circuit. The difference is that there is zero need for this fuse to be larger than the circuit it's on dictates.
  6. Just to clarify, it's not pointless, just provides no advantage over a 150A fuse, while a 150A fuse does provide advantages over a 300A fuse....allowing less unwanted current through the circuit.
  7. vladd
    Welcome to the IHoP
    What mids are you using? That's kinda low on the upper end for my taste(1250) but could definitely be appropriate depending on your speaker. Also keep in mind that the steepest slope is not always the best. You may find that a more shallow slope and lower/higher crossover point is much better (on the low or high end). Are you able to adjust your tweet crossover? For the upper end on your mids you may find it easier to get your initial point with no tweet at all, so you can tell when the mids break up easier, especially if you have a hearty tweet.
  8. By that logic are you saying the size of your wire has nothing to do with amp power? No, he's saying that the fuse is there to protect the wire from meltdown. It doesn't matter what amp is connected to the other side, the wire itself has a certain ampacity that if exceeded will become a fire hazard. This is what the fuse is there to protect against. So you fuse for the wire. The wire should be properly sized for the amp, and the fuse should be properly sized for the wire. The one caveat I'll add is in the instance where the amplifier does not have any onboard fusing you would want to select a fuse size that will protect both the wire and the amplifier, but you would want to go with the most conservative of the two. This is what I was pointing out. If A depends on B and B depends on C then A does depend on C. When I fuse I fuse the circuit, not the wire. If I know my circuit shouldn't pull more than 10A i'm going to fuse for that regardless of how big the wire is, so when the circuit pulls more than it should for any reason I'm aware (like a body screw that manages to penetrate the wire insulation or old insulation cracking and rain causing a short). Headroom may be good when choosing an amp but I don't like it with my fuses, that's room for trouble. Alternatively, I cannot think of a reason to fuse higher than the circuit dictates, if there is one I'm missing feel free to enlighten me.
  9. By that logic are you saying the size of your wire has nothing to do with amp power?
  10. P/V = I 3000W/10V = 300A 3000W/12V = 250A 3000W/14V = 214A
  11. vladd
    Welcome to the IHoP
    In my intro class's lab we made wine as well. Man that shit was nasty.
  12. vladd
    Welcome to the IHoP
    andddd to put this where I meant to put it! sushi again tonight. Had a california roll with fuck if i remember(at least tuna, avacado, crab) but it was ok. Maki roll with cooked shrimp that was very good. And a fried roll w/tune and it was fucking awful, I tried one, spit it out, and fed one to the dog. the wasabi was still strong as shit, i actually kind of like it this way
  13. vladd
    Can i mount a yellow top on its side?
    lmfao having two windows open bites me in the ass again! that post can be found in the hop soon! yellowfin = yellow top?
  14. sushi again tonight. Had a california roll with fuck if i remember(at least tuna, avacado, crab) but it was ok. Maki roll with cooked shrimp that was very good. And a fried roll w/tune and it was fucking awful, I tried one, spit it out, and fed one to the dog. the wasabi was still strong as shit, i actually kind of like it this way.
  15. vladd
    Welcome to the IHoP
    everyone pray for rain for me! (if it rains I don't have to work but still get paid). The radar says the chance is good.
  16. vladd
    Welcome to the IHoP
    that's why they're called kick pods!
  17. vladd
    Welcome to the IHoP
    I would send him back your bottom dollar and explain why it's infinitely better than anything he'll get for $50.
  18. vladd
    Welcome to the IHoP
    that made me lol
  19. vladd
    Welcome to the IHoP
    Now it's hidden! repetitive and catchy! Sorry to the people that have forgotten about it.
  20. vladd
    Welcome to the IHoP
    and just deleted them, there has to be a line, i'll be happy to draw it for them.
  21. vladd
    Welcome to the IHoP
    i went ahead and accepted them but put them in a group, i'm still debating deleting them.
  22. vladd
    Welcome to the IHoP
    so my sister, mother, and brother (in that order) have requested me as a friend on facebook and I've declined all three. Since when was facebook a place for family? that would be almost as bad as them checking me out on SSA!
  23. vladd
    Welcome to the IHoP
    gracias R2
  24. vladd
    Welcome to the IHoP
    any bird people here? This hawk just landed outside the window and I managed to snap a few pics before he took back off. Anyone identify him? BTW i'm in Punta Gorda, FL
  25. vladd
    Welcome to the IHoP
    extremely straightforward, of course there's 30million different ways to go about it. For large flat surfaces like valve covers I usually prefer steel wool. For complex wheels (like honeycombs) i prefer to paint the bitches because you'll spend at least a day per wheel.
