Shogen
SSA Regular
    6,733
  • Days Won
    21
Everything posted by Shogen
  1. Shogen
    small inside flex video
    question.... why is your HD video recorded through a door frame??? Did you crop it like that???
  2. Shogen
    Incriminator Audio 187 Review
    nice thats how we like it... more information and more POWER!!
  3. that's sick... your rims look nasty dude... They almost look like the car is sitting on the rubber...
  4. Shogen
    crazy vibrations on that side mirror... lol ..nice... what is the actually name of that song??
  5. Shogen
    Nice to read but not really what you could call a review... What are you using to power it? Sealed or ported? Makes a difference in power handling... I was honestly close to getting a 15" before I ended up with my Icon... But I kinda wish I knew what I was getting into before I bought it, now I need to upgrade electrical and front stage to match the sub stage since it can be overpowering at times... Do you find this true to your experience with the 187?
  6. Shogen
    Random YouTubes
    It's only 3 pages but no it wasn't posted... lols
  7. Shogen
    Hey yall
    welcome sir!
  8. It looks as if your alternator isn't charging your batteries well.... 12.4v is very low...
  9. But why would it matter if the charger does it separately??? Will the charger put the batteries above his stated resting voltages? And then putting it in the car will maintain it???? I'm just confused about it...
  10. Thanks for the link... If it is accurate then its pretty good....
  11. Shogen
    Amp for 2 xcons
    ported is tuned to a certain frequency, so the enclosure would sound better at THAT frequency from what I understand.. So if tuned to 32Hz it would most likely sound better in the frequencies around the port tuning... Beyond a certain range it probably doesn't do as well... But don't quote me on that, I am no expert... That is just my guess on the subject...
  12. Shogen
    Amp for 2 xcons
    Why can't a ported enclosure be used in an "SQ" setup? well it sounded like he wanted strictly SQ. and to me, sealed is definately cleaner sounding. but as the OP said, he will be doing ported. subjective but I'm with you...lol
  13. Shogen
    Can someone from DC Power Contact ME!!!!
    Although this whole situation is "shitty" ... I think they should just give the OP money back.... It's now gone past the I'll just hang a bit stage... And whenever that product is ready, there will always be that bad taste in his mouth about the situation and he will probably not be happy either way. I understand it's not some small project to just back out of, but I think the OP should work with DC Power and ask for refund and stop asking for status of his order. This is just putting a toll on each party and the end result won't every be that satisfying. At least with a refund of his money he can go to someone else or do something else with that money... Can someone from DC Power make that happen? Refund this man's money and call it quits for this situation. It seems like there will never be a solid answer since the work is not all apparently being handled by DC Power....
  14. The fuse is there so that the wire carrying the current does not heat up and melt/cause a fire... So going higher would allow a higher current without going into protect, but if you're using a 180a alternator then I don't think it would make a difference so I would keep it how you have it..
  15. Shogen
    Hooking up two battery's
    Amp grounds directly to rear battery.
  16. Shogen
    Amp for 2 xcons
    Im. Being told everyday that I .need to port .my Icon. Still not made a decision yet.
  17. Shogen
    15 OR 18
    pretty much look at twistedchild's setups on here... he always has something huge in his Sante Fe, almost always one subwoofer and seems like 18" is common for him..
  18. Shogen
    15 OR 18
    different subwoofers different enclosures... Although it is odd on paper to see the BTL require less as optimal... Wateva... Fi says so... lol
  19. Shogen
    15 OR 18
    near the end... https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154d2937214bae4/shopdata/0070_Tech/0070_Speakers/0040_Tech.SSD/product_overview.shopscript
  20. Shogen
    15 OR 18
    that's most likely calculated with floor to roof height... So obviously not what you're looking for... And that might even be with seats down... Not sure I'd go by that.. Do the measurements I stated... Will give you the size at largest for an enclosure... I wish I had gotten a SUV at times just for simple fact of easier box planning... My Toyota Camry trunk isn't very easy for planning/staging...
  21. Shogen
    Random YouTubes
  22. Shogen
    15 OR 18
    uh-oh... bad questions... I cannot explain "how tuning works" ... But basically higher frequency during competition is done to hit higher numbers usually, going lower is to more the a music thing... Measure the width of the opening of your hatch, the depth from the hatch to the seat and the maximum height you want the box... do all this in inches... Then multiply those numbers.... You now have cubic inches.... Then plug that number into the blank field on this page... http://www.metric-conversions.org/volume/cubic-inches-to-cubic-feet.htm
  23. Shogen
    15 OR 18
    I'd say stick to 15 but, you need like 5-7 cubes for an 18' SSD in a sealed application... depends on type of enclosure as well... Ported I think it goes 8-10 cubes man... That's not small...
  24. Shogen
    15 OR 18
    you dedicated the whole trunk area for bass?
  25. Shogen
    Fi N2 BTL Video
    crazy nice man!!!
