///M5
SSA Tech Team
    73,916
  • Days Won
    449
Everything posted by ///M5
  1. ///M5
    wall help
    Good & Wide is less than an octave??? Do you really have ANY idea what you want or are you just citing terms and numbers?
  2. ///M5
    wall help
    That is irrelevant.
  3. ///M5
    wall help
    Your comment is correct about a standard 4th order ported enclosure, but NOT about a 4th order band pass. Wherever you are reading is confusing you....A TON. Perhaps if you took a second to think about what the term band pass means it would become more clear. If that is your logic for attempting to build one it is going to be a monstrous fail compared to just building a "normal" box. Doing something to be different (or the same) as others is a terrible reason to do anything btw. And please, stop referring to ANY enclosure as a "4th order" as that is far from describing any one box type. Shows a complete lack of understanding of rudimentary audio. (ought to tell you something about where you read others calling BP enclosures "4th orders")
  4. ///M5
    Welcome to the IHoP v.2
    I am going to pull a few pounds and share with some buddies Whats up with the green chili? I don't have any of those,but I do have a few gallon freezer bags of Banana peppers and Jalapeno's from the garden last year.those won't help, need some hatch chile
  5. ///M5
    Never is Enough, What Next?
    You need front stage bad. For bass the box is the first step
  6. ///M5
    Is on the Mustang. I don't have the tool, was going to do the second video's route.Only other route is change the rims which I don't really want to do. I dont see why not. The only issue would be the quality of the metal that you are trying to roll out and maybe getting the paint too hot Worked fine with the baseball bat. I didn't have to worry about paint. Awesome and
  7. ///M5
    Mid bass driver for 80-800
    Perhaps I could say this differently. You have nothing of value for building into anything else at the moment.
  8. ///M5
    It would be WAY cheaper to buy something used than fix what you have. Also 1000% impossible with the current crossover you have.
  9. What is a radio? More seriously this is expected. Radio stations cater to idiots and therefore already ruin music before the put it on the air. Exactly why I started my post as I did.
  10. ///M5
    My first delivery DAMN are these things spendy. $100+ each. Of course they will support 1000hp
  11. ///M5
    J - had no idea Hobart WNY was in the fam. A wee bit more industrial than my needs which account to doing something once/month max...but my interest is piqued. I am going to rethink my needs a bit and come up with some questions Thank you!
  12. ///M5
    Me too. Lots of it
  13. ///M5
    E46 is the one generation I skipped so I can only guess... Yes to the big no on the SMG. This is fact. Maintenance records and the desire to keep things clean. I love buying from people and not dealerships. I want to see their garage and house. If it isn't in order, I would expect them to have neglected the car. Neglected and German is bad. VANOS is a Seth question. Been on the bimmerboard asking? Timing chain. I've NEVER heard of a BM'er timing chain concern. Belts yes, greatest reason to not buy a pre-92 2.5L
  14. ///M5
    That is some tail
  15. ///M5
    So is funky cheese, yogurt, herbs, and cucumber on rice. Glad you finally get it.
  16. ///M5
    $300 would be WAY better spent buying something used. WAY, WAY. If you do this you HAVE to learn.
  17. I have no headunit, no need for a $50 harness but after having no chimes for the first time today I realized this means no blinker noise or low gas warning. I'd like to restore that, but it would be the ONLY output I'd need from the harness making me not want to buy one. Of course, if the signal is only over the CAN bus and has no analog counterpart it'll cost me something, but was curious if anyone has rednecked a good solution? And yes, I'll still have a stereo in the Escalade (2010) but it'll be a carputer and no headunit.
  18. ///M5
    And btw, it is REALLY, REALLY obvious you didn't model those Selenium's before you picked them.
  19. ///M5
    Yikes, no. You already bought crossovers?? If so, you are going to have a hell of a time determining actual cross over points on particular drivers and get anywhere near close. Need to know exact specs of everything and even then it is going to be a major compromise. That would be like grabbing a 1.5ohm 60Hz 12dB filter and using it on a 3ohm sub. If you can't calculate what that means you better learn darn quick.
  20. ///M5
    when it comes to food
  21. ///M5
    I hate America
  22. ///M5
    French dressing is also a ketchup base dressing
  23. Maybe others have had better luck. First one just pooped, second one caused all sorts of shit to fly off on the CAN bus on my truck. All sorts of lights.
  24. That scan tool sucks. I've had two die. Work fine for checking but if you leave them plugged in all the time they last a few months.
  25. ///M5
    By just I don't mean exclusive, but that is the base.
