73,916 -
Days Won
449
Content Type
Profiles
Forums
Gallery
Everything posted by ///M5
You said you cool by electricity..Water or refrigerant is the only way..lol besides a fan of course if you want to concider that. Cooling by electricity is the dumbest thing I have heard..You are just trying to get me gassed up.How is the water pumped? How is the refrigerant state changed? How is the heat removed? How is the air turned?All done by electric motors, hence his comment. Electricity, the one common denominator. Why yes they do..Both heating and cooling systems both do..That is not what he meant,electricity does not cool atleast I have never known it to absorb the warm air.Yep, you're right. He's so stupid that he literally meant eelectricity cools. What's even more amazing is your supreme intelligence could conclude that while the rest of us could not. You are one smart cookie! Says the guy that thinks electricity has two E's...lmao Edited by Sean. Fuel removal...
You are right about one thing, you assume that you know what assume means but you don't.I assume you like to google so you can try to make it seem you know what you are talking about champ. Unlike you, I don't have time for that shit.
I know you like it but you got azz raped! Find me a fully digital and programmable multi-zone thermostat system that can be open source controlled by a computer for less. Hell you can't even get shitty analog ones for that, lol
You said you cool by electricity..Water or refrigerant is the only way..lol besides a fan of course if you want to concider that. Cooling by electricity is the dumbest thing I have heard..You are just trying to get me gassed up. Only because you can't read. Discussing the expense of power sources. How you extrapolate that any other way is sheer stupidity.
Needing a new Box design for my Loaded 12" Q
///M5 replied to 99gpgtx's topic in SPL & SQ / Fabrication
Nothing works out on SMD. Misinformation headquarters of the car audio world. Should start with laying out exactly what you have. Should make sure that is the problem before building another box. "sounds like 42Hz" isn't really a good mechanism for making that decision. -
I think I paid $20/thermostat for the three zones in my house and another $25 for the controller.
They work with the switches 100% of the time. The computer 99.9% but sometimes there is a delay as it has to poll and realize the command failed.
My lights are pseudo dual. ie, the respond only to one direction but are rapidly polled to check state. This is somewhat of a bastarded option in between the above. They are wired, single direction, but fast enough to always know state. Even then, not 100% reliable
You had your chance to show you knew something about HVAC when MK asked. Add to that the amusement of the "electricity" question, rofl. Mike, btw I run RCS thermostats in my house. RS232/485 protocol to my pc which then allows a wifi connection via my home automation. Hardwired and programmable, but over rideable anytime via wireless. Wired control for automation so I know it'll work. As with any home automation protocol: One direction wireless < one direction wired < dual direction wireless < dual direction wired If whatever you have doesn't confirm the command at some point it won't get said command.
coldest month here is usually $500 and the hottest rarely breaks $350. We have super shitty 1974 Windows in a 5500sq ft house though. Your previous post seems to suggest the opposite.I meant to compare the coldest that hits $300+ to the hottest which hit low $200's but I got distracted when I posted. Also, that is big house but that is a ton of windows. Your house must be 99% glass. that is what happens when I flip things. Doh. Last summer was brutal
How do you cool with electricity?Wow are you quick
Of course we also heat with Natural Gas and cool with electricity
Like when it is -numbers here? It's cheaper to cool the house then to heat it when it's cold out. I remember when it was cheaper to heat then to run the a/c. ROFL. Umm, not here...
Two times even
I have no idea if there's any relation, but kinda weird as well: I'm left handed, my left arm is slightly bigger than my right, but my right leg is bigger than my left. I'm left handed, but my right is stronger than my left and my right leg is actually shorter and not nearly as strong as my left. Probably from sexual preferences,my left arm is stronger but my right arm is way bigger..I have no idea about the legs my right is bigger 29" thigh as I think that is from carrying my abnormal over sized right testicle all my life. Big testicle and a 1" cock. That has to suck.
those are copies of the ergotron, lol
versus the more expensive and often copied Ergotron
I like the technical marketing as well
They are about $50 more than the next best thing, but those looks like they will last forever versus being disposable.
Two singles or one dual monitor arm? http://www.colebrookbossonsaunders.com/products/monitor-arm-stand/flo-plus/ http://store.hermanmiller.com/store/servlet/dynamicKit__10151_-1_10051_5821?adpos=1o1&creative=40756415617&device=c&matchtype=&network=g&gclid=CjwKEAjwmZWvBRCCqrDK_8atgBUSJACnib3l3HLTsYF8kucpj9lALzrBu5ZGLx5ROqs9nBf4kEvW4BoC0Mfw_wcB The main reason for the two together is so that I can adjust them together anytime I want and quickly. Since I'll sit some and stand some it frees this up to be faster. The main disadvantage is that you can't move them separate....something I have never done.
Mikey - tranny trick for ya.
Can you hardwire? Wireless and home automation is a no-no.
