///M5
SSA Tech Team
    73,916
  • Days Won
    449
Everything posted by ///M5
  1. ///M5
    Welcome to the IHoP
    Helloooooooo?
  2. ///M5
    Welcome to the IHoP
    Helloooooooo?
  3. ///M5
    Welcome to the IHoP
    Helloooooooo?
  4. ///M5
    Welcome to the IHoP
    Helloooooooo?
  5. ///M5
    Welcome to the IHoP
    Helloooooooo?
  6. ///M5
    Welcome to the IHoP
    Helloooooooo?
  7. ///M5
    Welcome to the IHoP
    Helloooooooo?
  8. ///M5
    Welcome to the IHoP
    Since no one is here, SKIP TO: 5468
  9. ///M5
    rlp spl meter
    It will measure them, but the response will roll off just like if you try to play high notes out of a sub. If it is a Class II meter (which unless you spend upwards of $1500 it is at best) it will not at all measure accurately down at the 50hz region. It might be repeatable but that has nothing to do with accuracy if the transducer is rolling off so fast.
  10. ///M5
    Wheres mike?
    Hope your on vacation, you deserve one.
  11. ///M5
    Eclipse SW-8200
    marketing, ugh.
  12. ///M5
    free stuff links
    Not sure I want to be on Astroglides mailing list....
  13. ///M5
    free stuff links
    What does the toothpaste have to do with the sex accessories??
  14. ///M5
    Discolored cone on Rl-p
    Or just put it in a bandpass.
  15. ///M5
    2x RL-P15 D4 in 2001 F150
    Either that or if you have room you can bolt on an extension to the port to tune it lower with some T-nuts.
  16. ///M5
    looking for a lightweight sub
    This will help a lot!!
  17. ///M5
    1971 impala build
    Comeon, what about the added deebeez??
  18. ///M5
    Eclipse 8v?
    *sneakily looks around for used deck*
  19. ///M5
    everything is fixed dont worry.
    Nice work young grasshopper. CB, I assume you are satisfied now? In which case, I would say the customer service is spot on. Yes, there was a miscommunication at the factory with the CS rep who didn't know Jeremy but considering the situation I think that is pretty normal. I have seen much larger and smaller companies have similar issues, it is actually quite normal but in this case we have you to thank for making sure that it doesn't happen again.
  20. ///M5
    1996 Impala SS build
    That is going to be sweet! You will have to post finished pics. As for the triangles, they aren't as easy as slot ports but depending on how you run them in the enclosure are really awesome bracing, plus it looks as if you have enough surface area which is why there is no huffing noises! Great job so far.
  21. ///M5
    Invitation
    I'm with Ryan....
  22. ///M5
    Welcome to the IHoP
    TOP
  23. ///M5
    Welcome to the IHoP
    Your night is 2-3 hours after some of ours.
  24. ///M5
    Welcome to the IHoP
    Mine is the size of a desktop pc, actually just a scope that I bought from Toro when they went digital and cleared out old equipment. $5 wooot!
