///M5
SSA Tech Team
    73,916
  • Days Won
    449
Everything posted by ///M5
  1. ///M5
    Billy Jack Thread Dumping Thread
    I didn't change anything. Read the quotes above in my quote. You can't be that reading challenged. I can summarize if it helps: BJ "I set the time alignment for 2 seats at once" M5 "You cannot set time alignment for 2 seats" BJ "You can and I did" Nigel "You were not setting it for 2 seats, you set it for the center" BJ "Yes sir, what I said all along" You are arguing with yourself and it seems only because I replied. The problem is your first statement can lead a poster to believe something is possible when it isn't. Then you try to soften your statement by arguing and changing the direction of the thread. This is thread dumping. You are so eager to argue with whatever I type that you rarely make sense. This needs to stop and now. Argue with me all you like that isn't the problem, but keeping it on topic so that you don't ruin every thread you post in is required.
  2. ///M5
    Ideas for my System
    Where are you mounting drivers? Curious why you are so deadset on a 3 way as well. You would have an awful lot of audio gains if you went 2 way active first.
  3. ///M5
    Tweeter suggestions
    Back on topic: Where are the mids going? That I understand...but not their implementation. The vehicle screams for an on axis setup for most of the audio range (exact reason you currently have the sound bar), but FCA's installation of it was horseshit. Just peak at the off axis response of any ~3" midrange and you will see why. Completely confusing how they could get part of the equation so right and part of it so wrong. Other problem is that in that truck it is hard to treat the doors well enough for an 8" midbass which takes away fro the whole full ranger options.
  4. ///M5
    Again you thread dump. STOP. Read your first post above. To the OP this sounds like you are recommending time alignment that is "good enough" ie, great, for two people at the same time. I clarify and you get your panties in a bundle and have to argue. Read your argument, then read how you try to completely change your tune two posts later by saying you did NOT time alignment for both but something completely different ie some random spot in between the two. Even worse when that random spot between the two is shit for both. In a car you can't eq for one side evenly, implying you time aligning it is learning challenged beyond belief. EVERY time you post in a thread you are all over the board implying different things and the people who made these threads don't always realize your audio understanding is beyond confused. They may take your implied reality of what you hope your car is as fact. I am done warning you. React like a little bitch again when you imply some nonsense and someone corrects you and you will no longer be a part of this forum. You have had way more warnings than other people we've let go. We have let this happen because you do it out of ignorance instead of intent. The initial statement isn't the problem, but your incapability of opening your mind to criticism and how you respond after. Three different mods have addressed this privately with you. Now here it is publicly. SS - sorry this is in your thread. We can surely move the off topic to the dumping thread, but being part of it is almost on topic we can move it later or at your request.
  5. ///M5
    Port too long?
    Don't tune so low. Past the range of diminishing returns.
  6. ///M5
    Ideas for my System
    Doing a 3 way active as your first step isn't something I would recommend. 6.5" midbass won't be much of a midbass. If you are in the mode of a 3 way...I'd try like hell to fit something bigger. As for the rears, those locations are useless. Don't use them.
  7. ///M5
    Port too long?
    Que? Small box, low tuning = long port. The rest of your question is really hard to read...
  8. ///M5
    Ideas for my System
    Thanks for the nice write up, that helps a ton. One thing to clarify. Midbass drivers are part of the front stage. Of course this also means it makes basically zero sense to use a 6.5" midrange when you have a midbass driver. Something MUCH smaller will GREATLY improve how things sound. A few questions to get us going: 1) Have you had an active setup before 2) How big of a driver can you fit for a midbass 3) Where are the speaker mounting locations 4) What is the plan for the 3 way crossover. The 6XS really cannot be used for this...
  9. ///M5
    Tweeter suggestions
    Perfect. Then when you get those nailed as good as they get, complain about what you don't like and we can either help you select temporary replacements or fix the tune further
  10. ///M5
    Tweeter suggestions
    Yes. You CANNOT time align for two seats at the same time. Not even close. Rudimentary Physics...
  11. ///M5
    Tweeter suggestions
    Beware of one thing. On axis and tweeter is usually not desired. Location can stay, but I'd play with aiming. As we clarified before, that doesn't work. Not even close. I am sure your "driver" and "passenger" settings were better for the other person than if you didn't change them, but it was far from optimized and your "close enough" is miles away for most of us.
  12. ///M5
    Pioneer 8100NEX - Excellent condition
    No subscription needed. Can buy updates though
  13. ///M5
    Tweeter suggestions
    You will be surprised how much active filters can help any driver. If the jbl's are in just try them first.
  14. ///M5
    Tweeter suggestions
    Personally I would start with what you have and then see if you need to change.
  15. ///M5
    Welcome to the IHoP v.2
    Need one big sock
  16. ///M5
    Not really, both turned into marketing terms. I researched like hell and was willing to spend, but instead just bought Penny's high end whatever the hell and they destroyed the other super high count or Egyptian spendy ones I have. Mileage will vary, but expect all specs to be nonsense
  17. ///M5
    Fplanning the outdoor remodel in my head after the better part of a 12pk
  18. ///M5
    I feel like I am feeding an old hay burning steam traction engine Ha ha. Spell check changed hay into gay
  19. ///M5
    Sweet. I am outside heating the earth and burning 15 years worth of bills and receipts.
  20. ///M5
    10" drop chest to waist here. Shoulders 1.5" bigger than my chest. I just want a pimpin sport coat to wear with jeans
  21. ///M5
    That is really reasonable. So you have a salesman you like.
  22. ///M5
    It was awful. I was looking for Jean shoes though so the styles I wanted stopped at 13
  23. ///M5
    They were serious dipshits. Of course I went to the Edina store. From the experience, no way I would do business with them. Even worse they flat out told me they couldn't.
  24. ///M5
    An LS with a TVS on it.
  25. ///M5
    SSA 1969 Firebird
    Small world. Helped my buddy build a protouring 69 Bird a few years back. Was FUN!
