chris89127
Members
    41
Everything posted by chris89127
  1. chris89127
    Sundown SA-8 Pre-Sale
    just wanted to say my sa-8 been working great. i got a new 4" port sounds so much better then the 3" aero i got mine on 600-700 watts at 2 ohm this sub will take some extra watts with no problems. this sub is great its my first small system great SQ with these all the notes are very clean and loud. nice job jacob on the sa-8s
  2. chris89127
    my one SA-8 sounds good. ended up throwing it in the normal way not inverted. It can handle some watts i got 600-650 watts going to it. My 3in areo is too small, gets alot of port noise. prob end up making a new slot port box for two or three. Jacob how much are they now after the presale?
  3. chris89127
    its not off much but enough to notice. ill have it in a box to day i will share the results when i get done.
  4. chris89127
    got mine today looks good But the dust cap is off center. doesn't bother me its going to be inverted .
  5. chris89127
    How many left to ship out? still waiting on mine
  6. chris89127
    I got my box ready to go lol just need the 8. its .85 cuft with a 3 in aero tuned to 34. the amp is a cadence daytona DCA 1000.1
  7. chris89127
    Got my order in How would these sound inverted ? i think im going to invert it my box is going to be .85 cuft 3" aero port tuned to 34
  8. I will be getting a sundown Sa-8 here when they ship out. I need a amp i was looking at the Rockford prime r500 ,but i dont know if its going to hit them low lows. the box will be 1.2 cuft tuned to 35hz aero port. DOES ANYONE know of a good amp for it UNDER 175 dollars?
  9. chris89127
    Sounds good thanks for the post!!
  10. chris89127
    could you give a description like coil size,spider/tinsel configuration? the videos already got be bought lol i will have my order in after taxes get back to be
  11. chris89127
    when does the presale end ?
  12. chris89127
    foam surround ?
    I have a SS xxx 15 with a psi recone. the surround ripped does any one know where i can just get the surrounds ?
  13. chris89127
    foam surround ?
    It ripped half way around
  14. chris89127
    my btl broke
    it was making a popping sound a few days ago. then yesterday it happened the coil broke from the cone. im going to try in glue it back witch glue should i use ?
  15. chris89127
    my btl broke
    It is a 15 FL newer one. i got it used from a guy that had 4 of them in a wall i think he had 4 40001 bd's to them daily driver. the subsonic was a bit off but not that bad to do that much damage.
  16. chris89127
    my btl broke
    I build my own boxes its 34"x17"x24". the port is a L ported width is 4.25" long 15.75" L piece is 6"
  17. chris89127
    my btl broke
    subsonic was set a lil bit above half. i figure its some where between 35-40 Hz .
  18. chris89127
    my btl broke
    my box is 4.5 cu ft tuned to 33hz 2x saz1500 at 2 ohm. my subsonic was set about half i think. set gains with dmm so i don't think clipped it to death.
  19. i was looking for some good batts to match up with a audiopipe 3000 and a 200 amp alt. i was checkin out the kinetiks on ebay they seem to be good for the price. im not to sure about some other brands out there really just kinetik and xs power is all i know of . i am on a budget as i only make min wage. 200-280 is all i want to spend on batteries
  20. chris89127
    H/O Alt or Not?
    Get the HO alt it will do alot better charging those batts you are going to get.
  21. chris89127
    Not Happy
    my 1200 just broke too after a few weeks of playing. prob going have to send it in to db-r
  22. any know the SQ on the audiopipe 3000 i was thinking about getting one but dont know how good they sound ??
  23. chris89127
    rf t40001bd amp
    maybe something came loose and got grounded
  24. chris89127
    lighting bolt in side my amp loud snap pop sound
    I will send it tomorrow
  25. my amps protection light blinks on then goes off then when i turn the song it happens the arc of high amp electric its random it just starting doing it i had it installed for a few weeks sae1200 extra batt stock alt
