thebiggmann12
SSA Regular
    1,026
  • Days Won
    1
Everything posted by thebiggmann12
  1. thebiggmann12
    Best battery for under the hood?
    check out the sticky in the xs power section.
  2. thebiggmann12
    Getting Metered @ Show
    nice score...but my question is, what were other peoples scores with what equipment?
  3. thebiggmann12
    What to do to make a box look like this...
    kerfed cuts...google it, or check out the box builders section on here.
  4. thebiggmann12
    Amp for 2 Fi BL12's?
    if its in the right enclosure they will get loud and sound good. not great bc they aren't made to sound great, but they will sound good. i had a bl 10 and it got loud as hell for a 10 and sounded decent while doing it.
  5. thebiggmann12
    biggest one u can fit. better to have 2 much then not enuf
  6. thebiggmann12
    saz2000 or aq2200 if ur looking at audioque. do u have the electrical system to back this up?
  7. thebiggmann12
    both are fairly overkill. the subs are rated at 1k each for a reason. also, are you going to be able to supply these amps with the electrical system necessary? 1 battery in the back is not going to be enough.
  8. thebiggmann12
    FS>monster equipment
    i thought u had to have like 50 posts before you can sell something.
  9. thebiggmann12
    2 12's ,1 15's or 1 18's
    start buy telling us the car its going in and what his goals are...loudest possible isnt a very good description. also, rusty (i think thats his name) has said that the lvl 4 xl's are louder up until 2500 rms if i believe.
  10. thebiggmann12
    run your car on water????
    there used to be a youtube clip of a news channel doing an interview with a guy who ran his taurus wagon off of water and gas. something about burning the vapors of the water
  11. thebiggmann12
    my xcon died :(
    you do know this sub is not made to get stupid loud right? it is more along the lines of a sound quality sub that can pack some output if u do it right.
  12. thebiggmann12
    flat response for warden 12
    i think it has alot to do with ur vehicle...not just the box.
  13. check for belt slipping, or ur alt and or batt might b bad.
  14. thebiggmann12
    good tunning 8" 500rms
    it really all depends on what sub your going to run.
  15. thebiggmann12
    12" q fully loaded or 12" bl
    all of em, make sure u get daily and not spl and dual 2 vc's
  16. thebiggmann12
    Slowed down
    get on s. m. d. and check out the tunes...and get all of decaf's zips...he has some badass slowed music, and he tests it on audacity to make sure it doesn't clip.
  17. thebiggmann12
    ICON Prototype 12" Temp build
    whoops, my bad...the rings around the first baffle make it look like there is another baffle, but taking a closer look, it is a double baffle with one being the flush mount.
  18. thebiggmann12
    its a double baffle, with a 3rd flush mount baffle.
  19. thebiggmann12
    SAZ-2500D Pre-Sale OPEN
    1690 Watts 21.4 Amps 78.97 Volts 3.69 ohms Actual with box rise to 3.69 ohms 1690 sounds about right. 3360 Watts 63 Amps 53 Volts 0.85 ohm actual this is wired to .25 ohms, and hit .85 actual.
  20. thebiggmann12
    BOX IMPEDANCE RISE?
    make sure u have the electrical to back that up...even tho u might not be seeing right at .5 ohms, you will still be drawing a shit load more current than if u were running at 1 or 2 ohms.
  21. thebiggmann12
    BOX IMPEDANCE RISE?
    never count on box rise when wiring subwoofers for a daily system.
  22. thebiggmann12
    What to do for 15" Fi BL
    correct.
  23. thebiggmann12
    the q is a sound quality driver, not necessarily to get loud, the q is also rated at 1000 watts, where as the bl is also rated at 1000 watts and is designed to get loud.
  24. probably not...might wanna add another batt in the back but try it and keep ur eyes on the voltage gauge.
