Lucky 76
SSA Regular-
1,212 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by Lucky 76
Questions about SAZ-1500d & Electrical
Lucky 76 replied to phresh's topic in Amplifiers / Head Units / Processors / Electrical
btw tirefryr i must say that whenever i see your icon i must stop and gaze for a good minute lol -
i was talking to dom about isos and he said for every 1 good reason to get one there is 10 bad ones ... why did he say this and what are the disadvantages -
ya i left that alone ... id figure u would chime in about some isos lol -
Ford didn't make a 135 amp alt, it's actually 130 amp, but make sure you have the correct alt, as in '04 they used the small case 3G (115amp), and the 4G(130 amp), so you may not have the necessary current you need. The 4G will actually put out about 150 so if you do have that, you should be okay on your electrical side. My Taurus handled my BPX2200 no problem, along with 3 other amps, so you should be okay. I do suggest upping to the 200 just for safety's sake. The 200 amp Ford offerings are solid as a rock if you buy them from a reputable vendor. You can actually get an OEM Ford 200amp alt if you look hard enough. Quality Power Auto, is not well known by many, but they are very well known in the rebuilding world. High class products from a great company. Don't hesitate to use them! . . . . And you do not NEED a dual alt setup. While this is ideal, in all instances, it is not a necessity. Be leery of what people post on the internet, as the wealth of misinformation is greater that that of information. x2 - i think the 130 amp usually comes on the v8 model or with the towing package i forget ... i know my aviator had a 130 and it did work ... charged that bitch at 14.6 and didnt drop below 12.8 AT ALL ... this was with a bxi2006d and jbl 1004 along with other accessories on -
Sorry about the excessive comments but thats where im stuck at. If i might have to get a bigger alternator then why not spend the money that i would be buying a battery with on a alternator? well you are asking if i am going to need a bigger alt in the long run why not just got a bigger alt! well how about lets look at this mathematically for a 2000rms setup at 1ohm your amp will need like 45amps. but 2000rms/12.8volts = 156amp draw! so if your alt puts out 150 you will be able to supply the demand. is that correct or did i screw something up? i will just get a big enough battery to support my system. right now my setup is 1 15inch ns 2- batcap 2000's and STOCK battery and STOCK alt (105) and a SAZ2000 pushing all it is worth. my lowest voltage i have read off of my stinger volt meter is 12.8volts at full tilt after playing a full song. I have 2 Deka Intimidators with a stock 90amp alt and stock battery...with an SAZ3000D and 100.4 and I never go below 12.8 on a tone. Whats the website where I can look up the specs of the Dekas? I think im going to go with a Kinetik 2000 or 2400 if I get it at a good price in addition to my yellow top u should get a single powermaster. it will cost u a lot less than a kinetik. i dont know about the dekas and how good they are as i have no experience with them. people rave about them tho as they are not that expensive and do work. i would also be interested to see the data sheets -
THANKS! That was the type of answer i was looking for! Getting the battery! make sure to up the big 3 -
Not sure who told you they don't like over 3v... but the limit is 6v. There are issues with fancy RCA cable connectors, though, many times they don't make good contact. Cheaper cables don't have this problem. do u consider the knukonceptz krystal cables fancy? ... i just bought them and i am buying some sundown amps I have seen those work for people... anything with high tech looking ends on the cable has the potential to be an issue, but not always. wish i knew the krystal kables could be a problem before i bought them.. as well as my KLM POWER AND GROUND WIRE for my 2000d. they say it handles up to 250a. 2000d require a 200a fuse right? so will i be ok with the KLM or not? just get 1/0 and ur all set
because the alternator is never going to be able to support u when u r sitting still ... u r going to have to rev ur engine at a light and while coasting down a hill ... its a pain in the ass believe me ... i have a h/o alt and a single battery for the time being ... its terrible and will cause more strain on ur alternator -
also for what you have there is no reason to get a different one ... a 135 amp is plenty big -
So you would recommend a battery & battery isolator over just a new alternator? Why would I need a extra battery anyways. I thought it would be easier to just use the yellow top up front and a h/o alternator. And this is just a daily system... no comps at all idk wtf sadistc is talking about ... u dont need 2 alternators ... you should be fine with just a second battery (preferably one that shawn suggested) ... you need a second battery because at idle your alt will not produce enough current to ur amp ... if u get a second battery it will support ur amp for a longer period of time and ur voltage will not drop as much Then why not just get a bigger alternator. I thought i read it a million times that would be best in the long run over a battery because i a battery cant produce power? I dont want to put strain on my alternator if I dont need to. & i didnt pay the dual alternator for 2000 watts MAX idea any mind. Lol usually the bigger the alternator the less output they produce at idle ... it will also cost more money ... an extra battery will also stabalize ur voltage more ... according to iraggi you shouldnt use an isolator at all ... "for every reason to get an isolator there is 10 bad ones" -
alright thanks
so i was thinking of 2 saz-3000d as well as the 100.4... this is for daily ... if i have it strapped for 1 ohm (each amp at .5 ohm) and i tune it with an oscilloscope is this still a bad idea? ... wouldnt the nominal resisitance rise up to over 1 ohm anyway so it would be safe? ... what do you recommend as far as total aH (jake i forgot what you said lol) and how many strands of 1/0 will suffice to the rear (approx 15 ft from front to back battery bank)?
So you would recommend a battery & battery isolator over just a new alternator? Why would I need a extra battery anyways. I thought it would be easier to just use the yellow top up front and a h/o alternator. And this is just a daily system... no comps at all idk wtf sadistc is talking about ... u dont need 2 alternators ... you should be fine with just a second battery (preferably one that shawn suggested) ... you need a second battery because at idle your alt will not produce enough current to ur amp ... if u get a second battery it will support ur amp for a longer period of time and ur voltage will not drop as much -
which one would you do then if it were up to you jake? i have 4 subwoofers so would it be better to power each one separately?
i can get 4 of the 1500s for 100 cheaper if i wait ... my question is will they put out around the same power if i were to get 2 of the 3500s
wouldnt 4 of the 1500s be a good choice? ... i heard they are incredibly underrated ... would they put out more than 2 of the saz-3500d strapped?
if i were to wait until u received 4 2000s would u be able to give them to me for that price?
so would 2 runs of 1/0 be enough ... i am going refurbrished n e way ... do you think u would be able to get me 4 2000s refurbed at 375 each? just buy you a SAZ-4500D and call it a day. why when i can get more output for the same price and i wouldnt have to wait until end of october
stick with the alpine
Not sure who told you they don't like over 3v... but the limit is 6v. There are issues with fancy RCA cable connectors, though, many times they don't make good contact. Cheaper cables don't have this problem. do u consider the knukonceptz krystal cables fancy? ... i just bought them and i am buying some sundown amps obviously ... the problem is not the wire it is the connector ... it does not get a good connection to the inputs I have seen those work for people... anything with high tech looking ends on the cable has the potential to be an issue, but not always. ya. i dont think it is necessarally a problem with just sundown amps ... i know my kicker and jbl amps were having problem with my 120 dollar 4 channel and 2 channel tsunami cables You do realize that wire is wire right? obviously but the problem is not the wire it is the connector
well u said that 1/2 is a bad idea so im not gonna run that ... i didnt plan on spending more than 1500 on amps so i think 4 saz-2000s is out of the ? lol ... unless you can work out some type of deal with me
Not sure who told you they don't like over 3v... but the limit is 6v. There are issues with fancy RCA cable connectors, though, many times they don't make good contact. Cheaper cables don't have this problem. do u consider the knukonceptz krystal cables fancy? ... i just bought them and i am buying some sundown amps I have seen those work for people... anything with high tech looking ends on the cable has the potential to be an issue, but not always. ya. i dont think it is necessarally a problem with just sundown amps ... i know my kicker and jbl amps were having problem with my 120 dollar 4 channel and 2 channel tsunami cables
alright so if i were to put 4 xcon 18s in my suv which of the 2 would you pick to power them? ... what do you recommend my aH rating look like ... will 2 runs of 1/0 be plenty to the battery bank?
i see ... so it would not be a good idea to run these amps at .5 ohm then because the resistance could also go lower than that ... so i should either go 2 saz-3500 at 1 ohm or keep the saz-3000 at 1 ohm each ... i read on your website that the saz3500 is only doing 6kw strapped ... is this correct or is there a typographical error ... also what do you recommend for wire and batteries jake?
