Lucky 76
SSA Regular
    1,212
  • Days Won
    1
Everything posted by Lucky 76
  1. because its a pain in the ass to wire lol
  2. Alright I am just going to buy some 12 gauge knukonceptz wire then. Cash money is tight lol.
  3. Lucky 76
    Xtreme SPL Box Building Techniques
    i saw some 1" threaded at my local hardware store believe it or not lol
  4. No you are fine. Stop thread jacking BEYTCH!
  5. i like the knukonceptz flex cable. Kicker Hyperflex is also good. I would stay away from Monster Cable. I bought 250 ft of 1/0 to find out there is some plastic tube shit in the middle(apparently a noise reducer but very doubtful). I bought the monster flex cable and it dosent move at all. Just a rip off in general. If you dont need flexibility welding cable is the best way to go about things.
  6. Lucky 76
    Question about batteries needed
    So I emailed xs and asked about what I needed as far as batteries go. Here is the actual email. I just wanted to know if this is all I really need? I want my voltage to stay up and dont want it dropping. What would you recommend for my current installation? As it stands right now I have a 260 amp alternator. I drive a lincoln aviator which is the same as a ford explorer. The stock alternator was a 130 amp. I do not know how much current draw it pulled but I am sure it is more than the average car. I listen to my music loud 90% of the time. As for my current installation goes I have 4 of the sundown saz1500s going in which have fuse ratings of 150 amps and then I have a sundown sax100.4 and a sax120.2 which have fuse ratings of 90 and 60. So that is a total fuse rating of 750 amps. I am assuming that it would be better for me to replace my stock front battery as well to prevent voltage equalization of the different batteries. Just let me know what you recommend and if you could give me a price on it shipped to 06795. Thanks, Christopher Perugini Here is the email from them: Hi Chris, We actually have a new model that will bolt directly in place of your factory Group 65 battery. It is our D6500 model and it will be available on November 20th. If you cannot wait until then, our D2700 model may fit if you have some additional height clearance. If there is not enough height available, you can go with our D3400 and it will fit just fine. These batteries, along with your 260A alt will provide enough power to supply about 3kW. To properly supplement your 7,500W system you will need to add a secondary bank in the back. There are many options to choose from, and I would select whatever best fits your installation. For example, you could use 5 D680's, 3 D925's, 1 D3100... the selection is up to you. To get a better feel for the wattage, refer to the attached brochure. Once you know all the items you need, just let me know and we'll get you a shipped price. Thanks! Customer Service Team
  7. Lucky 76
    choosing the right 15" sub
    i would recommend the wood blocks. The phone books could create port noise due to the pages. Plus you could measure how much volume you are actually decreasing the box by
  8. Lucky 76
    The problem is not the subs it is the box . The q is a sound quality sub and if u look at the response curve it is pretty flat. Adjust your tuning and you will be fine. You need to find the sweet spot for your listening pleasure. In most cases the lower u tune it the more high end you will loose and vice versa.
  9. Lucky 76
    How much Ah is needed
    I am pretty sure it is calculated without a charging source. You have an alt that will charge those batts and you will also not be drawing that much current at a constant rate.
  10. Lucky 76
    I am going to run a single d3100 and the new starting bat they are coming out with and I will go from there.
  11. Lucky 76
    nightshade 15s or fi bl 15s
    I would go with the fi bls over the nightshades if I were you. The nightshades are a lot more money and you will not be able to use and abuse them like they were designed for with a 2kw amp. You might want to look into two of the ssa icon 15s. They are rated at 1k rms each and in my opinion sound incredible. I had 4 of them in my car and they burried lows off a rf t40001bd amp.
  12. Lucky 76
    Field Effect Transistors(FET)
    I know for a fact that MOSFETs are used because of their efficiency. I am not sure about the low noise though. They remain a lot cooler as well that is also why they are efficient I a believe.
  13. Lucky 76
    I know I have a car audio addiction when......
    -WHEN YOU GET A BASS LINE STUCK IN YOUR HEAD, AND TRY TO REPLICATE WITH YOUR MOUTH AND VOICE AT WORK WHEN YOUR BORED. x2
  14. Lucky 76
    edit: that is by FAR the most pathetic thing ive heard in my life. i want to laugh, but its just too pathetic. LMMFAO!!!!!!!!
  15. Lucky 76
    Ya ill stick with the recommended. It saves me money. If worse comes to worse I can always buy another.
  16. Lucky 76
    Lots of 18s
    oooooooohhhhhhhhh shit
  17. Lucky 76
    alright thanks!
  18. Lucky 76
    audiobahn aw120q
    ya i sold my bxi to my friend. I get a little jealous each time I see it. He has his blending with the blue neons in his car and it looks delish. It actually does rated power too despite what most people have say. Great amp for the money.
  19. Lucky 76
    audiobahn aw120q
    I am not gonna lie, I had 2 audiobahn aw1206 on a hifonics bxi2006d. For the money I spent I couldnt have been happier. This was my first install and didnt really care as much about the way it sounded but how loud it could get. Back then the louder it was the better it sounded. I traded them for a set of cvr 15s and to be honest with you the audiobahns actually hit more precisely than the cvrs did. The cvrs got a little sloppy.
  20. Lucky 76
    t shirts
    that would be nawyce
  21. These videos will show you why you need to have a proper electrical system backing your amps.
  22. Explains the pros and cons of caps and also when, where, and why you need an alt and or battery.
  23. they are also very easy to follow using picture diagrams instead of schematics for you less electrical savvy people.
  24. Lucky 76
    audiobahn aw120q
    they are going to sound like ass regardless. tell them to throw them out and get something else.
