85mag
New Members
    21
Everything posted by 85mag
  1. 85mag
    Fl Bl 15
    Can i put a a sundown 3500d on a single 15 fi bl?
  2. 85mag
    Fl Bl 15
    cause it clipping is the subs cuts in and out right and it doesnt do that
  3. 85mag
    Fl Bl 15
    To tell you the truth i dont know on the box side because i didnt build it but i got the specs off the website to fit it to the t. Cause i had superbass probox i busted it, it cracked crossed the top from one side to the other
  4. 85mag
    Fl Bl 15
    the subs isn't clipping and its in a custom box tune for that sub
  5. 85mag
    Fl Bl 15
    No since you have this question. The real question is why do you want to damage your sub, go get a BTL if you want to use that much power. Well whats the biggest amp i put on it? have you even thought about looking at Fi's website to find out how much wattage the BL can handle? yeah its says 1000 but i have a us amps md2d with a kenetik hc1800 with upgraded alt and the amp is max out and the sub is asking for more what do you mean maxed out? the gain is all the way up? how do you have the BL wired? to 1 ohm? yeah 1ohm and 0 guage wire and the gain is all the way up
  6. 85mag
    Fl Bl 15
  7. 85mag
    Fl Bl 15
  8. I have two batteries a yellow top duralast under the hood and kenetik hc1800 with a us md2d on 1 15" fi bl and a pioneer gm-6400 for my highs; stock alt< no battery isolater; i"m putting out 13.2 volts i'm trying to put 14v +. How can i make the that happen? Wrong information: it"s puttin out 14.4v but when the sub comes in its drops to 13v - 12v - 11v; so what can i do to correct this?
  9. so the big 3 wouldn't make a difference, w/o a hc alt?
  10. have you done the big three upgrade yet? what size wire are you using? 13.2 at idle? thats awfully low 0 guage all over car so wat else is there to without a h/c alt that's with the sub playin its at 13.2 idk what it is with off sry if i misunderstood you, i know you are using 1/0 but have you done the big 3? sry if you already answered but i wasn't sure whats the big three?
  11. yeah its at idle but it's at 14.4 then it drops 13v - 12v i want to keep it at 14v though
  12. have you done the big three upgrade yet? what size wire are you using? 13.2 at idle? thats awfully low 0 guage all over car so wat else is there to without a h/c alt that's with the sub playin its at 13.2 idk what it is with off
  13. have you done the big three upgrade yet? what size wire are you using? 13.2 at idle? thats awfully low 0 guage all over car so wat else is there to without a h/c alt
  14. What is the strongest amp that I can put on a 15" bl
  15. The RMS is 1k watts. A couple hundred over will not matter. Stick with 1k-1500. Im assuming this is for music and not burping or anything, right? i have a md2d on it already, can i put a saz-3500d on?
  16. The RMS is 1k watts. A couple hundred over will not matter. Stick with 1k-1500. Im assuming this is for music and not burping or anything, right? You can get a 10,000 watt amplifier and put it on there, as long as you set your gains and use the volume know wisely you will be cool . can it handle a saz-3500d?
  17. 85mag
    How do you set a md 2d?
    I have a md 2d but i don't know how to set it. i don't know what the sub sonic and lpf does. could tell me a step by step to set it?
  18. 85mag
    Wat amp to get
    I have a single 15 bl and i want to kno wats the hardest pushin amp i can put on it?
  19. what's the best way to mount a sub box to the trunk
