3,836 -
Days Won
45
Content Type
Profiles
Forums
Gallery
Everything posted by altoncustomtech
It's simple, but effective, and MUCH cheaper and easier than building an enclosure just to find out it won't go in the car.
Oh that's not intended to be used, unless he wants it sub up/port back. I wouldn't think that's ideal either, but there's people who do it. I was just showing him a quick drawing so he could get an idea of what he was thinking about, what it could look like and to show it's easy enough to toss some ideas out there in 3D which makes it easy to see how different configurations work. The subs could just as easily be on the front of the enclosure if that's what he want to do. The easiest way to find how just how big you can go is to make a cardboard mach-up of the enclosure you plan to use and see if it can pass through the opening. By using the cardboard you can see exactly how big you can fit before running into issues with sliding it in.
The miniDSP does EQ also, so no need for another device. You do need a computer for tuning (setting XO points, slopes, EQ, T/A, etc). With a laptop you can sit in the driver seat, and adjust everything on the fly. I could not find any info on the miniDSP site on anything other than crossover and EQ controls. I wasn't aware they could do T/A as well. Nice price for such a powerful little box, lol. Reading > me. They just call it output delay. LOL
2012 Fusion All Sundown Everything! Start Pg. 14
altoncustomtech replied to EPerez's topic in Build Logs
It's looking really good so far. That red will really look good against the black. -
How to locate fiberglass speaker rings perfectly, get the angle exact&
altoncustomtech replied to mklett33's topic in Technical Info & How To's
Very kewl, simple and effective. Nice to see a good way of doing that. I've not yet had to do any fabrication of the sort which would require matching angles like that, but it sure looks like another good tool to have in the belt so to speak. Thanks for posting this up! -
I think it's interesting just how completely random it seems to be. For example, I was on here about two hours ago and was using the "View new content" link without any issues. Just tried it again and poop, no worky, with the same machine and browser, nothing has changed. Also earlier I got the error when trying to go to the 4" VC heavy hitters page from the "View new content" page. Went back to the site index and had no problems going to the first page or the third page, but couldn't go to the second page. Random isn't a good enough description for how it happens. I have no training or knowledge about web pages, design, etc. but considering the little annoyance is still plaguing the site it must really be a bear to track down. I feel for you guys, I can't imagine how many emails and PM's you're probably getting on it.
How To Clear Cache/Cookies in Google Chrome
altoncustomtech replied to DanP's topic in Technical Info & How To's
The first thing I did when I received the errors on this site was to clear the cache and cookes. Not helped one bit. It's funny I can copy/paste the link into another browser on the same machine and it work once, then it may not work on any browser later. -
Kewl vid, very cute girl!
Box size and tuning frequency
altoncustomtech replied to handman84's topic in SPL & SQ / Fabrication
There's not any "Rule of thumb" or ratio for enclosure size and tuning. WinISD is also not the best program to use for designing enclosures for the car audio environment. It's not too bad for getting an idea of what the response might be like for a given driver in a given enclosure, but sometimes it's just way wrong and it has no idea what the response will be once it's in the car. I would never go just on what it says but when it comes to the box specs posted by SSA you can bet that the recommended enclosure sizes are correct and ideal for the sub and 3cuft is right at the top of the recommended range. 32hz or 34hz you're probably not going to be able to hear a real noticeable difference between the two. What's the max dimensions you have to work with? I can help you design and draw something up if you want. -
This is one of the quick designs and drawings I had made up. It measures 36" W x 16" H x 26" D as I had mentioned above (the extra 6"). The specifications are 4.5cuft NET volume tuned to 32hz with ~80sqin of port area. This is just a quick and basic drawing of what it could look like. Modeling the enclosure like this is how I know the 10's wouldn't fit on the top face of the enclosure.
I just did a quick drawing on the 10" box. Unless two are put on top and two on the front then the four subs aren't going to fit, there's just not enough space on any one face for them to fit without interfering with the port wall or a box wall. I'm not sure how good an idea it is to put the subs on different faces either. I could see where it could possibly cause a loading issue, at the same time I can also see where it wouldn't be an issue, I'm just not experienced enough to know the answer to that.
Sure it would. For the 12's it would only need another 6" to keep the recommended 4.5cuft NET volume and get ~80sqin of port area which would be plenty sufficient. For the 10's it would need another 7" to keep the recommended 5cuft NET volume and get ~80sqin of port area for them as well which will do nicely. What does that extra 8" consist of? It's not the remaining room between a wall in the vehicle and the enclosure is it? You'll need room between the enclosure and any surface for the port to breath. Another issue you may have with the four tens is fitting them all in the enclosure.
I have to disagree on both counts. The NET enclosure size has to be down close to or at the minimum recommended for either option and the port area has to be way too small (at least for my tastes) to get either the 12's or the 10's in an enclosure that size. If you go by the quick and easy calculator on carstereo.com (which is usually a bit smaller than the Small method) the port area is well below what it recommended just to fit. For the 12's to fit within those dimensions the NET enclosure size needs to be 3.75cuft with 54.375sqin port area tuned to 32hz. That port area calc says ~76sqin minimum. For the 10's the NET enclosure size minimum recommended by SSA is 4cuft and it has to have ~49sqin port area tuned to 32hz to fit. That port area calc says ~82sqin minimum. Usable I suppose, but not optimal. For what it's worth I sure wouldn't recommend either configuration to someone as I wouldn't use either configuration myself. It would be a great fit for a single 15" ICON though. 3.5cuft NET with ~58sqin port area tuned to 32hz.
I keep getting this error on some pages: "Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 160312 bytes) in /home/soundsol/public_html/forum/admin/sources/classes/output/formats/html/htmlOutput.php on line 625". Any idea what's up with that??
That's kewl, I figured you guys are on it. I was just hoping it wasn't just me having the issue.
- Show next comments 210 more
I can see them fine as well. Jared the enclosure looks great!! You did a clean job on it, especially the carpeting. Still can't wait to hear your thoughts on the sub too!
Yeah those XCONs would definitely kick some ass but he's trying to run closer to $600 total on the budget AND have the subs/enclosure removable. Being removable wouldn't be too easy with about 100lbs worth of subs plus the weight of the enclosure. Hell my Q's are a fair bit lighter and removable as well. It takes two people to do it carefully enough so I don't have to worry about dropping it. Besides the DCONs will still offer plenty of output. OP, dollar for dollar I think you'll find the SSA subs, no matter the series, will stack up against equivalent subs from the well known brands with ease. Very few companies offer drivers that off the performance, quality, and reliability these will for the money.
It's impossible to say just how long it will take them to reply. Considering the nature of the issue I would resend the email if you've not heard back from them in 24hrs. Did you order the sub with dual 1 or dual 2 ohm coils? That amp is rated a fair bit above the rating of the sub at 1 ohm. That's not a big deal for an experienced user, however considering several of your questions I tend to think you don't have the experience needed to safely use that amp with that sub at full tilt. Now, if you ordered the sub with dual 1 ohm coils with the intention of using the amp at a 2 ohm nominal load then its definitely a good match as the amp is rated for 1700wrms at 2 ohms. If you did indeed order the sub with dual 2 coils then I would recommend the brz1700. The need to upgrade the alt will depend on what kind(s) and what number of batteries you plan on using and what kind of voltage drop you experience. I believe in always doing a big three no matter how small the system. I've sen it help some small electrical issues in vehicles that didn't even have systems in them due to such horrible factory grounding. More important is the enclosure you're going to put the sub in. The sub in a properly designed and executed enclosure and installation powered by only a few hundred watts can outperform a horrible enclosure and less than ideal installation on 10x the power. Do you have a design yet? Are you building it yourself? Have you built any before?
Well I don't know the reason why spanky is considering a c pillar wall, but I know the reason I'm looking at doing one is to blow away all the nooblets around here. No one near here has a wall of any kind. To hell with numbers I just like to be different.
Yep, C pillar wall as Dave stated. I plan on doing one with four 15" DCON's myself in my Blazer playtoy project vehicle. It's a big deal to do a wall though. A lot of planning and hard work is required to get a good fit and finish along with proper specs for the right performance. I'm not looking forward to doing the one in that Blazer, lol.
Yes, if the name used for the billing information does not match the card it will typically be declined. I would wait for Fi's reply to your email on the situation. Your dad may not appreciate the bill when two 18's show up at your door, lol.
Did you make a payment from your bank account through paypal? If so then that E-CHECK can take 5-10 business days to clear through the whole system. If you used a credit or debit card then it should have been pretty much instant. If you paid using a bank account as the payment source just have some more patience. If you used a card then it may not hurt to email Fi and see if maybe something got crossed up on the order.
Thanks, I made that post before seeing or reading anything about the server change. It made sense when I saw that. I'm not certain the weight is posted correctly. It's after 3am right now and while the SSA store won't load (probably issues due to the server switching, best time to take things down for those kinds of reasons are the middle of the night when traffic is lowest) the 1800Woofers store would and it shows the same 20lb weight for the 10, 12 and 15 inch sizes which I know isn't accurate. I can remember the shipping weight being right at 20lb for my sister's 12" but the 15" I bought recently from a member on here weighed in at 28lb shipped. If the DCON 10 is heavier than the JL 10W3 then I can't imagine it's by much at all. I see what you mean about the price too. That's got to be the cheapest price there is on the JL and due to that fact I would definitely imagine it's not going to be coming from an authorized dealer/distributor. Also, when you open the page that shows all the prices sorted in price+shipping order the cheapest price is $175 as the other stores that show up with a $147 price don't have free shipping. JL Audio will not honor the warranty for any product not purchased from an authorized dealer/distributor so you have to make a judgement call on how important that is to you. JL makes a great product and if you decided to go with the JL I know you wouldn't be disappointed, but the DCON's will save you a few dollars and its my opinion the DCON would effortlessly compete with the JL on all fronts if not exceed it.
Long-time lurker finally posting up!
altoncustomtech replied to rocketman123's topic in Newbie Sign IN
to the forum! -
What the hell? I thought for sure I replied to this thread, along with a second post in this thread by you OP. I'll reply again though. What kind of restriction are you going to have on enclosure size? It seems like you'll need it to be fairly light if you're wanting to be able to easily remove it. I would suggest a single DCON 12 or a pair of DCON 10's for several reasons. First being that the enclosure size for 10's or a single 12 will be very close with the distinct possibility for more output from the pair of 10's due to the extra cone area and increased power handling. Second the subs themselves are relatively light in comparison to others. Third the small amp that would be needed to run either setup would be a bit less expensive to attain which would help stay well below the budget. Fourth, the smaller amp would also very likely not require much in the way of electrical upgrades if any which helps a lot in the realm of usability and budget as well. The DCON's may be lower powered subs but don't let them fool you they're true performers. My sister has a single 12" DCON in her Durango and it is truly fantastic. Very good and articulate response that sounds great and it can also get plenty loud enough for most anyone who she's demoed it for. If I were forced to replace the Q's in my van with her DCON it wouldn't upset me much at all, except for the money difference, lol. Also, for making the enclosure easy to remove you might look into Neutrik Speak-on connectors. They're not real expensive, are non shorting by design and can be disconnected/reconnected with power applied.
