emh9009
SSA Regular
    3,649
  • Days Won
    8
Everything posted by emh9009
  1. emh9009
    2k vs 3k on BTL N2
    And who is to say you wont be happy with 2k? Could be too much even, never know.
  2. emh9009
    2k vs 3k on BTL N2
    It may make a diff. on the meter, but probably not to your ear. The general rule is that you need to double your power to notice anything. It's going to depend on box, install, person yada yada yada. But i would say not worth the strain on the electrical.
  3. emh9009
    2005 Scion XB mini build
    Schweet! Looks solid, you've put a lot of effort and thought into this. It will pay off once you hear them
  4. emh9009
    budget system for my bro
    couple black FiDay X 10s? Don't forget to budget wire in there. Also if you don't want to try the diamonds, you could do the CF coaxials. Their component sets have a great following. These can't be too far behind. http://www.soundsolutionsaudio.com/store/products/Bravox-Audio-CX60CF-Coaxial-Speakers.html
  5. emh9009
    Let's see some videos!
  6. emh9009
    Let's see some pics!
    Fiday X series 12s
  7. emh9009
    need help with building box in trunk
    measurements of trunk? what kind of ports do you want? any more info?
  8. emh9009
    T3 T600's, AQ SDC2.5's, or SA 12's
    2 of each! lol If you already have 2 SA, then just get the rest so you dont have to deal with selling them.
  9. emh9009
    Replacing Speakers, what to choose?
    http://www.soundsolutionsaudio.com/store/categories/Speakers/ link to bravox, they're getting some pretty darn good reviews around here. Be sure to check them out. go to a local shop/show and try and listen to some stuff, see what you like.
  10. emh9009
    I wouldn't bother with the rears. Check out the Bravox in the SSA store, i believe there is a deal with a comp. set and amp going on right now.
  11. emh9009
    Happy b-day bigger_george
    Happy late birthday!
  12. emh9009
    Great stuff. Nice ideas, too! Keep it up
  13. emh9009
    2010 LA Auto Show!
    I like the Lexus and the Fiesta
  14. emh9009
    1991 Honda CRX Si
    So who has used hurricane nuts to secure their subs? What kind did you get? I'm looking at the #10-32. Is there much difference between those and the 1/2"-20 or the #8-32? http://www.parts-express.com/pe/showdetl.cfm?Partnumber=081-1084 VS. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=081-1082 VS. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=081-1080
  15. emh9009
    AA Carbon's
    I was mentioning 50hz, because that is what some people have been telling me I guess. I'm realistically looking at having the sub crossed at 70 (XCON 12). I like a little more impact from the sub. Problem is, I don't know if the XCON is capable of running up to 70 hz. I had an ED 13AV2 and was told it would exceed 70, but based on an RTA, 63 is where it rolled off fast. I really want a system that is going to give me some hard hitting kick drums, even the tighter metal kicks. Also, here is the site for my mids http://www.dls.se/en...?produkt=en_581 Was the RTA in your vehicle? Reason I ask is that you might have a vehicle-induced roll off around 63hz that is independent of the driver. You would have to RTA it both in and out of the vehicle to determine what affects your vehicle is contributing to the sound. Yes, the RTA was in the vehicle and we tried the sub in my buddies Escalade and same outcome. We didn't test it outside, but we assumed it would show the same result. We had a DD 9512 to test in my vehicle and it did really well, but needed some eq'n in the low end. Hitting a wall like that means one of two things. An electrical filter or a mechanical filter. Sure you didn't have a LP on? If not, there was some hell of a mechanical one. Did you try multiple enclosures? There is a way around it... I surely wouldn't use the AA's with the crossovers you have, but if you were to swap out those mids and run active fine. At that point though I'd change the tweeters as well. yep, tried different enclosures too. I did talk to someone at Elemental and they said the sub wasn't designed to go much higher than that. The inductance was fairly high. He didn't have an exact number, but he was assuming it was higher than 5mh. If I did get the AA's, I'd probably run them between 60 and 70, depending on how the XCON is going to perform. Predicting what you're going to cross them over at isn't going to do much, that will probably change once you get it all installed. Every install is going to have different limits, and different settings that sound good. But i do love my Carbons, i say give them a try, if you're really looking and needing something new.
  16. emh9009
    AA Carbon's
    I have the AAs, they can play 50, but there really isn't much sound. Even if your sub is crossed over at 50 it will drown them out, so no real reason to do it that low. It's just risky having them move so much. They sound amazing on rock/metal, i love them.
  17. emh9009
    1991 Honda CRX Si
    Thanks, much! For now my 1500D. The next upgrade will be to a 3500? But thats in a while. Thanks!
  18. emh9009
    It's too late, but wouldn't a steel bar across the rear panel help with your goals?
  19. emh9009
    SSA ICON Series out of stock
    Another upgrade? ICON v.4?
  20. emh9009
    1991 Honda CRX Si
    I believe subs up/port back. Is that what you're asking?
  21. emh9009
    1991 Honda CRX Si
    This is how they will be placed in the box, i like the tilted look. Nice black finish on the ass And what's left of the living room haha
  22. emh9009
    1991 Honda CRX Si
    4 12" Fi Xs
  23. emh9009
    1991 Honda CRX Si
    And the first one i open happened to have other goodies as well!
  24. emh9009
    1991 Honda CRX Si
    Got 2 large packages today, but was irritated how though. UPS just decided to leave them outside, while it's pouring outside, nobody home for hours. Awesome. Luckily nothing was damaged or stolen. All is well, time to pull them out of their packaging and take some pics! They're uploading now...
  25. emh9009
    Can Fi X handle 500 watts rms
    The FiDay Xs are only a 2" coil. 500 is almost double what is recommended. I don't see any reason to, unless you're planning to cook the sub. Seems like you should have bought 2 for that power range.
