emh9009
SSA Regular
    3,649
  • Days Won
    8
Everything posted by emh9009
  1. emh9009
    Make your own ring terminals
    AND they have customer service? Ill definitely order from them
  2. emh9009
    This would be helpful
  3. Taking the dash apart to a whole new level! I'm too scared to do that to my car, i dont even like drilling holes!
  4. emh9009
    1991 Honda CRX Si
    05/29/11 09:00 1 Import Face Off WOODBURN OR 479-750-0505 FE+CS DP Woodburn Dragstrip - 7730 Highway 219 Northeast - Woodburn - OR - 97071 Looks like i have a drive ahead of me at the end of the month.. First USACI event? PLEASE! I don't know if i want to compete, but would be awesome to go to. Not TOO far away. 5 hrs?
  5. emh9009
    rival904s walkthrough build.
    that's like... 12 Ds! Always on the lookout for more looks like a solid list of equipment! Keep the pictures coming!
  6. Thanks. I expect to see pics when you do. Of course! Keep a lookout, should be happening soon. This friday is payday, that means i can get these little things that are holding me back ordered and installed
  7. ooooh all the pictures work now Looks very clean. This is motivation to go get my ass in gear and build a frame for my false floor
  8. DC power is a vendor on here, the prices depend on the output you want, ask for the options on your truck. Get a volt meter and install it somewhere to see how bad of a voltage drop you get. If it's getting lower than about 12.5 then you need to beef up your electrical or turn it down.
  9. You can use a 10k amp, depends on where you set the gain But really you can get it and watch your voltage and go from there. But a HO alt would be a wise investment with a big battery or 2, like lance said. There is a big chance sooner or later your stock alt will burn up. I did it with less than 1500 watts on a 60 amp alt
  10. emh9009
    hhr 4th order wall build, fo fih-teenz
    Did you ever get those corners glassed or taken care of some way or another? Just looks like it's getting harder and harder to get back there to work on them. Looks good though!
  11. emh9009
    Got My SA-8s !!!!!!!!
    woo! glad you like them. Gotta' post some pictures though. Check out Andrew at Argent audio for a box.
  12. much easier to carpet with the new glue?
  13. emh9009
    New glue system! Yummy!!!!
    looks pretty schnazzy. get to work now!
  14. emh9009
    Fi Bl 12 Flexing out the Dodge
    that 12 is doing some work!
  15. emh9009
    Thank you SSA
    What's it being covered with?
  16. last 2 images dont work for me? These are looking really freakin' good. If i make a wood model will you glass it for me?
  17. emh9009
    I missed it, is the tank for airbags?
  18. Every time i see an Xcon flex, it blows my mind. I need some of that excursion, for sure! Sucks about the foam on the surround/dust cap
  19. emh9009
    1991 Honda CRX Si
    I haven't yet. I like it way it is now. Not sure if ill be able to notice a difference. If i do go inverted i wont be able to wire it the way it is now, so ill be sending less power. Would only be able to run at 2 ohms on one channel. the amp rates that at ~160 watts, compared to what i have now; rated at 100 watts per coil. If i mount the sub normal it would take even more power to get as loud because of the lack of volume, so i think ill keep it this way. I'm happy, why fix something that's not broken It's within the recommended size for the 12, POSSIBLY a little on the larger side. The new X series call for .6-1.1 ft^3, this box is .93, so i'm golden Hope i got your name right This is true.. Thanks Anything backwards seems weird that's the kewl part about in mang!! As do i, thank you
  20. emh9009
    1991 Honda CRX Si
  21. emh9009
    1991 Honda CRX Si
    "~43 min. remaining" says youtube. it's only 7.5 min. long
  22. emh9009
    Team SSA / Decent GEO SBN Video
    Did my name get bleeped?? lol
