tech2332
Members-
315 -
Content Type
Profiles
Forums
Gallery
Everything posted by tech2332
How cheap can you get the T20001DB?? Edit: How about the SAZ-2000D? SAZ-2000D
Which amp for 10" Fi Bl?
tech2332 replied to 4X4AUTIGER's topic in Amplifiers / Head Units / Processors / Electrical
Audioque 1200D -
New Amp Problems
tech2332 replied to tech2332's topic in Amplifiers / Head Units / Processors / Electrical
I'll get pics as soon as I go buy a camera today or tomorrow. I let my Sister-In-Law borrow my old one and she accidentally ran it over. ...I guess it was time to upgrade anyways. -
Alright, so I got my amp yesterday (Diablo Audio Technologies 1000.1) and it's great, except for one problem. Every time I turn on the truck, about 5 min. later the amp turns off and a blue light (alarm) on the amp goes on, even if I don't have it that loud. Can somebody tell me what might be the cause? P.S.- There is only one L.E.D. and Red means On/Power Blue means Alarm
Amp problems! Help please
tech2332 replied to lilblacky's topic in Amplifiers / Head Units / Processors / Electrical
The ground has came out of my amp on me and the music just shut off also. But after I put the ground in everything was fine. I think there is another problem with the setup. Edit: Did you make sure the ground to the Amp & Car were really tight?? -
Make sure the ground to the car is really tight! Really Tight! -
New Amp Problems
I just found out what it was!!! My ground was loose. Thanks Jonecon2001 for the help. I'll post pics up later of my new amp. Man Diablo Audio Technologies is great! -
New Amp Problems
12.68 At Battery - Truck Off 14.2 At Battery - Truck on 7.45 At Amp Leads (Doesn't look good here) -
New Amp Problems
4 Gauge Power and Ground. But the amp doesn't play at all it, the blue power light just dims on and off. Should I replace the fuse and fuseholder? -
New Amp Problems
Also if this helps any I have a 60 Amp Fuse in the hood and this amp has 3 40 Amp fuses. (1 Ohm Stable, wired to 2 ohms). Should I get better fusing under the hood? -
Good choice. What are the specs on the box?
New Amp Problems
I took out the amp and brought it inside my house to let it cool then put it back in the truck and I noticed that I was wrong about the L.E.D. Light.(I had it backwards on original post) Blue=Power Red=Alarm So all it does is flash (Dims) on a blue light. While the truck was on I took out the remote wire and put it in and it turned on blue steadily then it starts to dim. RCA's and all wiring on the amp is correct. Has the power light ever started dimming when truck was on to anybody? -
(2) 12" sdc2.5's OR (1) 12" hdc3... off a saz-1500d
tech2332 replied to cadillac davelle's topic in Subwoofers / Speakers
2 12's will take up more space than 1 15. -
Is this for a Single Cab Truck? -
New Amp Problems
It ain't low voltage, And I have it wired to 2 Ohms so it's a 1 ohm stable amp so it's not wired low, overheating...i'm not sure.(My MTX amp never shut off on me and my new amp is in the same spot-under the driver seat.) Is there anything else that might be the culprit. (All my wiring is the same i did a direct swap with my MTX Amp.) -
The size of a large match box!!! That is awesome. I might get in touch with you for some speakers and amps for my GoCart/Dune Buggy.
Power Wire Size
tech2332 replied to Estsound's topic in Amplifiers / Head Units / Processors / Electrical
20mm squared is the area of 4 Gauge. 5.189mm is the diameter. Do you go by area or diameter? Edit: I think you go by area... -
Firefox and Opera
tech2332 replied to Aaron Clinton's topic in Computers / Electronics / Music / Games
I have the new Opera Beta and I love it. It's so fast. I did a speed test with IE & Opera and they both were the same on upload and download but the Ping was 117ms on IE and 54 ms on Opera. I guess thats a good thing. -
Subwoofer Setting on HU?
tech2332 replied to pear_b's topic in Amplifiers / Head Units / Processors / Electrical
What level did you have it when you set the amp gain settings? For example, on mine I have it set at 0 and my gain set a little less than half.(Does not mean your amp gain should be the same) But when I set the HU Output on max I would have to turn down the gain so it could be leveled out. Edit: Which is why when you turn up the bass control on the HU it sounds bad. -
I have the Pioneer Deh-P5000ub and I have that too. I consider it like a bass knob on the HU. So I would either leave it at 0 or set it at highest possible and tune your gain settings so you won't be clipping. -
I really like that car but not the color.
I say get the 2 12's. How about the Xcons?
Pretty cool. All the numbers have to be put in inches, right?
Good find.
Thanks, just wanted to make sure because I couldn't find anything on the search function.
