tech2332
Members-
315 -
Content Type
Profiles
Forums
Gallery
Everything posted by tech2332
Here is a JVC Touchscreen. I think it's 1.5 or single Din also has 5 Volt PreOuts JVX AVX77 Either the one I found or the third (Middle) one you found.
I told a few people about this deal. They'll probably give you my Yahoo E-mail but my PayPal E-Mail is different. Danny,
You got any pics? On a side-note: Are you still interested in the Icon? I have quite a few others who are.
Haha. Alright thanks.
Has anybody had any experience with Rear-Firing in Single Cab? I plan on doing this or downfiring. The only problem with downfiring is the max bottom depth I can do is 12.5" so the 12" sub will be on the surface of the wood just barely. I'm worried it might not be enough support because that will leave about 1/2" on both sides of the Sub Hole. (Where ever the sub will be, it will at least have 2 baffles.)
The sub is going to be a 12" AudioQue HDC3 Which I already own. Its 52 Pounds.
I cut out a piece of cardboard that was 21" Wide X 12.5" Length/Depth. This is still a comfortable position. Way better than my 10" box. So my only question is do you guys think the Sub will be supported good enough with double baffle?
No sir I'm not. I'm 5 Ft. 10 In. Tall. And it's not 12.5" Top & Bottom Depth. Top depth is like 6.5" or 6" bottom depth is 12.5". And I still fit comfortably. (Pics Below) Here is somewhat of design. (There will not be an upfiring slot port, it will be a 6" aero firing out the side.) Measurement (Bottom Depth) P.S.- If I do Forward Firing then I'll have to to a Fiberglass Base to gain some Cu. Ft. over the darn Hump.
If you have money for BTL's then get them.
Yes I need a port, i was thinking 2 seperate ports for each sub. layout would be Sub / / Sub all in one box. Do you guys think 1 JL 500/1 On each sub would be sufficient? If you want to save space it would be better to have one port.
Slot Port?
Thanks, and yea i'm still trying.
Updated Design: I now plan on using 1 6" Aero port firing out the drivers side. It will only have the external aero, the inside will be "aeroless".
Got Wood & Glue Supplies Also Got Another Package Today Compared to SSA 10" Icon Hopefully start on box by the end of this week.
Is there a major sound difference for a 12" from 2.30 Cu. Ft. to 2.50 Cu. Ft.??
Okay so I went to Home Depot to get some MDF, Glue, & Screws. So I see the 3/4" MDF and grab a sheet. Then I get home, take it off the truck and find out it's 5/8" instead. Would it be okay to use 5/8" instead of 3/4"? Its going to be for a Single Cab, Downfiring Enclosure, With a Double Baffle. Sub will be AQ HDC3 12"
They would have to be the same. Here is the page to give you a better idea on how to strap. Sundown FAQ
I would recommend 1.75 - 2.5 (per woofer) net volume including speaker, bracing and port displacement. I would tune around the 33-38hz range. You could do a single chamber box and create a L-shaped slot port. alright thanks ... i am sorry i do not know if i am misinterpretting what you are saying ... do you mean 1.75-2.5 cu ft with the sub in or with the sub out ... i know i get all confused when displacement is used in a sentence lol With the sub, bracing, port, etc. in. So after you have all that in the box you should have 1.75-2.5 cu. ft.
what to do with the remote of my saz1000 ?
tech2332 replied to Notorious97200's topic in Sundown Audio
Thanks. I will "study" how to use it to avoid blowing my sub. This little amp is like a beast!!! It's almost like a volume knob for the amp. When it's disconnected it's like having the bass knob at full. -
I thought the same thing.Either that or a couple of MiniHorses.
I'm glad I'm not the only one who doesn't understand a sentence he wrote on this topic.
What amp should I get??
tech2332 replied to ABentley72's topic in Amplifiers / Head Units / Processors / Electrical
my budget is at about the $100 range but i can find deals on ebay/craigslist so feel free to just shoot me some ideas for amps! I got a MTX 600 Watt RMS @ 2 ohms for sale. MTX 600 RMS -
Wiring Icon D2 Sub in Parallel to SAE-1000D? Also, amp settings
tech2332 replied to eman88's topic in Amplifiers / Head Units / Processors / Electrical
Subsonic is a filter that "filters" frequencies below a Hz. Since your box is tuned to 32HZ then you can set it around 30Hz. -
Yea just wire it in Parallel. On the sub just do + to + and - to -. Then get a piece of another wire from Positive Terminal of sub to positive to amp and Vise Versa with of Sub Negative to amp Negative. LPF depends on your taste. 80 HZ or below. Subsonic depends on box. Ported? Tuning? or Sealed? Bass Boost -0 Phase doesn't matter too much
