loondizie52
Members
    244
Everything posted by loondizie52
  1. loondizie52
    audiopipe bullet tweeters
    been looking at the audiopipe horn and bullet tweeters...wondering if they are any decent, and what is the advantage of horn or bullets over regular tweets
  2. loondizie52
    ya those are the exact ones i was wondering about...oh, whats the general consensus on the ap 3000d? does it do rated power?
  3. its actally about 5.7 after bracing and displacement, is it too big?
  4. when you build a box with a square or round port, isnt it nearly impossible to stay within the 12-16 sq in of port area per cube rule? if so what is the rule for those? and when making a external port it is still the same length as if it would be internal correct, only it is on the outside...
  5. loondizie52
    best materials need to build sub box
    or you can make a jasper jig...really easy actually. ive made a few. takes probly 30 min max (if You want it painted or whatever) Saves ya lots of $$$ cuz those things arent cheap. just my .02 by the way, does anyone know what BJ uses to seal his flares to make them so smooth? ive tried lots of primer and sanding with many many coats of primer and paint, and also tried resining and sanding that as well...neither come out as good as his.
  6. loondizie52
    sqaure or round ports vs L port
    well i was just throwin some numbers out as examples but i understand much better now...so you measure down the center to the center of the corner then till the end of the 2nd L correct?
  7. loondizie52
    can you make a port that is part internal and part external...such as 5 inches external and 12 inches internal to get a certain frequency rather than L-ing it? and what is total port length bc on the re site calculator it will something like port 1-12 and port 2-3, and then the port length will be like 19...so how do you figure out how long to make the port
  8. loondizie52
    pierce audio products WMD
    anything its comparable to?
  9. loondizie52
    Sub up port up or sub forward port forward
    also its gonna be a daily driver tuned to 33-35
  10. in a 2001 dodge ram ex cab fully deadened
  11. loondizie52
    sorry...im pretty settled on a 15 or 18 BTL, just cant decide on how to make the box, cuz ive always gone sub forward port forward with port on driver side...but ive been rethinking my regular box styles and was wondering what would have the best outcome
  12. loondizie52
    2 amps on 1 BTL
    if you take a fully loaded btl D1 coils and wire up one autotek mean machine 1500d to each coil would it put each amp at 1 ohms since its a 1 ohm coil?
  13. loondizie52
    2 amps on 1 BTL
    ok sweet thanks i was pretty sure just wanted to dbl check...and should i strap those or run one to each coil? and if i do strap, does it need that maxilink think or just do it the regular way
  14. ive already got the big 3 all done in 1/0 with terminals soldered and all the goods, but im gonna install the alt soon and i was wondering if its necessary to double up on the 1/0 or no? and it says in the paperwork to add another ground from the closest ear on the alt to the frame..is that necessary too or just a good idea?
  15. loondizie52
    HDC3
    how much can a aq hdc3 take daily on good electrical? and whats good box size and tuning recs for a daily setup..mostly listen to rap, hip hop and r&b
  16. ok ive got 2 type r's for now, not forever. but i wanna get a good 1500 rms amp i can use for now and the future. so far im lookin at Audiopipe AP1500D Autotek Mean Machine 1500.1 US Amps MD2 Sundown SAE-1200 Hifonics Brutus 2000 Power Acoustik BAMF 4000 So far its kinda in that order, with sundown only bein that low bc its only 1200rms
  17. loondizie52
    Which 15's
    which one for a daily beater that can take 1200-1500 and get low and loud
  18. loondizie52
    Which 15's
    well i would but i used to have 2 FI Bl 18's and i loved them, but i wanna try other companies and see what else is out there...its like with women, you wanna try as many as you can before you settle with one for a while haha
  19. loondizie52
    Which 15's
    aww SOB...which tc was the Rl-p comparable to
  20. loondizie52
    Which 15's
    just was lookin at the soundsplinters and apparently then arent selling them right now, anyone know whats goin on?
  21. loondizie52
    Which 15's
    how much power can the LI's really handle on a daily system? and what about soundsplinter, im really liking what i see with those...
  22. loondizie52
    Which 15's
    NS is a little out of my price range right now...im lookin in the 350 and under per sub range. unless there is any other suggestions, ive been keeping eyes peeled for used stuff but none so far
  23. loondizie52
    Which 15's
    also will be forward firing in a 01 extended cab dodge ram
  24. loondizie52
    Which 15's
    usually rap with strong low bass such a gucci mane or jeezy etc...still deciding on amp, thinking either autotek mean machine 1000.1 or 1500.1, or us amps md1 or md2....amp choice will depend on subs i decide on, but leaning towards those with the possibility of AQ 1200
  25. ive been looking for a decent amp and i ran across some forums sayin that the fusion 4000's are good amps, so how are the others? or is the 4000 the only decent one? im lookin at the 3000 for $228...
