jcarter1885 replied to nadcicle's topic in General Audio
Vibration sounds like the culprit, plain and simple. Get that fixed or toned down some and you should be A-1. Or get a zip tie or something that can keep it in place, when the bass hits. Might be an eye sore if seen but will probably be your cheapest solution. Is there a way to lessen the vibration of the radio itself without doing so much to the car and dash. Like those brackets you used to hold your horns in place.
Yeah im looking at the PPI now but also wondering if I should save up for better quality. 6-7" Mids: Beyma Pro6WND, 18 Sound 6nd430. 8" Mids: Beyma 8G40, B&C 8NDL51 or Ciare 8.50ndw.
I heard good things about those Usher drivers, even though they have a breakup thats needs eq'ing. I have been eyeing those 18sound drivers myself and they are at the top of my list if I stick with 6-7" drivers. Zaphaudio really breaks things down for an individual shopping for mids.
Could have metal shavings stuck on the driver, a common problem with those mids. I believe their are videos on youtube about it, remember it from my days on the ID forum. Also check your cones, they tend to warp as well causing problems.
Obviuosly 14 volt system charges at 16 volts so im sure he means will it be okay to run in on a system that charges that high. Op why not just run the car and mids/highs amp on 12volt setup and use the 16volt setup for your subs amps.
