12,022 -
Days Won
123
Content Type
Profiles
Forums
Gallery
Everything posted by jcarter1885
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Got tired of the box sliding around and decided to go this route.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
What do we have here?
- 401 replies
1
- secondskin
- fi
(and 7 more)
Tagged with:
So far it seems that I have eliminated the basic rattles inside the car. The rear over head light console should be quiet now. I added one layer of Soundskins speaker foam ring dampening. If you look closely between the black squashed dampening, you will see a black plastic trim piece that is attached the top side of the headliner. That was smacking against the roof of the car. This deadener is about 1 inch thick give or take and thickness is perfect, I had to jam it in there but it works great.
- 401 replies
1
- secondskin
- fi
(and 7 more)
Tagged with:
I loved that thing man when I was car shopping, but for what I got the Passat at that time brand new it was a no brainer. But everyday when I drive by one of those I drool. Dope ride for sure and thanks man.
- 401 replies
1
- secondskin
- fi
(and 7 more)
Tagged with:
Light show at night time
- 401 replies
1
- secondskin
- fi
(and 7 more)
Tagged with:
Daytime shots after wiping the enclosure down
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Fi Neo 4.7 15” new DSP settings
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Faital Pro PR160 new DSP settings
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Eric Steven Horns new DSP settings
- 401 replies
1
- secondskin
- fi
(and 7 more)
Tagged with:
I didn't apply it my box builder did, but from looking at it. It doesn't seem like he had issues nor did he mention any.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Yes sir it is, now I'm upset my battery box doesn't match the enclosure. I will be getting photos tonight with the enclosure's led lights playing.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Updates I'm still waiting on Stevens Audio MB-8 2ohm mids to get back in stock then I will send the car to the shop to have them fabricate my Sony 8" H/U in my dash and do my front doors with one pair of 8s in each door. Will be ordering SMD Fuse blocks for under hood positive wires and trunk's positive wires. All connections will be crimped with terminals. I have quotes from Stinger and Brand X for H/O Alternators, just trying to do research to see who to go with. Ive noticed voltage issues from factory as the weather gets warmer and have been following Euro Bass Girl and she gave me some ideas to mitigate that problem. I ordered a voltage regulator controller knob from Conventry Industries that I will install when the new alternator gets here.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Thank you very much I appreciate it, stick around as there are more things to come and I'll be addressing some things I should of executed better.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
I finally got around to adding some dielectric grease to the front battery terminals. I also added my power wire for my alternator and I should be ordering my H/O Alternator here soon.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
New high score even with lower voltage since it's warmer outside and my car charges at a lower voltage depending on the heat.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
It all started with a vision, then once it's executed you realize that it's way more dope in person.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
This enclosure turned out perfect, I cant wait till night time and I turn on the blue light to see how it all plays out.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
So for the first time in forever I fucked up, but it's ok y'all can flame me. I was rushing and excited, I also tried new screws but at the end of the day it was all my fault. Little drill slippage that I fixed with amazing good, put it on the underside and top of surround as well. Luckily it dries clear and the location of the hole in the surround when the sub is mounted, is at the back of the box so you cant see it anyway. Like Dae Dae said in next Friday, Playas Fuck Up! Haha
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
I had to do a lineup photo since the box wasn't in the trunk.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Don't worry, no subwoofers were hurt during transport. Sheesh when your tweeter is bigger than your subwoofer.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Got a little work done before this storm and tornado warning came through after work, shortened my ground wires coming from the trunk spare well going to battery terminal a lot. Instead of going around the back of battery, above it and back down the front of it. The wires come straight up to the terminal. I also cut the ground wire for my Audio Control amp as well and wired that on that last connection underneath the negative battery terminal. The only ground wire that will be attached on the topside of the negative battery terminal will be for the subwoofer amplifier. I should of done this months ago but I hate working on the car in the cold. There will be no ground wires coming across the top of the battery box. Looks so much better already and I'm no where near finished. Before picture first and after pictures will follow.
- 401 replies
1
- secondskin
- fi
(and 7 more)
Tagged with:
Thanks I greatly appreciate it because I never seen this before and it had me worried. I'm glad I caught it when I did. I will buy a crimper and will be crimping all my wire from here on out. No more set screw style fuse blocks from here out either. Not blaming them but if this can be avoided by not going that route then I'm all for it.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
Going to change a lot of things. That fuse holder will be coming out and I will be getting an SMD Fuse holder and will crimp all wires to prevent this from happening in the future. I'm also trying to upgrade amps to a Crossfire 4K so this may delay the box going in for a while. H/O Alternator is in the works too, trying to stop buying car audio this year.
- 401 replies
- secondskin
- fi
(and 7 more)
Tagged with:
