jcarter1885
SSA Regular
    12,022
  • Days Won
    123
Everything posted by jcarter1885
  1. jcarter1885
    audiopipe 3000
    I just did a lot of research and really couldnt find no hard facts to back it up but I think it is 1 ohm stable when running two channels(1500 x 2 @ 1ohms) but 2 ohms stable when running one channel (3000 x 1 @ 2ohms) because its supposedly two 1500.1's put together in one case.
  2. Well the reason for the small voltage drops is the heat from outside(the later you go in the day the hotter it gets) and your engine components heating up after be running for a few minutes will cause this. Were not saying your battery is bad (the battery can be excellent for a normal car just for starting purposes) but your trying to run an amp that draws over 400amps, the group size battery you have is probably to small for that application. What size and what kind of battery do you have(just because you add a H/O altenator does not mean it will be ok for you to try and draw 400amps or more from it and be okay without upgrading your battery. You have been having alot of voltage problems, how about taking your car to someone who knows what their doing and maybe then can guide you in the right direction (check all your wires and connections, especially your grounds-thats what could be causing all these voltage leaps and bounds).
  3. Just my .02, it seems to me like it is your battery (you got two different alternators put in the vehicle and still have the same problem). That amp is drawing a lot of power and a H/O alternator by itself will not cut it.
  4. jcarter1885
    Thinking about buying a Fi subwoofer
    Either a Sundown SAZ1000D or Saz1500D would do you justice with a 15" Q or BL with the BP option. The most h/o alternators for Saturns are not over 200 amps, so I doubt you will find a 300Amp but you never know. If its a car your not going to fit a 18" subwoofer in a Saturns trunk, you can get a 15" ported with the right amount of enclosure space or 2-12" FI SSD's with a Sundown SAZ-1500D would be perfect also. If you get a good starting battery(group 34) and secondary battery for your system(group 31) you probably wont have to get a h/0 alternator depending on how your voltage holds up. just my .02
  5. jcarter1885
    Rushnrun's Dodge Ram 1500 install
    Sounds like a challenge Bill!! x2 Challenge!!!
  6. jcarter1885
    Midrange amps
    true, true......
  7. jcarter1885
    Amp for 2 15" BL 1ohm?
    yeah just get the 12" BL's in Dual 1 ohm (wire each sub in series to 2ohms, when added together they will drop down to a 1 ohm load),now go get the 2000D.
  8. jcarter1885
    my new subb?
    Id say copy and just make yours louder and sound better thant your friends, every car is different.
  9. jcarter1885
    Biggest Sundown Sale Ever!
    What will be the price on the SAX100.4 once the sale is over, hopefully I can scrap up some funds today. Why not ending tomorrow?
  10. jcarter1885
    Dump the Cap?
    Sundown SAZ-2000D FTW! Now for my understanding on caps, most people on this forum rule against caps because they dont make power (only store power and can be bad for your electrical system). They would reccomend and me also to get a good starting battery and secondary battery by the amp or wherever you can put it because your trying to power your system and in order to do that you must buy something that makes power. Only batteries make power so they will be your best bet (xs power, deka, kinetik, shuriken, optima, stinger etc.). You probably wont need to upgrade your alternator if you stick with an amp under 2500 rms as long as you have good voltage from your batteries while playing at close to or full tilt. If you let your h/o alternator run do lower than the voltage it is regulated for then thats when your in trouble. There really is know way to over do your electrical, its better to be safe than sorry. if im wrong someone will correct me.
  11. jcarter1885
    new sub setup
    glad you could join us. whats your budget for subs, amp? what else will be in the system (head unit, front stage speakers, electrical wise)?
  12. jcarter1885
    Ridn's Expo Build Log
    box is getting their, how was the popeyes.
  13. jcarter1885
    New To The Fourm...What's Up Guys?
    welcome, show pics of system when you get a chance.
  14. jcarter1885
    Hello from D.C.
  15. jcarter1885
    Hello
  16. jcarter1885
    MONSTER TINSEL LEADS
    If i were to see that on a sub, I would be scared to see what it would to my car or what other huge components the sub will have on it (motor, coils and etc.) appreciate the sharing
  17. jcarter1885
    purchased another sundown audio piece of great equipment the SAX125.2 a few days before the sale was over. Thanks Jacob
  18. jcarter1885
    should I get a volt meter?
    That wont work since you said in your other post that you bought dual 2 ohm subwoofers so you will have them wired in parellel @ 1ohm on each amplifier or in series @ 4 ohms on each amplifier. Just wire one in series to 4 ohms on one amp and the same for the other sub and amp. This will help your electrical out and when you get your alternator all you have to do is hook up the rca to strap the amps and your good to go, no taking subs out and rewiring them or anything.
  19. jcarter1885
    Greetings From Adassa Audio
    yeah they make alot of car audio equipment (wondered on their site awhile back somehow) http://adassaaudio.co.uk/home.html
  20. jcarter1885
    slacking... someone offered to buy the truck complete with stereo... for a decent price... so I'm mulling it over should be picking up the new SPL car tomorrow! man thats great news, not just the the setup but the whole car (very impressive because that lets you know someone admired all your hard work. I would say sell and start over because its not like you cant make another SPL car and hopefully louder than where your at now. good luck on whatever decision you make
  21. jcarter1885
    Midrange amps
    you can look at their amps on the ssa's store or sundown audio.com The Sundown Sax 50.4 does 80 x 4 @ 2 ohms (plus some) and the Sundown Sax 100.4 does 160 x 4 @ 2 ohms (plus some).
  22. jcarter1885
    which 18" subs would you choose?
    your first post said that you want sound quality while staying loud, thats exactly what the Xcons will give you (great sound quality while being able to get loud). Im thinking you just want to be loud ass balls like a bright yellow shirt on a sunny day.
  23. jcarter1885
    running @ .5ohms?
    Either way it wont matter since you will be giving both speakers the same power either way, usually it would matter if you run them at 1 ohm or 2 ohms (since a lower ohm load = equals lower power and less strain on the vehicles voltage) but in this case you will be bridging at its ohm load stability also so I think it will be an even call. It just boils down to personal preference. Sorry jay-cee your incorrect. lower ohm load = a higher strain on your electrical system. you loose efficiency as the ohm load goes down there fore your amplifier requires more amperage. Its solely dependent on the amp if you can run it at .5ohms some can some cant. In my opinion i wouldn't run an amp below rated specs unless your aware of the the harm you can do and willing to live with the out come. For a daily situation you'll be far better off at 1ohm and that would be the best advice i can give you. I meant either way he wired the subs up 1600 x 2 @ 1ohm or 3200 x 1 @ 1ohm it would be the same, I didnt even answer the question about wiring it for .5 ohm load, I only did that too one amp (memphis power reference 1000.1 just to see how long it would last for and it did for almost a year) and I didnt even know thats how I let a local shop do it awhile back. Vowed to never let them do my work again, but I would never recommend anybody to run a amp below its ohm stability unless you wanna kill your amp eventually and cause a lot of strain on your electrical. That amp is a two channel amp. It can handle 1600 X 2 @ 1ohm, 3200 X 1 @ 2 ohms but not 3200 X 1 @ 1 ohm. your absolutely right, I even read that post three times over before I posted it and couldnt see a mistake since they took my words wrong in the one before it, but yeah thats what I meant.
  24. jcarter1885
    Midrange amps
    well in some cases power is power it just really depends on the quality of the amplifier your have to start out with (well hifonics is known to put out power and so many say their underrated so their 400 can be around 320 or a little more). While companies like Sundown will give you real power and rate at 400 rms but give you more than that and add some more sound quality to your overall system also. I will say that you will get upgrades by switching to a better quality amp whether its power or sound qualtiy and most times both. A dude on this forum did a review between a kicker amp and sundown amp that he swtiched out for his midrange and he still got more power and better quality, so in my opinion Sundown Audio FTW!
