jcarter1885
SSA Regular
    12,022
  • Days Won
    123
Everything posted by jcarter1885
  1. jcarter1885
    18 btls sealed? why not?
    Or you can email them if you want a direct answer from them since nobody has answered you yet.
  2. jcarter1885
    New guy here
  3. jcarter1885
    Reconfiguring specs on my BTL enclosure
    You and me both
  4. jcarter1885
    Glad you posted this because after reading that topic on end correction I was in the dark also, I just started learning how to do these the paper and pencil method (this will help me out a lot).
  5. jcarter1885
    Sub has arrived, pics and all
    You sure you have it wired like this: Check you headunit settings also. What does your electrical consist of?
  6. jcarter1885
    4ohm stable mono block amp with subsonic filter
    Yes that amp will work, yes you can wire your D2 subwoofer to a 1 ohm final load.
  7. jcarter1885
    New Setup, Starting from Zero. Tips Welcomed!
    Search on the internet for it, look in your manual or go buy the handbook for your car from AutoZone, Pep Boys, etc.
  8. jcarter1885
    x2, and if you feel the need to go against the norm then ask Fi why you shouldnt do it before you do it.
  9. jcarter1885
    battery question?
    Not a problem at all man, I was in the same boat as you two weeks ago going off of AH ratings and thinking I need 2 or 3 batteries. But that is how car audio is full of misinformation that we run off with thinking is true, Im guilty of this myself.
  10. jcarter1885
    Here is a pictorial for you man, these are the two wiring options you have for you subwoofer: or
  11. jcarter1885
    BL or SSD
    That is not even a comparison, for those goals then go for the BL's.
  12. jcarter1885
    battery question?
    You dont buy batteries by Ah rating. Read through this article: http://www.soundsolutionsaudio.com/forum/XS-Power-Batteries-application-t35357.html To the OP I didnt purchase the battery yet but I will in the future, Nathan would be able to help you find out what battery will fit and support your application.
  13. jcarter1885
    fi q 15'' vs kicker cvx 15''
    It depends on which would be louder but it all will come down to enclosure and install, these two subs were made for different goals in mind.
  14. jcarter1885
    battery question?
    Contact Nathan@XSPower or ask to the moderators to transfer this topic to the XS Power section so he can find it easier.
  15. jcarter1885
    Z v.2 15" Production Unit
    Im pretty sure yes the would since you have a major cone advantage there, more motor force and so on.
  16. jcarter1885
    Modified Chicagofans 1500 and 50.4
    x2, the same thing I was thinking but I love the look
  17. jcarter1885
    Pound That Sound Update
    x2, no words but that.
  18. jcarter1885
    I really can't decide.
    Thank you, this actually makes sense to me. I don't think the 18 will squeeze the budget quite as hard, I just wish I could listen to two 15's or one 18 and see what i like better. Listening to either setup shouldnt help your decision because you can find a setup where one 18" will kill 2-15"s and vice versa (its all in the install). Just do like ///M5 stated earlier or make a compromise, that is what it comes down to.
  19. jcarter1885
    hey ssa from cali
  20. jcarter1885
    Amp question and other questions
    To me keep it and use it on your door speakers and sell the Infinity once you get a better amp for your subwoofers, you have a classic amp in your hands.
  21. jcarter1885
    12in Fi Q vs 12 AA Havoc
    If you want to customize your subwoofer then go with the Q but if you dont feel like then go with the Havoc.
  22. Never heard of it, call pioneer and get ahold of there tech team the best way to get this issue resolved.
  23. jcarter1885
    power acoustics
    Please make a thread with a budget in mind so we can help you pick an amp that meets your goals so these topics dont clutter up the board. To answer your question no this amp does not do rated power.
  24. jcarter1885
    kicker cvx or aq hdc3
    Subwoofers can not be compared at all, they are made for different goals in mind so this is a useless thread. Read new member topic guidelines (comaprison threads are useless). The AQ can get loud and the CVX will do better on the lows, so it is a compromise which one you will want to go with (you cant have both, car audio is full of compromises). Next time make a topic on helping you pick a sub that fits your: goals, sound preference, budget, enclosure size availability and so on. Those subs could be put on a 3000watt amp if gains are set right and volume control is use wisely but would I do it no. If you get the AQ 2200D with the CVX's set your gains right with a DMM and you will be fine, just because an amp puts out 2200 watts doesnt mean it is doing it on a constant basis since music is dynamic (there is no problem with having head room). Head room will help some individuals keep from clipping there amp since some want to turn it up as loud as it can go.
  25. jcarter1885
    First taste of Sundown Goodness
