jcarter1885
SSA Regular
    12,022
  • Days Won
    123
Everything posted by jcarter1885
  1. jcarter1885
    BTL problems continue
    but its a ported box though Just like he said: either get a sealed box for your subwoofer, turn the volume down or dont play songs with low frequencies in them.
  2. jcarter1885
    SAZ 3000-d Protect Mode
    Sounds good, glad it is getting taken care of.
  3. jcarter1885
    mikey's OFFICIAL build log
    If they fit your goals and budget then I dont see why they wouldnt be legit. Legit like how?
  4. jcarter1885
    amp tunning
    Bass Boost should be at 0, LPF should be anywhere from 100Hz on down (usually between 60-80hz) but that depends on where your midbass are crossed at and how your speaker performs at that frequency. Your input should be matched to your headunit, so if your pre-out voltage is 4volts on your headunit then that is where you want your input level set at 4 volts.
  5. jcarter1885
    SPL-Labs LCD Bass Meter
    I feel prompted to let everyone know, because of post like this one, that I am not a part of SPL-Labs nor profiting from the group buy in the for sale section. I am here to give a review of a product that has generated a buzz for those looking to step up their car audio experience. I did my due diligence and bought one with my own dime. Rest assured this will be impartial. If it works and is accurate cool. If it sucks, well I guess I out the cash till I find a sucker on e-gay. Just kidding, I wouldn't do that. Now that I got that off my chest, lets move on and continue with the review. and great review so far
  6. Sorry I thought I explained it well enough in the previous post. By hooking up another battery correctly or incorrectly you could have triggered a code that is telling the light to come on. Unhook the secondary battery, the one you just installed in your system. Once you unhook it then see if the lights are coming back on or if they are back off.
  7. jcarter1885
    Serious voltage drops
    What kind of volt meter do you have, if it is a Stinger did you calibrate it before using it? If not then ignore my post.
  8. jcarter1885
    Death By Bass 2 XXX 15's
    Whats the name of the song in the video?
  9. The only things I can think of it being is a code issue or a slip up some where. Take the battery off that you just hooked up and see if the lights still light up, just my .02
  10. jcarter1885
    1995 Cadillac Eldorado Build
    I always loved Cadillacs, enjoy it . Sounds like your headed in a good direction with your plans so far.
  11. Dont use bass boost and dont use a DMM to set your gain since you cant detect clipping. If your worried about your electrical being enough to run at .5 ohms it is only one way to tell, install all the equipment and watch your voltage. I would take extra measures to make sure my voltage is up to par to run an amp at .5 ohms. If your stock speakers get to loud or sound like ass then either replace them or change your settings on your headunit that control those speakers and what they do. Play around with your settings till you get what you want or give us some more information and we can try to help you, how do you have your headunit set up as of now?
  12. jcarter1885
    94 Geo Metro
    Whats changing, let me in
  13. jcarter1885
    4th order bandpass box help (FI SSD)
  14. You can wire an amp to each coil but you may be asking for trouble so I wouldnt advise it personally. I would just run it on one amp at 1 ohms till you can get an amp that you need. What is the exact Autotek Model number and what does the amp do at 1 ohm?
  15. jcarter1885
    Hello from Topeka Kansas
  16. jcarter1885
    95 Eclipse Father/Son Project
    Very creative and use of materials that were already there, deserves a couple :fing34: on the tweeter install.
  17. jcarter1885
    2 12in DC Audio LVL4XLs, 2 stetsom 7ks, 1 2008 Pontiac G6
    on the shirt, definitely need 1 or 2 of them. Good luck on the numbers, what are your goals if any?
  18. jcarter1885
    ReconeHelp!!!
    Personally if your not listening to spanish music or old school music then it really is no use for the epic center in your car, unless you can control it right. During rap it shouldnt really be used period since nowadays it will just distort the bass then help it.
  19. jcarter1885
    subaru build w/ 2 15" dc
    Keep up the good work, looking nice so far.
  20. jcarter1885
    Drive By Testing!
    on score
  21. jcarter1885
    ReconeHelp!!!
    Changing subs may help out but if he doesnt know how to control the epiccenter then it will happen again.
  22. jcarter1885
    Q 15: sealed or ported?
  23. jcarter1885
    12" Lethal Injection T/S Parameters?
    Dont know there T/S Parameters, you may have to email them for those specs but this may help: IA Recommended Enclosure Sizing - SSA Car Audio Forum
  24. jcarter1885
    Memphis Amps?
    Memphis makes good amps, I had a Power Reference a few years ago. I loved my amp and it did its job, i accidentally wired to 0.5 ohms and it lasted for almost a year until it gave in (user error listening to a friend before knowing what I was doing). What is your budget and what features do you need. If the Memphis fits your budget and will fit the requirements for your install then get it.
