jcarter1885
SSA Regular
    12,022
  • Days Won
    123
Everything posted by jcarter1885
  1. jcarter1885
    2021 Volkswagen Passat Rline
    Factory battery was a group 43 but it had extra room left in the battery tray and seen a video on YouTube where a dude had a group 48 battery so I said F it and went bigger. New battery fit with no issues whatsoever. Voltage with Max AC and other features on now sits at 14.3v vs 13.8v with the factory battery in.
  2. jcarter1885
    I like twins even if one is bigger than the other one. Love these batteries, the new underhood group 48 battery came resting at 12.96volts.
  3. jcarter1885
    Big 2 of 3 wiring is complete plus factory wire upgrade for the negative side, all 3 wires are 2/0 welding cable. The positive side is going to be a whole different animal.
  4. jcarter1885
    VW wiring terminals suck as they do not allow you to take off the nut to allow more terminals to be added. No biggie as I can easily replace it. I actually love their grounding points, pretty effin dope of you ask me. The nut that holds the wires is back but the underside that meets the terminals is bare metal.
  5. jcarter1885
    When you buy battery terminals and the whole is too small for the bolt, just bring out the drill and get to work
  6. jcarter1885
    New Battery Terminals from Jim's MachineWorx for my front battery. You will see why I need these later on, probably this weekend if I start on the big 3 wiring.
  7. jcarter1885
    I would but the blue lights from above, light it up perfectly. I need to find a different filter because my camera makes everything appear blue which it doesnt do looking at it in person.
  8. jcarter1885
    The small subtle things stand out the most
  9. jcarter1885
    Cleaned up the front stage 6 channel amplifier wiring
  10. jcarter1885
    Woke up this morning and deadened the front door panels, picture is of driver side and both panels done the same.
  11. jcarter1885
    Fuck this Fender Audio stuff, is the short answer. It won't allow me to tap into or get great signal using a DSP. I have to get a Navtv Gen V unit to throw in between the radio and amp to get signal. My DSP doesn't have an optical input as well. But the shop is going to install my horns, build speaker brackets for all 4 doors and as well was run wires to the molex connectors for me. I felt comfortable doing it in the Hyundai but not the VW. On top of that I can't find a lick of wiring diagrams for this car, another can of worms to deal with as well.
  12. jcarter1885
    Some wire clamp downs, wiring still isn't permanent. I have to take her to a shop to get the DSP hooked up to the factory amplifier. Once that is done, then all the wiring will get done properly.
  13. jcarter1885
    Thanks man, I appreciate it. Mids will be bridged on my Audio Control LC6.1200, it does 400watts @ 4ohms bridged. Mids are 8 ohms. Bandwidth will be about 80hz - 1200 or 1500hz. I haven't decided all that yet but that's a starting point.
  14. jcarter1885
    Thank you Randal, I appreciate it.
  15. jcarter1885
    New and Checking in!
    Hit the three bar icon on the top right of this page. Select Account tab and then select Profile tab. On your profile you will see a pencil icon and image icon next to your profile image, either of those should work.
  16. jcarter1885
    Newbie signing in
    and can't wait to see you what you guys do with the Jeep
  17. jcarter1885
    Until I find someone who can customize my doors when I'm ready to add the Eric Stevens MB8s, I ordered some 6.5”s. These Faital Pro 6PR160s are just beautiful and made with quality parts. The build quality is immaculate
  18. jcarter1885
    Sub wire is mounted to the top of the inside of the enclosure for a cleaner look, I also moved the jumper wires around so they won't be visible in the Plexi Glass window. Sub is wired up and screwed down.
  19. jcarter1885
    Sub not wired or screwed down but I had to tease myself some.
  20. jcarter1885
    I used the drill battery to run the LEDs to see what they can do. 20210908_235534.mp4
  21. jcarter1885
    Playing with the LEDs while I get the wires attached to the enclosure and holes sealed up.
  22. jcarter1885
    Close up on the Plexi window and the LED strip.
  23. jcarter1885
    Some daytime shots
  24. jcarter1885
    Thanks Aaron I appreciate that.
  25. jcarter1885
    Just got back from picking up this beautiful enclosure, plexi glass etched with Fi and a hidden LED strip. I'll get daytime shots in the morning
