c@raudi0
Members-
44 -
Content Type
Profiles
Forums
Gallery
Everything posted by c@raudi0
I know the SQ of the Fi Q 12" is good. but will it still bump good in a 2^3 foot box off of 1200 rms???
Right now i have a RE SE 12" running off of a hifonics 1206d at 2 ohms in a 2 cubic foot box ported at 32 hz. basically i was just thinking about swapping out the RE SE for the Q.... but running the Q at 1 ohm off my amp
Better is subjective, louder is not. Even on 1watt the BTL will be the loudest sub that Fi makes. By a bunch. If that is what is better to you, by all means get it. On the same note if that is your goal, definitely not the Q. i think i'm gonna try'n save some money and go with a loaded SSD...... cuz i want to get some good component speakers too. thanks for all the help guys
I have a 2 cubic foot box ported at 32 hz, and a hifonics amp that puts out "1200" rms at 1 ohm. Would a BTL run ok with this setup???
More SQ with the Q that I know of, if your worried about output then Q is not for you. If SQ is your goal then the subwoofer should be the last thing your worried about. I cant really comment on which would have better output, but you should be comparing the SSD's and BL's in your case. Know if you want a good sounding woofer than anyone that FI makes will fit the bill, hope that helps. ok thanks. i'll probably go with the SSD with bp power option and flatwind coil. i just want a good daily subwoofer with good sq, but will still bump really good. thanks for all the help
so what is better between a stock Q and a loaded SSD? SPL and SQ wise?
hahaha ok thanks
so will the ssd with the bp power and flatwind coil be able to handle running off of 1200 rms ok?
well i dont think i'm gonna go with the BTL because of just th money issue..... so would a SSD with the BP power option and the flatwind coil option be a significant upgrade to what i have right now? which is a RE SE running off of my amp at 2 ohms. so i'd be running the SSD with the BP power option at 1 ohm. and what exactly does the flatwind coil option do?
yeah it says march 1st, but that was 2 days ago and its not up lol
lol nooooo. i just want to see what they updated about it lmao. don't woryyy
ok thanks. Does anyone know when they will be putting the updated Q back into the lineup?
so the BTL would be better than the Q or the BL? even though the power i am running would be more geared towards a Q or a BL? i was originally planning on getting a Q or a BL, but i want "the best" haha. but i dont want to have to upgrade my amp quite yet, so i was just wondering if this would be better than going with a Q or BL... thanks guys
I now have a re se 12" running off of a hifonics amp that is putting 900rms at 2 ohms to the sub, in a 2 cubic foot enclosure ported at 32hz. would it be a sufficient upgrade to get a Fi Q 12", and put it in the same box with the same amp? i would run the amp at 1 ohm. it's 1 ohm stable at 1200rms. and both subs are within the specifications of the box. ups and downs of this upgrade? very noticable difference because of xmax? (RE=18mm, Q=27mm)
Best Deck For System
c@raudi0 replied to Hell-Razor's topic in Amplifiers / Head Units / Processors / Electrical
anything ALPINE -
how would 1 12" ib3 sound running off of a kicker zx500.1 in a ported 2 cubic foot box at 32hz?
What is the best amp i could get for the Fi Q at a 2ohm load for about 250 dollars?
running 900rms to it, should i get the bp power option? should i get it just in case i ever run more power to it?
ok....anything have anything helpful to say??? lol
what do you think would be the best amp at a 2ohm load to power this sub for about 250 dollars?
well i thought at first that if i got the BP option, then 900 would be underpowerring. but since its just cooling i should be fine
ok i just didnt know. because i was thinking that since i was already underpowerring at 900rms, then i got the BP option then it would be even more underpowerring. but if it just keeps it cool then why not get it for free right? lol
ok well for now im running 900rms to it, but eventually i want to upgrade to the Power Acoustik BAMF4000/1D, which puts out 1700rms at 2ohms. i dont know if it "actually" puts out 1700 at 2ohms, it might be more like 1400. but with that amp u think i will need it?
lol its grey, why does that matter? i just want to know what the BP power option is, and if i need it running 900 rms to the Fi Q. just in case i ever put more power to it or whatever
Which is better? what are the good and bad points of each? can one handle more power? does one sound better? whats the deal? lol
