Jay-C76
SSA Regular
    1,314
  • Days Won
    26
Everything posted by Jay-C76
  1. Jay-C76
    Utah Bass and Vape 3x show 6/10/17
    Everyone I show your vids to says the same thing......... "Holly Duck!"
  2. Jay-C76
    Welcome to the IHoP v.2
    been over a month for me now and my S8 has really grown on me. Best phone I have seen out so far to date.
  3. Jay-C76
    A few of my pics
    Amazing skills!
  4. Thanks guys for the compliments!
  5. Hope to get these done soon so I can put up a video of these for y'all!
  6. Test fit on the tweets. I have to say these things are stout! Very well designed & assembled. I am very impressed by the build quality on these tweets.
  7. Have to still add some filler for the imperfections before painting.
  8. I used to have 15" earthquakes back in the mid 90's, they totally sounded like dookie in a sealed enclosure. It wasn't until I went ported with the enclosure that I had a major improvement. It was like I put new subs in.
  9. Jay-C76
    Happy 40th Birthday Aaron Clinton!
    HAPPY BIRTHDAY!
  10. Jay-C76
    Ssa tweets?
  11. Jay-C76
    Help with 2008 F250 subwoofer wiring
    Your power wire will be the constant... Ground will be grounded... The swiched power or remote wire will be from the head unit and is typically blue or blue/white stripe (aftermarket) or labeled as an accessory (acc) switchable wire commonly traced on a diagram to either another piece of equipment or a switch. Simple answer, no it would now be wise to splice in an aftermarket amp to run off the factory wire harness. Mechanically inclined was used loosely in responses by the reactions you gave to people trying to help.....
  12. Jay-C76
    haynes manual should have the wire scheme in the back of the book if you are trying to trace color
  13. Jay-C76
    2001 Civic SDA3 12's 8k
    Poor woofer design...
  14. Jay-C76
    2016 Mazdarati Hatch
  15. Jay-C76
    Introduction
    Just out of my experience, the design you have on the port has yielded you a very poor output. With the numbers you put up & equipment, you cou do far better with a simple redesign of your enclosure. The port design is killing your output. With a dual common chamber you should never increase then decrease port area as you have done in the design. Modeling the design with such a dramatic change in the flow on the port is next to impossible to accurately model. You should keep the port equal throughout in the design and you will put up higher numbers on output. I managed going from 146 up to a 150 on 2-15" Icon (3500rms @ 32hz) just by redesigning and testing about 6 different enclosure designs. Change the internal net volume and port volumes, then adjust tuning to accommodate you vehicle peak. After that, model the enclosure to find a comfortable preference on the tuning to accommodate your response graph.
  16. Jay-C76
    Ideas for my System
    Thought exactly the same thing when I uncorked mine years ago. One of the most accurate subs I have ever heard. Nice choice!
  17. Jay-C76
    Yukonvict XL overhaul!
    Braced up! Overkill is good! Get that f/g started now David!!! Maybe next year they'll be done building the subs! Lol
  18. Jay-C76
    Another tease pic!
  19. Jay-C76
    2002 Ford F-150 Super Crew
    If it helps, this is a great resource that I use on you tube... He has a large amount of vids for Fords & used to be a ford tech. Sorry for the kinda wacked link but you can find his stuff on YouTube.
  20. Jay-C76
    That looks like it's ready for a t.v. promo! Can't get over that shine!
  21. Jay-C76
    Amazing! Wish this had it's own thread. There's a ton of info & pics that are mind blowing.
  22. This may sound weird.... Is it a whine that increases with engine rpm, hum that is steady or wave pulse, or pop sound when it happens?
  23. You have resistance build somewhere in a ground. If nothing has changed and you haven't recently added anything to the mix, I would check all of your ground connections. They can loosen from vibration or become bad from corrosion, especially when left bare and exposed to weather.
  24. Jay-C76
    What is the name of that cleaner? It seems to work like a champ!
  25. Jay-C76
    Aero port idea
    What is the definition of safe sex in michigan? Placing signs on animals that kick....
