706 -
Days Won
2
Content Type
Profiles
Forums
Gallery
Everything posted by kirill007
by just putting it in the trunk it fits. It's a tline if i haven't told that before.
Some flex video's from a kid i made this enclosure for. (10 inch sub) It's on 100W (not clamped.)
1 pic of it in testing stage (well i have the whole build..) And i'll try to find a sub picture. It's a cerwin vega, underrated with 300W or something? (i've had more then 600W going thru it and it playing fine for over 2 minutes at 27-28 hz.although it was A/B class at 4 ohm) EDIT: sorry for the big pictures.
The piece of plastic/metal that holds that big gray thing up. (i don't know how to call it) And he uses a older style Panasonic lumix or something you can only buy the new one which is HD. This shows that you don't need thousands of watts to be 'loud'.
Soundstream XXX blown...again ! Why ?
kirill007 replied to Notorious97200's topic in Subwoofers / Speakers
Could also be the amp shooting DC up the coils.. -
Those aren't accurate enough. You need the thickness of the coil, the exact inner and outer ID.(keyword is exact) Heigh is something you already have. And maybe also measure inner and outer ID of the gap.
The closer you get to the max output the more distortion is created. true, so let him run it at 1500w at 1 ohm and tune it to 1500w with a dmm.(i don't know how you set gains.)
Lol these comments are funny. Haters unite.. Looks like everyone starts bashing SMD because the person that got "kicked"(i'll continue on this a bit later) is butthurt and says the wrong reason. He got "kicked" becasause he didn't listen to the mods. A mod called LT. Smoke said to stop these kind of comments and if those kind of comments will occur repurcussions(sp?) will follow. So guess what Elrey did.. indeed he posten the same kind of comment which the mod said not to post. He ignored the mod. And it's probably not the first time he ignores mods, or else they wouldn't do it. He got kicked,not banned. It probably for a few days and then it's over. Be a man and just do something else in meanwhile, don't go on other forums talking bad about WHOLE SMD. (to the person that said if you don't have DC you are not good, well today it's DC tommorow it's something else. But the people who say DC FTW or other brands like that are most of the time kids that don't know anything. All sites have these kind of people.) So 98GMC, he didn't get banned. And that wasn't the reason. The reason was not listening to mods when they warn people and go against them. Mods are like cops, go against them and you get punished. You have mods who are strict, and mods who are less strict. Sometimes they have a bad day and can come over like a a***at because they are just people and we don't know their story.)
fiberglass resin on subwoofer box question
kirill007 replied to irvin productionz's topic in SPL & SQ / Fabrication
Use fiberglass and resin. Not just resin. -
Fiberglass adds strenght and seals it up. But the titebond(=woodglue) should already seal it up and the bond is stronger then the MDF itself. Liquidnails doesn't has that strong of a bond. EDIt: you kind of didn't take the time to do it right. Have you sanded down the resin?
WHy is this under general? It has to be under offtopic... And here you go: HaHaHa. Enough laughs?
M5, some people have totally different goals then you. They just want the max out of their amp at run it under a rated ohm load and want that last watt out of the amp or they feel like they haven't done enough effort to make it sound loud.
The LMS will play lower then the xcon in perfect conditions, but it will handle less power.
Lol at the comments in this thread. The T2 is a good sub, but not made for SPL at all. It doesn't even has a aluminium cone anymore It has a good buildquality so it's not a POS at all. But the BTL is better for his goals. EDIT: Jack3d SPL The info you got is very wrong. THey don't need a lot of attention, as much as any other sub.
Lupo GTI Build Log - Ascendant Audio, SPL Dynamics, XS Power
kirill007 replied to BILTD's topic in Ascendant Audio
BILTD i have a question. Do you use the silentcoat 2mm or 4mm? Did you get better results with silent coat or second skin? (i mean less loud on the outside, less flex,..) -
Nice craftsmanship. -
New Amp, Not as Loud
kirill007 replied to whatmh5's topic in Amplifiers / Head Units / Processors / Electrical
I'd expect it less loud. The audiopipe is rated at 1 ohm. the MTX amp is better quality and puts out more at 2 ohm. -
Neo is not happening for the SSD. It would have to be priced in the N2 range...and it is not adding that much performance, it is still an SSD. Neo isn't happening for SSD? I don't know if this was said before it said on the site: "Neo SSD's are coming." Like TC wasn't already overpriced. Jesus. Depends on what you mean with overpriced.( it's quite expensive but it's a better product then most in a certain niche.) And those MSRP prices are not at how much they will get sold
Lol edouble. Don't worry 4 18's Zcon can easily do 150+. There is a car with 4 15" icons and it does over 155 at low hertz.(= lower then 35hz, but i don't know how low.)
But there are TOO many factors arent' there? I mean, If I was to build a box, tuned to 32hz, and lets say everything stays the same. Ok, if this box peaked at ohhh 38hz. So now that I know that my vehicle peaks at 38, I decide to build my box tuned to 38hz. Will my vehicles freq still peak at 38hz? He asked for peak frequency. Not cabin peak freqeuncy or resonant frequency of a car
LED is not just a gimmick. It gives a better image then normal LCD's, colors are more true and better contrast.
Team MN Loudest, the JEEP IS BACK, 2 18 btls walled!!!
kirill007 replied to antonmiller's topic in General Fi
Fi is a business, i don't think they will warrentee it. You intended to overpower it, and you did, maybe by "only" 500watts but you overpowered it.(that's just the way i see it, maybe they'll do it.) -
You overpowered them, that means no warrenty for u -
They perform excellent in sealed enclosures. If you want to use them in sealed boxes, i recommend adding the "high Qts" option. Built the box to FI specs and it's all good, just try to be in the middle or the lower side of the box size.(smaller if you don't listen to low music and want to use full 1000W or a bit more, altough i won't recommend more)
What? Learn how to write. He asked goals and max dimensions. Holy fuck, learn some slang dumb ass. No, it isn't illiterate, it's just a different writing style, dur. " :facepalm: to you. And nah shit, he asked about the sub, it's in the title moron. Dur? >< I understood the "bruh" part, but you tried to be a spelling pirate and you write those kinds of things. Thanks for bashing me..>< And like S.DeYoung said i'm from Belgium so it is possible that i don't know a few words. Try to learn to respect someone.
