4,575 -
Days Won
21
Content Type
Profiles
Forums
Gallery
Everything posted by mikel7829
Agreed!...Box first, then invest in a new amplifier the setting "tweaking" for that model is limited...
I asked what it was set at? Not to adjust.. There is only two settings...
Honestly I would look into getting a new amplifier. And maybe get the specs for your box from whoever built it for you,and maybe we will be able to help more..
What do yo have the subsonic filter setting at?
Ceaser Milan endorsed roller skates. Got a pair for my mom for Christmas a few years back. Hooked her up to her 40 lbs. mutt...holy shit... Wtf??
Yes you usually change the thickness of the loading wall, height of the port or width of port just like any other enclosure to adjust the tuning.Yes this is correct genius...And quit neggin all my post your just making yourself look like a little bitch!!Mike, please stop accusing people of "negging" your posts. Do you specifically know JayCee is doing it? Nobody pays attention to reputation points and even spam accounts can click the negative buttons. Uhh yea..Every time he logs on i get but rapped..lol..Guess you must be hitting him from the behind
- 82 replies
-2
I would not listen to some members in this thread...As they have no experience with very few products except what they google.. Even though they may have thousand's of shit post Via 'searched' on the web' with no real experience "except what he or she said" I would love to see the products this looser has! not pointing any fingers but jay-cee you are a bitch! and only post on other people's experience..lol
- 14 replies
-3
Wtf were you doin???
don't drive over 55!!! lol That's what they say. Lol It dumped 6" this morning so will be crawling home anyways. Be careful brother!!
That was a shot below the belt wasn't it?
Don't do it!!!!! I can't live without the horrible tie linky's!
seriously!! I guess i will just leave the hello kitty....I give up better than the carebears I guess..wtf
Were did you find that fuckin smiley at!!????
Yes you usually change the thickness of the loading wall, height of the port or width of port just like any other enclosure to adjust the tuning. Yes this is correct genius...And quit neggin all my post your just making yourself look like a little bitch!!
- 82 replies
-1
LOL!!!
Wtf???
They need oxygen. A pond heater would be your best bet especially if it's going to stay cold. One of those air pumps will probably work too, but it's not ideal. It's above freezing now..Only going to be like 39 here tonight i busted a good chunk out of it maybe a 1/8th of the diameter..the holes that I punched earlier was already froze back and it is like 45 here at the moment..
See!!!!!WTF is this shit????!!!!!!
I actually did like the punch classic's way back in the day...Lol With the old RF hd's
If anybody knows anything about yard ponds I need some advice I'm a newbie at this... I have a pond that is probably 2 feet deep in spots roughly 12 feet in diameter with several koi fish, some big some small about 10 in all I think..due to the arctic clipper that moved through it has a solid maybe 2 1/2 inch thick sheet of ice on top I tried to break it with no luck got a couple of maybe 2" holes in it is about it..I'm worried they may not make it but they are still alive as I seen them swim for there lives when I was beating on the ice..lol Any tips? Or will they be ok with the solid sheet of ice? thanks, michael
[NEED HELP PLEASE] JL,SUNDOWN, SPL OR SQ?
mikel7829 replied to Peter Lee's topic in Subwoofers / Speakers
With a proper "big three" you can see little to no voltage drop on a factory alt for a little over 1000rms..I ran a cadence ia9 and ia4 with a factory alt for a bit with minimum voltage drop. although I never got to see it's full potential on that project,I never replaced the factory alt with a HO...Depending of course on the factory alt specs..And the equipment.. But I would always recommend a HO alt if all possible.. The replacement alternators for his car are rated anywhere from 80amps to 120amps. 1000watt amp will draw roughly 70amps--more if you consider the amp isn't 100% efficient, less if you consider impedance. Stock alternators are designed to power the vehicle's electrical needs with little headroom. Even if it drew an average of 50amps that's a large portion of the alternator's output. --- To the OP, Capacitors won't help you. I didn't mention anything about the drivers since I haven't used either. From your post it sounds like you want a driver for output not sound quality--that's not to say it won't sound good, but SQ and "shaking the neighborhood" are polar opposites. Just about any driver sold on this site would suffice. I'm biased as I've only used Fi and SSA, but I couldn't be any happier about their products. I'm not sure how Fi's customer service is these days, but I know SSA is always top notch if that's important to you. I would measure your trunk and figure out how large of an enclosure you can fit / willing to use then depending on that select your driver(s) and size. E.g. an 18" is about half the cost of 2 12"s and the money saved could be used for another battery if needed, etc. I think "for example" the Q1-1200d draws 120 or so if I remember correctly with a "big three" you could get by like you said though with little headroom for the rest of the automobiles electrical it would definitely be pushing it at full tilt not to mention if a front stage amplifier's draw as well as I assume will be installed..also not to mention the possibilities for damage to the electrical,if all possible I would recommend a HO alt as ASAP -
I don't see anything..... I know i removed it! It was a fuckin rainbow with a unicorn
