flakko
SSA Regular-
2,661 -
Content Type
Profiles
Forums
Gallery
Everything posted by flakko
Pick my external hard drive
flakko replied to Aaron Clinton's topic in Computers / Electronics / Music / Games
i just recently picked up a 500gb maxtor...loud as heck. -
wacha can do is get a internal 320 gig kit, and get an external enclosure. im really diggin this: http://www.newegg.com/Product/Product.aspx...N82E16817119215 http://www.upgrade-solution.com/detail.cfm...785&add=yes - 3 yr warranty -
I hath submitted the order yesterday...should be shipped out monday or tuesday!
ooh those brushed alum ones are teh SEX
ive tried 2 cubes sealed, 2 cubes tuned to 30 hz (too little port area), and 1.6 cubes tuned to 32 hz (too little port area) i like 1.6 to 32 the best
yah? yah. hehe welcome to the forums
are you looking at other options as welll? check here: http://bensbargains.net/category/37 500gig for 120 - 20 MIR = 100 shipped http://www.buy.com/retail/product.asp?sku=205844199 -
Jeremy, What about my amp? I still haven't received a response about a replacement for mine that I sent in well over a month ago. I have sent 2 PMs about it. im workin on it. its dropped off today.
well in general, at 8 ohms just half the rating it does at 4 ohms. thats the closest guestimate i can give you. i dont have any benched specs. at 6 ohms quarter it? not too sure about that one.
I concur. Never let me meet her. was that a demand, or an exclamation?
you got a pm. i hope you will be satisfied edit: also i would like to add, that this is not about the SSA store. It's all me my bad guys.
pm responded
Greg hasn't answered my e-mails...Need an answer fast!!!!Help!!!! CALL CALL CALL!
well in terms of the class D's....greg just told me that they use the same circuitry as each other. as for the A/B amps, they are totally redesigned, the USacoustics redesign was scrapped, and are now lookin like the old Florida amps. i guess the only difference is the AX line is infinitely strappable. so yea thats GREAT news to hear im thinkin i might go all merlins next.
i have an MTX 8500 sitting in my garage collecting dust, dude said it was working fine but it came frozen. is it possible for you guys at Fi to recone this thing with your soft parts?
with mlt you can strap 4 or as many amps as you want together, HOWEVER, I, never strapping an amp before, i would give greg@usamps a ring to see if you can run them at .25 ohms as well as how to do it. 877 AMP 9360 or his cell 626 833 2177
250w for the mids sounds like a little much...i mean 500w to drive just the mids? or am i mistaken.
because RE switched their focus to the B&M dealers. it's where the money's at.
alright, the md3 will put out 2kw with a 1 ohm resistive load (usually what dirk tests amps with) and it is with the 07 model...im sure the 05-06 will put out the same as well. and the damping factor is 100 at 4 ohms.
Where is SS located and thinking about gettin one
flakko replied to donpisto's topic in SoundSplinter
Mike lives in La Canada...rich punk -
I found this very interesting and decided to post it here to save yall precious clicking time. I probably understood like 65% of the material, but get the basic idea. All of this info is taken from here : http://www.diymobileaudio.com/forum/showth...ht=coustic+xm-6 Mod edit: Thank you to MiniVanMan from DIYMA for putting this together. "There have been a lot of questions of late on the differences between active and passive crossovers. I'm sure with the influx of people on this board there's some confusion over what's what when crossovers are mentioned and how they're employed. So, while this is in no way a comprehensive tutorial on crossovers, it's a beginning. Especially for those just cutting their teeth on audio. Feel free to add, as hopefully this will grow, and feel free to correct me for anything I've said. Okay, as promised here goes. CROSSOVERS!!!! First, this whole topic can be confusing in the respect that there is so much debate on this subject. Some guys swear by 24 db Linkwitz-Riley filters, while another guy can write an entire doctoral thesis for his PhD on how the 6 db Norman Bates filter is superior. So what does it all mean, 6 db, 24 db, Linkwitz-Riley, Butterworth, L-Pad, Zobel, blah, blah, blah, blah, blah.....????????? Let's start simple. High Pass, Low Pass and Band Pass. I just need to mention this just to be sure everybody stays on the same page, and even understands the very, very, very, very, very, basics. High Pass means only frequencies above the crossover point, or sometimes referred to as the cutoff frequency, are played. For example, a 2000 hz high pass will only play frequencies above 2000 hz. Low Pass means only frequencies below the crossover point are played. For example, a 2000 hz low pass means only frequencies below 2000 hz will be played. BandPass plays frequencies between two points by utilizing both a high pass and low pass in the same filter network. So, for example you could have a midrange driver only playing 200 hz to 4000 hz. ***** Note - Before everybody and their grandmothers jump on me, let me cover myself. Because I say that a high pass will only play frequencies above a certain point, does not mean I don't understand that the frequencies below that point are still played, just cut me some slack. I'll get to that point later. Next are slopes! Slope is the name associated with the numbers, 6 db, 12 db, 18 db, and 24 db. These are the most common, and I'm sure you've all seen them. What they actually mean, is "X" db drop off after the cutoff frequency per octave. So, to translate, let's take a 2000 hz "High Pass" I said above that a 2000 hz "High Pass" will only play frequencies above 2000 hz. That's not entirely true, as you may have gathered by my "Note" above. Okay, first you need to understand what an "Octave" is. An Octave is half, or double of a given frequency. 1000 hz to 2000 hz is an octave, as is 5000 hz to 10000 hz. So a 6 db per octave slope, cut at 2000 hz will yield a 6 db dropoff of output at 1000 hz, and 12 dbs by 500 hz, etc. Now understand that a 3 db gain is double the output, and 3 db loss is half the output. A "Low Pass" at 2000 hz using a 6 db slope would yield a 6 db drop of output by 4000 hz. Clear as mud???? Good! Why are these numbers important? Well let's take a tweeter for example. You'll toodle around on this site and see many people talk about "Fs" or "Resonant Frequency". As a general rule that we use around here, we like to say that when picking tweeters, use double the "Fs" of the tweeter to determine lowest crossover point for a 12 db slope. This is in direct conjunction with how much power you can expect your tweeter to handle. So for example we'll take a tweeter with an Fs of 1500 hz. This tells us that we can safely use this tweeter at 3000 hz with a 12 db per octave slope. Now anybody that's been around speakers knows that it's not the high frequencies that blow speakers. It's the low ones. Just look at subwoofers. You might be able to get that 10" sub to play 20 hz, but you might start hearing some nasty clunky sounds when you try to get that sub to play 20 hz with double is rated power. The same can be said for a tweeter. So how do we get the tweeter to play closer to its Fs? Raise the slope of the crossover. A 24 db drop, when a 3 db drop is half the output is considerable. I'm not doing the math. You do it if you actually want to figure out how many halfs of halfs that is. Anyway, because 24 dbs is a lot more than 12 db, you can drive your tweeter closer to it's Fs. Same can be said of midbass drivers. You want your 7" midbass driver to play flat to 60 hz, but it's got an Fs of 40 hz. Well, you'd probably better use a 24 db slope. Getting muddier, and muddier, isn't it?? Now on to Linkwitz-Riley, Butterworth, etc. You'll usually see a name associated with a crossover. It's usually Linkwitz-Riley, or Butterworth, or even Bessel, or some fairly exotic ones. So, a crossover is a crossover right? WRONG!! With the case of passive crossovers, not knowing the difference can be very detrimental if you're trying to design one. Let's talk about what happens at the crossover point. We'll use our 2000 hz example again. If you have one driver playing 2000 hz, and another driver playing 2000 hz, and both are putting out the same amount of output, that would be effectively doubling the output, correct? Double the output is a 3 db gain. So, if you have one speaker playing flat to 2000 hz, and the other is playing flat to 2000 hz, then at 2000 hz, you'll have a summing of frequencies and effectively a 3 db gain in output. Maybe not so desireable, or maybe it is. Depends on the drivers and the application of the drivers. Well, this is actually the basic design behind a 12 db Butterworth crossover. It's simple and uses one crossover point to calculate the values for the components of your network. Only hitch is the 3 db gain at the crossover point. So, how do we get rid of that 3 db gain. Well, maybe by offsetting the frequencies a bit. Let's say 1850 hz for the low pass, and 2150 for the high pass (these are arbitrary numbers). Since they're not technically overlapping at this point, then the summing of the frequencies is only happening AFTER the output has started to go down. (I use calculators to determine this stuff so please don't ask me to do any math). With the right calculations, you can determine what sums will create a flat response. This is what a Linkwitz-Riley filter does. A Bessel filter will yield a 1.2 gain, and if you want to do the math, you can probably create your own filter network and apply your name to it. Then you can write a long diatribe about how great your filter that has a .82564345 db gain is, and how it will revolutionize the audio world. "Man, are you sure this is mud, it smells more like.... Now to put this all together. There are some common statements on this board. "Go active, the results are better". "I'm new to car audio, and am unsure about tuning an active setup". "Passives are way too hard to get right, you're better off going active." etc, etc, etc.... So, let's take a car application. You have a choice. That shiney new Diamond Hex set looks really sweet and you can get a great deal on it, or you can do it the hard way, and get an active crossover, some new shiney Seas drivers, and another amp. Well, with all this information you now have, please tell me how Diamond Audio knows how their components will be installed in your vehicle. Did they use a 12 db butterworth filter in their crossover? Doesn't that mean there's a 3 db gain at the crossover point. If I put these in kicks, on-axis, will that give me a nasty peak at the crossover point? If I put the midbass in the doors though, maybe the fact they're off-axis will be compensated for a bit by the butterworth design.... This is why we're advocates of active processing. It doesn't matter what kind of filter it is. As long as you can change it and experiment on the fly to get what sounds best. There's no math that needs to get things all muddled up. However, if you really want to design a passive crossover go for it. Remember home audio uses the passive with great success. Their environment, however, is MUCH more controlled than ours."
