5,839 -
Days Won
8
Content Type
Profiles
Forums
Gallery
Everything posted by bassahaulic
Right this second a single ZCON 18" powered by a DD M3a. I have a second 18" at the house soon to be installed though.
Never heard of it. Hm
At Hearts? Lol Ill be passing by soon. Ill turn it up.
Where at on Airline. I'm in Jefferson as I type lol. I live out in Central, just say BR to make it easy.
What part of Baton Rouge are you from?
Y U NO CARE WE CLOSE?!:-(
Ok, to please you. Tomorrow, ill go back to the shop. And well do it off an amplifier. Highs or sub?
Speaker wires directly out the radio. Everything set to flat or off directly as DD-1 manual says.
All my videos are recorded with a phone. None are that bad. :-P
Its not mine to open sadly.
This may, or may not have been what my friend said.
I'm not saying anything, just throwing this out there for people to draw their own conclusions.
EBay FTW!
There is a meathod to our box madness. Lol. My woofer loads well over a huge frequency range.
Valid point, considering most subwoofers can sound good, and the enclosure will be the bigger factor. You guys are like in the same swamp area right? You could show him a few things. Apparently so, I'm mobile so had to switch to "Desktop View" to see his location. But yes, we should be close.
Standard 4th order. Only issues is full power below 30Hz, and even then it has to be those weird notes. Lol. Make sense?
Are you really looking for an SQ woofer? Or just one that doesn't sound bad?
Amp question
bassahaulic replied to pitbull239's topic in Amplifiers / Head Units / Processors / Electrical
As long as your wiring is proper there should never be maintenance needed. Look into a single HUGE 4-channel. Like the Sundown SAX-200.4. Anyway, what is the equipment your running? -
Do you go around jammin stuff in the mid to low 30's? I play a good bit of Bigpimpin91 and DJSNT. Which is all low, 28Hz-38Hz.
I am tuned to 40Hz and my SSF is at 10Hz. I never have issues.
OP says he has a smaller Kicker amp correct? To make the woofer "bottom out" in a small box with low tuning like that would require SUPER low notes. Also said his gain was half way up, so why would 25/60 be full volume?
Its all from the OP. I'll go into detail when j get home. I'm mobile ATM.
There is so much fail in this thread. Wow.
I know WHY they are glowing. The bolts were not meant to have that much power pulled through them. They are meant to hold the ring terminal to the pad.
Dude....... jeez.
