bassahaulic
SSA Regular
    5,839
  • Days Won
    8
Everything posted by bassahaulic
  1. You need the wire coming form the front battery to connect to the positive on the rear battery. And a ground in the rear to go to the rear battery. You can then connect amp power/ground to the rear battery.
  2. bassahaulic
    First HD video of my van.
    Make sure to put it on 720P.
  3. bassahaulic
    In the build log. Click here for pictures.
  4. bassahaulic
    fosgate t bd 1000
    Well with a dumbass like you behind the volume knob, no they aren't that tough. You are clipping the signal which is why the T1 is messing up, if you clip the signal to an Fi it will have the same result. And the gain isn't a volume knob, it is meant to match the input voltage of the amp to the output voltage of the radio's RCA's. So more then likely, after 1/2 gain, all your doing is clipping the signal harder and harder.
  5. You need to focus on AH no CA or CCA. What ohm load are you running right now?
  6. bassahaulic
    SAX-200.4 Prototypes In
    I WANT
  7. This ^^ lol Had a friend of mine tell me yesterday that when he first sat in the van he wanted to puke lol
  8. It's a rear loaded horn designed by PWK
  9. I won't be busy tomorrow after around 2. If you want my help just have Matt text me around then. I get off at sixish. I also have your number. I might hit you up, but I'm gonna try and tweak it some myself. Is the ohm load correct?
  10. I won't be busy tomorrow after around 2. If you want my help just have Matt text me around then.
  11. Say WHA? I'm not sure where you heard this, but it is inaccurate sir. Please reference the SAZ-1000 and SAZ-1,500 as proof "true mono block amps" can have internal fusing.
  12. Seems like you just want to stay mainstream. Which is fine. I guess we all can't see the truth in it all. Your paying for a name, nothing more.
  13. Interesting. Try strapping?
  14. Are all the wires connected as they should be? I'd hater to seem redundant, but check all the speaker connections.
  15. See that V6..... it hates you all lol
  16. Didn't connect speaker wires?
  17. http://www.knukonceptz.com/productDetail.cfm?prodID=KCA0BK-50
  18. bassahaulic
    tuning 2 18s btls with round ports
    You do realize that is a 6000+ watt amp since he's running 16v right?........ How much power do you have? What do you drive? And in the video with all the hair moving those aren't Fi BL's..... They are DC LV4 XL's.
  19. bassahaulic
    is this a good box for the 12" BTL?
    Is it a pre-fab box?
  20. bassahaulic
    Sensitive Competitor Design Information
    It wasn't brute force. If it was, it would still be working at it. lol
  21. bassahaulic
    I didn't mean to upset anyone if I did. I was juts having some fun, as I think everyone else was since they all thought I couldn't do it. lol I have deleted all information I got from breaking the encryption. I sorry
  22. bassahaulic
    Are Fi Subs easy to blow?
    I've read before. "Subs are stupid, they do as they are told" And by the way Fi = AA
  23. bassahaulic
    48x SA-10s Build
    FTMFW!!!!!!!!!!!!!!!!!!
