neal00
New Members
    5
Everything posted by neal00
  1. neal00
    technical stuff
    That 's a very debatable matter, sounds like the other guy's definition of xmax is , coil length minus gap height divided by two equals xmax. Well that only works for one motor topology, long coil with short gap height. I believe the rl-i10 uses TC Sounds TC2+ motor, which is of the long coil / short gap height design. However TC does not measure xmax by that formula, their definition is 70% of BL (which in my mind is the only reasonable way to measure xmax). It would seem to me that using that method of xmax measurement could require a coil quite a bit longer than 50mm just my $.02
  2. neal00
    magnet weight
    btw...la storm 12 with ferrite magnet and honeycomb cone 44pds. la storm with neo motor and aluminum cone 31pds. Thanks Mrray for weighing them. Hmmm, 13lbs, not bad but I thought it would be more.
  3. neal00
    magnet weight
    007 Neo stills ends up being quite a bit lighter does it not? What is the weight difference on the L.A. Storm subs?
  4. neal00
    weird
    I had a weird situation once also. I made a box for two 12" Audiomobile subs in an Acura TL. The subs faced down and fired into a 3 inch slot that opened to the front of the box and it had a removable plexi rear panel, when I played it without the plexi it actually played a little deeper. Suprised the heck out of me, I thought for sure there would be massive cancellation.
  5. neal00
    Linear Motor Technology - A Reference
    I vote for a neodymium magnet, for us guys that don't like heavy subs
