89 -
Content Type
Profiles
Forums
Gallery
Everything posted by Eagle
Looks good jacob!
I did 2 4500's strapped @ 0.5ohm! each amp seen 0.25 before rise. Big diff. over 2ohm strapped I had to roll the vol. to keep the amps from clipping out. I did 10,332 watts @ 1.10 ohm and @ 11.9 volts. (only allowed 3 batterys in my class) So I say go for it! Good luck man.
where you getting 14k from? 2 Sundown 3500d's would be 7000rms not 14k smh.
I don't think jacob is taking anymore team members at this moment sorry.
looks good man!
They don't say..... "you get what you pay for" for NO reason!! And I have bought cheap 5 dollar walmart RCA's and I got Stinger Expert RCA's in there now, and there is a BIG difference!! But not on sub amps!
I run everything Stinger hands down!
Just making sure my amp will be okay without this
Eagle replied to holley2346's topic in Sundown Audio
Just put another zip tie on it and be done with it! -
Can't be sq with audiopipe! just saying! Put a Sundown 1000d on the pair of SA-8's Don't do them SA's like that!
- 21 replies
-2
finally got my loud daily driver up and running
Eagle replied to hiloracerboy84's topic in Sundown Audio
nice burp! -
MSRP is. 10'' 665.00 12'' 675.00 15'' 700.00 18'' 740.00
x2 or any specs on the 200.4 for that matter, I know your under the weather Jacob so whenever you can. Thanks. should be 440x4@1ohm stereo and 880x2@2ohm bridged.
What is the name of the shop?
NICE! Any Panda can do that! It's a Panda! lol I'd like to see you do it Put some money up and I will! I don't do it for free you know! I have own 3 crx's! trust me I know ALL ABOUT IT MAN! And I'm not saying it was easy by no means! It took time to do that number! I was just trying to be funny, because all crx's and panda's useaully start off in the 150's anyways! lol Good job man on the score I strapped 2 4500's @ 0.5ohm seen 10,332 watts at 1.10 ohm, volts dropped to 11.9
Why is that ? because your not allowed to beat the fender in the get a bigger battery under the hood! makes you wonder what other rules they broke to get the big numbers??? That is allowed... otherwise nobody would have a battery this size in a CRX under the hood. Per dB Drag Rules : 6-8i -- "The primary battery must be located in the same general area as the OEM battery location. (For example, if the OEM battery location is under the hood, the primary battery must be located under the hood as well. Aftermarket battery trays and/or custom fabricated battery brackets may be installed provided no other applicable rules are violated.)" * It is a custom fabricated "battery tray"... that is also not defined as a modification to the vehicle skin (per the following): "Modifications to the external OEM "skin" (body) of the vehicle are not permitted if the modification in question will result in a change in the vehicle's interior volume. The dBDRA defines the "skin" of the vehicle as the external shell (top, front, back, and sides) of the vehicle's OEM body that gives the vehicle its distinctive appearance. This is also the part of the vehicle that is normally painted. The underside or undercarriage of the vehicle is not considered to be a part of the OEM "skin"." "Modifications that are strictly cosmetic in nature, or that do not affect the internal volume of the vehicle are permissible. " * That part of the vehicle is the under-carriage and does not change the internal vehicle volume. I want to come play with it jacob!
You would need some spl history! And to get on team Sundown you would have to EMAIL jacob on that one.
A few items I picked up in Newton Grove NC this weekend
Eagle replied to Kickin Kia's topic in Sundown Audio
good job man! Maybe I will see you at the BraggPawn show! -
Can't see why anyone would wann rush PERFECTION.But i understand people being overly excited about your great work also.Its like a kid on X-MAS eve P.S.-I'd like to thank you for your great customer service and work. jacob is the man!
well i guess u need to get someone to make u a Moderator.....but guess until then you have to read this post here We haven't gotten any new mods in a long time, don't count on it Julian OP:Good luck in your search. I can do one for 500 plus shipping! no scratches,new heatsink!
No alum. pole plugs gary?
