4X4AUTIGER
Members-
155 -
Content Type
Profiles
Forums
Gallery
Everything posted by 4X4AUTIGER
Its not but the 12s wont fit under my back seats of my F150 so i have to go with the 10s. So how many cuft per sub would you recommend? I could go sealed and do the max of .6 cuft per sub or i could port the 10s and do at the most 1.1 cuft per sub
how many cuft per sub would be good for 2 10" ssds?
Was there a big difference between the 12 and 15?
Alright so I might have to get the 10" ssds. Would it be a big difference from the 12s? If not how big a sealed box should I run?
If you see his truck beat him down!
I have an 04 supercrew but i am getting a 2.5" Seat lift
Then i might have to go with the 10s... what would the 10s mounting depth actually be? Around 6.5"?
glad to hear that but still is it true that the SSD is actually around 7" mounting depth... thats very important because they are going underneath my rear seats
well im a member of f150online and i posted a thread about what i want to get and to see any thoughts and opinions. here yall can just read the rest... http://www.f150online.com/forums/speakers-...yall-think.html
Alright how does this setup sound? 2 12" SSDs no options and an audioque 1200D amp? the amp has been rated at around 1400 watts at 1 ohm but the SSDs are 800 rms. would it still be okay or should i find another amp? and if so what amp. around $250 please. thanks
just found out i cant port them. so any suggestions on how big of a sealed box?
oh wow then ill probably just leave them stock. but what the heck are circle ports? do they not use as much room as a regular port?
already on a low budget. i doubt i could get both of those options. what about just the copper coil? is it a big difference?
oh but should i get any options on the subs or should i just leave them stock?
i was leaning towards sealed because i heard its cleaner and tighter and they are going under my rear seats in my f150 so i doubt i would have enough room for a ported box
Okay so im going with a 12" Q with the BP option and an audioque 1200D amp. I want to port this sub around 33Hz. How big of a box should i make? I know Fi recommends anywhere from 1.8-2.5 cubic feet but what would be the best? Would it be better to go bigger than 2.5 cubic feet or should i just stay around that number? Thanks
Alright so im thinking about getting a 10" Fi Audio Q... First, should i get the BP Power? Second, i was thinking about running the Memphis M1.1100 amp or the Alpine V Power 1000 amp or the kenwood excelon 2400w amp... What are your thoughts? If you know of a better cheaper amp ill listen to any opionions
Alright so im deciding between 1 10" Ported BL with cooling and flatwind coil, 1 10" Sealed or ported Q with BP power, or 1 12" Sealed or ported SSD with BP power and either flatwind or copper coil... i will be running a Audioque 1200D amp... what should i go with? and sorry these are my only options due to mounting depth under my ford f150 back seats
How long do you think that free bp power will last? i dont plan on purchasing the sub for a couple of months
Alright well i just found out that i can fit a 12" BL or a 12" Q... So with that amp which sub would you run? And what options would you get with the sub? Price really isnt that big of a factor
Alright so im looking at getting a 12" BL but what features should i get with it? I like the cooling option but should i get the flatwind coil? I listen to country and rap/hip hop. I want some SQ but i also want some people to hear me bumping from down the street. The amp i think i will run with it will be the audioque 1200D which is RMS at 1200 watts but ive heard it is very underrated and should put out around 1400 watts. Will this be enough with the BL with the cooling or should i get the flatwind too?
ill take it. how much you selling it for? and do you have an amp with it?
Yeah but they require a ported box. so they wont fit. trust me ive already talked to alot of f150 people and they said either 10" Q or 12" SSD
Alright either want 1 10" Q with BP Power or 1 12" SSD with BP Power and either the copper or flatwind cable... How many watts should each handle and which one should i go with? I want more of an SQ setup but i also want people to hear me coming down the block when i feel like turning it up.
not much... under $500... I was looking at the sundown sae 1200D and 1000D. which one would be better?
