7,743 -
Days Won
32
Content Type
Profiles
Forums
Gallery
Everything posted by Julian
Sean this is for you.
amp for two Level 4 XL 15's
Julian replied to Lschevy's topic in Amplifiers / Head Units / Processors / Electrical
A used saz-2500 will run you About 600 refurbished from db-r.com -
Welcome to SSA
Even refurbed, those still shoot up there. I've heard good ratings from the higher powered AP series.. Such as the AP3001d. If i were to go up to the 3kw range, that was going to be one of my main choices due to it's price and feedback. I'm trying to sqeeeze a quarter out of a dime here.. leaving for college this coming summer. Need to get this install done and start saving. I'm not sure how the AP amps are, I haven't really played around with them.
I would look into a Saz-2500.. you wont hear a difference and you can get one refurb'd for a reasonable price.
X10000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
I HATE people with extremely bright headlights (The HID's).. especially on raised trucks... My car is low so i get these assholes headlights straight in my face and i hate it.. even when my windows are tinted at 20% Same here. My last Mustang was the worst as it was so low, I was even in direct line with several normal vehicles. It's even worse when they also have fog lights.
Power and ground wire
Julian replied to Kyle1141's topic in Amplifiers / Head Units / Processors / Electrical
Welding wire is the best for the price.. The kicker wire is indeed good.. but you're paying for a name and a fancy jacket -
We don't know what you're talking about.
"0g" = 1/0 2/0 = 2 1/0's in one jacket. Pronounced One OUGHT, Two OUGHT, so on and so forth -
If it's sealed.. No I'd deaden the rear deck since for most cars it's just flimsy sheet metal.
I was googling for that video nick
very carefully with a sharp razor blade cut under the the CA glue and get it off, then re apply CA glue and position it correctly
That tailpipe is looking very sensual I'd like to get to know it a bit more... that is one sexy car. Anyways i love the taste of Crown Royal Black but the next day not so much... not so much hung over but.. feeling bloated
Personally I would deaden the rear deck and make sure it's 100% sealed.
Front stage installed, possible feedback?
Julian replied to BanginGMC's topic in Amplifiers / Head Units / Processors / Electrical
It's the amplifier popping off and on. It could be your hu, this is what you can do Get a 4PDT relay (four channel system), or a 2PDT relay (stereo system), and connect it between the output of your HU and the input of your aftermarket power amplifier. Connect the coil of the relay to chassis ground and the system turn-on lead... If the pop is quicker than the relay, you can add a large value electrolytic capacitor (i.e. 4700 mfd @ 16 VDC) to the turn-on lead of your aftermarket power amplifier... And you'll have to add a 1N4001 diode, or equalivent, in series with the turn-on lead feeding your aftermarket power amplifier... This will keep the electrolytic cap from keeping the entire system active. This is what i've heard to do. http://www.davidnavone.com/cart.asp?24&cat=1 there you go. -
Signs of a bad amplifier ground?
Julian replied to ONE15ISALLINEED's topic in Amplifiers / Head Units / Processors / Electrical
Those amps don't do well on low voltage you need to get a digital volt meter and or a Stinger volt meter. :peepwall: -
Well, first off easy thing is what was your voltage at? and was it going into protect? -
It doesn't matter if I can throw a million watts at a woofer.. I'm concerned about how well it uses that power.. The hdc3 woofers' have extremely high inductance.. They're basically power hungry whores. Either way id suggest Fi.. The DC stuff is old designs from RE that Scott later improved on..
My problem with those is that they start "wearing out" when you screw them in and out after a few times. I know, you dont take out and put back your amp every day, but I try to avoid those when I need to screw something. Personal taste I guess, but they sound like a great way to stop theft. They don't wear Down unless you don't have the right tools or no patience, take it slow and try not to strip them, that will detour lots of theft, worse thing they can do is bash up your stuff, but a recone is much cheaper than a whole new woofer, same thing goes with a new HU. the torx screws are cheap and can be had in many sizes from local stores and definitely the Internet, probably something like 5-10 dollars for 100. I'd checks parts express too.
lack of a pre out?
Julian replied to smashedz28's topic in Amplifiers / Head Units / Processors / Electrical
90% of the people don't need rear fill, I had one set of comps in the front and it was Nore than enough for the back
