johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    Anyone know where i can buy these terminals?
    http://www.partsexpress.com/pe/showdetl.cf...number=091-1152
  2. johnecon2001
    tuning
    27-33Hz. Although, I'd rather have that driver sealed.
  3. johnecon2001
    Some original SD-1 12" Available
    Scottsdale John needs one of these. I'll forward this to him.
  4. johnecon2001
    Check this crazy chit out
    Drunk and fell asleep behind the wheel.. Near mexico.. And they say border control is useless.
  5. johnecon2001
    Thanks Mark!
    Another satisfied ICON user.
  6. johnecon2001
    BL
    no
  7. johnecon2001
    BL
    With a dual 2 ohm sub, your only wiring options are 1 ohm and 4 ohms currently.
  8. johnecon2001
    thinkin to step my game up
    3 Q 12's will be easier to fit in your trunk too. You're starving those BL's as it is now.
  9. johnecon2001
    HBD! Aaron
    horay for you!
  10. johnecon2001
    low watt amp
    Budget at all?
  11. johnecon2001
    electrically supporting the 40.1
    200-250A 16v alternator and 4-6 large batteries should be fine. I know Kinetic has a 16V batt, as does Powermaster and Turbostart.
  12. johnecon2001
    BL
    So which one did you end up getting?
  13. johnecon2001
    Getting louder?
    That should be a pretty big difference imo. If you had a difference of 100-200w, probably not. But you're almost doubling the power to the sub.
  14. johnecon2001
    What ohm load is the 40.1 running at?
  15. johnecon2001
    BL
    Chill son. No one was mocking you, your post didn't make any sense. So I said something. Can't help you if no one understands you. And no, the universal option doesn't let the user switch back and forth at will. It simply means the gap where the voice coil sits is larger to accomodate the D1 and the D2 coil. If you got the D2 option, it automatically comes with the universal option. The D1 gap is the tighter gap, and you must add universal to it to allow you to switch to a D2 coil if you want in the future.
  16. johnecon2001
    Battery Selection
    You can't ever have too much power... well unless you suspension can't handle the battery bank.
  17. johnecon2001
    tuning box?
    aye, what sub is it?
  18. johnecon2001
    What Options
    Here you go compadre. Right from the sticky in the technical section. http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153 A few parts still correspond to the previous gen BTL, but most of them are the same.
  19. johnecon2001
    2 X 12's and IB?
    Just make sure you seal the trunk up real good so there are no leaks where you don't want them.
  20. johnecon2001
    Diamond audio
    Moving to Amplifiers / Head Units / Processors / Electrical Since this isn't a Sundown question.
  21. johnecon2001
    customer service....
    if you're worried about glue all over the place, I would send them to Fi. A recone isn't a beginners task.
  22. johnecon2001
    subwoofer question
    How much space do you really have in the town car? Ported boxes for Dual 18's or Dual 15's are quite large.
  23. johnecon2001
    BL
    Your post makes no sense.
  24. So what was the problem with the HU then?
  25. johnecon2001
    2 Atomic APX 10s Install
    Was the one on the right the reconed one? How does it sound now?
