johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    4.0 @ 32 hz- Pair of 12" Fi Bl's
    I like your double baffle cutting technique.
  2. johnecon2001
    Ordered My Q 15 with bp option whats a good amp
    Why did you order a Dual 1? You'll need to look at Kicker amps for that power now as most are stable at 2 ohms. Shame you didn't order Dual2, then you could take advantage of this --> http://www.soundsolutionsaudio.com/forum/i...c=20977&hl= You should email Fi and see if you can change.
  3. johnecon2001
    Wait a second...
    Been here awhile lol
  4. johnecon2001
    AudioQue Amps
    Sundown has two great amps right now for insanely low pricing. You could pre-order the SAE-1200D for $350, or order the now on sale SAZ-1500D for $425.
  5. johnecon2001
    One BTL 15
    Sundown is having a sale on their SAZ-1500D's right now. $425. I'd swap that for the Rockford you have. Probably save a little.
  6. johnecon2001
    Pioneer P9
    Ebay. craigslist. etc. They're no longer made, so used is your only option.
  7. johnecon2001
    SSD 12
    The AQ amps have been blowing up left and right. Stay away.
  8. johnecon2001
    In Dash DVD head unit
    Single Din or Double Din?
  9. johnecon2001
    rms question
    Without a model number, we can't do anything for you. I sincerely doubt it was anywhere near 2000w~ though.
  10. johnecon2001
    Question on ordering a Fi sub
    I've never heard of that, nor has google... so I'd guess no. What's your amplifier budget like?
  11. johnecon2001
    4 by 6's whats good
    I believe they make Plate speakers that combine a 4"-5" mid and a tweeter. This would be much better than a 4x6.
  12. johnecon2001
    About that roof?
    My civic was always fine. But I never had any thing crazy in there.
  13. IF you intend on getting your full 2500 watts out of it, a second battery is in order. 1/0awg from the front battery to the second battery. 1/0awg to a distro. 4awg to amp.
  14. johnecon2001
    box design program for mac
    Good luck. I've been looking for that for forever. There isn't one.
  15. johnecon2001
    15" SSD?
    You're confusing DCR readings with ohm load.
  16. johnecon2001
    Few pics of my G35
    HDR looks good.
  17. johnecon2001
    Birthday ideas?
    QFT.
  18. You could measure your impedance rise and pray for the best.
  19. johnecon2001
    2 12'' SI bm's or a 15'' bl
    You seem slightly confused on your goals. The BM's are shallow mount SQ subwoofers while the BL would be considered a Ground Pounder. Just stick with the BL if you have that much space available. Do a ported box and tune to around 35-37hz.
  20. johnecon2001
    computer to tv
    PERFECT THANKS! tha VGA inpyer should be blue on the tv right.... the female in the pic. yep, the VGA input is the blue one. You'll probably have to play around with your resolution settings on that output to match the TV.
  21. johnecon2001
    Does anybody know..
    http://www.partsexpress.com/pe/pshowdetl.c...tnumber=390-804
  22. johnecon2001
    computer to tv
    Its possible you can only run two of your outputs at the same time. Also, most generic VGA cables will be male to male. Shouldn't be too hard to find one that will be long enough. Check out www.monoprice.com for cheap, well built cables.
  23. johnecon2001
    how can i get an fi dust cap?
    You only need one topic *merged*
  24. johnecon2001
    Mechman 250A alternator
    Full tilt meaning what? What about idle output?
  25. johnecon2001
    What will hit harder?
    All depends on your skill as an installer.
