johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    wiring amp to bl 18"?
    Please read our gain setting tutorial for tips on how to set your amp up correctly. http://www.soundsolutionsaudio.com/forum/i...c=3704&st=0
  2. johnecon2001
    vedanta temple in montecito hills
    Tripod sir. Canon's have great white balances, if you can, shoot in RAW format so you can mess with the files later.
  3. Be bored on new topics then. Not 6 month old ones.
  4. johnecon2001
    Looking for something new/ changeup
    I'll say it again (although saying it in two threads is silly).. if you want even sound you need to go sealed. Another thing you said is that you're not hitting the higher notes (up to 60hz). This is midbass territory. Time to upgrade your front stage to fill in the frequency gaps.
  5. johnecon2001
    upcoming spl competition help
    Honestly.. the thing that's hurting you the most is not knowing your resonant frequency of your car and tuning close to it. 31hz is going to be hard to get good numbers on.
  6. johnecon2001
    sq design
    Well certain subs do better in certain enclosures. I'd say 7 times out of 10, the ported will be louder though. It is a little hard to generalize seeing as there are so many variables to consider. You could always sell the 15" Q and go with a couple of 10" Q's or ICON's.
  7. Tubes in car audio... lol. I'd expect them to either not last long due to vibration, or to need constant recalibration. Specifically in class A amps.
  8. johnecon2001
    Opinions On Two Tens
    One 1500D? I'd say the Q's as well, but I would lean more towards fully loaded SSD's. But this all is moot, we need to know what you listen too and what your front stage consists of.
  9. johnecon2001
    Kicker 12" L5 hatchback enclosure
    Did you make that red guide? I've been wondering how people cut square holes..
  10. johnecon2001
    head unit suggestions
    Hate to break it to you chief... but you'll need to increase your budget if you want a screen. $500 is enough to buy used or a cheapy brand (which will only lead to failure in the future). Plan on around $700 for a quality unit.
  11. johnecon2001
    sq design
    If you want even sound reproduction, you should consider switching to a sealed enclosure. The Q flourishes in both types, but sounds far better in the sealed environment.
  12. johnecon2001
    Looks like a good spot for pictures. You should head up there at dawn/dusk and see what you can capture.
  13. johnecon2001
    Thanks Trevor:p
    Indeed, all will be forgiven if I receive a PM.
  14. johnecon2001
    Need help with set-up ideas
    I still say to go with the BL. You don't seem like you have enough experience to try and undertake the larger system.
  15. johnecon2001
    With only $1500.. I think your plans are a little lofty. While the BTL is a superb woofer that does indeed get loud off of 3kW... the money you'll need to spend in upgrading electrical alone will leave you with next to nothing for the actual woofer, amp and enclosure. I realize you want to be insanely loud, but a proper enclosure with a proper support system will be much better than doing it half assed. I'd drop down to a BL. Stick to a 15" since you don't have the room for an 18" (the enclosure will be smaller, and cheaper to build). Buy a single 1500w amp (Sundown SAZ-1500D perhaps). Spend whatever you have left on 1/0awg wire and a spare battery.
  16. johnecon2001
    Thanks Trevor:p
    psh, you're not supposed to ask for permission. Simply ask for forgiveness later B&
  17. johnecon2001
    Thanks Trevor:p
    Allow me to be the first to say... Pics or Banned.
  18. johnecon2001
    I need some opinions
    yep, I read it twice. You used no punctuation.
  19. johnecon2001
    ARC KAR MINI
    Didn't Ryan buy one?
  20. johnecon2001
    R.I.P. S10 BLAZER
    Please tell me he took everything out... even the alternator.
  21. The Big 3 and a better battery certainly won't hurt you. That amp will be a great match to the Q.
  22. johnecon2001
    SQ System specs
    I don't understand what you mean by "run 2-way active" I have done the front doors only till now. what is "IB configuration"? Active speakers refers to not using the typical passive crossover in off the shelf component speakers. You instead use a crossever before the amplification and then send one amp channel to each speaker. IB is Infinite Baffle. Usually requiring less power but using your entire trunk as the enclosure.
  23. johnecon2001
    My VW R32
    That's just a popular photography trick. two pictures, one with hood closed, one with it open. Then go to work with photoshop and blend the two.
  24. johnecon2001
    SQ System specs
    Drop the Coaxials. Pick up a set of separates, run 2-way active. Don't do anything with the rears. Deaden the entire car. Use one sub in a sealed or IB configuration.
  25. johnecon2001
    Trying to decide
    DON'T do this unless you have the correct processing to run a 3-way Front stage.
