johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    rammat
    lol, no point in deadening anything at all then if you're going to be that lazy. Either do it right, or don't even do it.
  2. johnecon2001
    Need advice on OEM Subwoofer hookup
    Just use one.
  3. johnecon2001
    so the Fiance bought a car...
    U bastard. That looks fun.
  4. johnecon2001
    BUHH
    1) EVERYONE IS OUT OF TOWN FOR THE HOLIDAYS 2) THE "VIEW NEW POSTS" FEATURE IS BROKEN Apparently this is fixed now, yay! 3) Stop typing in caps lock.
  5. johnecon2001
    BTL Recone...D1 to D2
    Unless your BTL has the Universal option, you're stuck with 1 ohm recones.
  6. johnecon2001
    bl but with what options?
    Check here http://www.db-r.com/sell/store/index.php?categoryID=92 Looks like he's out of 1500D's at the moment, but the 1200D would be a contender too.
  7. johnecon2001
    Thinking about buying some subs...
    Budget?
  8. johnecon2001
    What frequency?
    The noise you typically hear coming from a kickdrum that you feel in your chest isn't coming from your subs. It comes from your midbass. Sounds like it's time to re-evaluate your front stage.
  9. johnecon2001
    question about strapping
    You're going about it the right way. When you strap two amps, you combine their lowest operating load (SAZ3kD is 1 ohm) for a final load. In this case 2 ohms. When you get two subs wire them like this: Welcome to SSA
  10. johnecon2001
    Fi BL OHM Load
    Like so
  11. johnecon2001
    SSD vs Q
    That amp is too powerful for either sub singularly. You could run two, but make sure you have the space for them. I'd get the SSD with Flatwind coil and BP power. Get the DVC1 option to run two of them, or get the DVC2 option to run one (wire it to 4 ohms). BEWARE though, that amp is double the power that subwoofer can handle if you run one. Box tools are here http://www.soundsolutionsaudio.com/product...sure_tools.html
  12. johnecon2001
    Add Cooling, Flatwind, Daily and Universal. Should be all you need. Extreme Lead too if you have the spare $5.
  13. johnecon2001
    Bump will depend on a lot of factors. Most importantly, the box. We can't recommend another amp to you, until you provide us with a budget.
  14. johnecon2001
    15.3volt alternator
    He wants to use the 1700w and the 3kW together on the same woofers? I hope you tell him differently. I hope that wasn't your idea.
  15. johnecon2001
    Power master D3100's $280 shipped BNIB
    They also suck at returns or any type of customer service. You ever buy something from there, hope to god you don't have a problem with it.
  16. You're not looking for good sound. You're looking for something that will keep up with your wall. Start looking into pro audio drivers and horns. Check out the manufacturer "Selenium" as well.
  17. johnecon2001
    Want to upgrade but not sure to what??
    Do you think the Q is going to "pound harder" though? Maybe a BTL? Pound harder than a W6? Easily.
  18. johnecon2001
    2 BL 12's or 1 BTL 15....2000 watts rms
    You can't say for sure that will be better though. Mo' inches doesn't equal mo' betta'. The BTL is Fi's most efficient subwoofer. It can handle that 2kW with ease. I'm always more impressed with single subwoofer setups putting up big numbers than I am with multiple woofer setups.
  19. johnecon2001
    SSD vs Q
    They're both ment for different things. So, after that's been said, what are you looking for in a woofer. And what power and space do you have available?
  20. johnecon2001
    12 bl chamfer or cooling?
    What's your budget looking like for an amp?
  21. johnecon2001
    specs for btl
    Box recommendations are the same from the old BTL to the new.
  22. johnecon2001
    Since you already have the W6.. I'd go up to the Q. http://www.soundsolutionsaudio.com/forum/i...?showtopic=7155 Read that ^ for info on those options.
  23. johnecon2001
    Hybrid clarus dimensions help
    So have I, but this is the other way around.
  24. johnecon2001
    phoenix gold rsd 1200.1
    That amp will be fine with the BL.
  25. Everywhere i have looked has that rms rating though, ebay and stores. The reality still holds though. The only Crunch amp that has been independently tested to do rated power is the Ground Pounder 3000 series.
