johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    amp help for an fi Q
    You know the drill. Start with budget and goals.
  2. johnecon2001
    12" SSD
    They're circle.. instead of square.
  3. johnecon2001
    12" SSD
    Copper coil will help with the sound quality and actually drop power handling a bit. Which is counter active to what I was saying earlier.
  4. johnecon2001
    i dont know what to do
    read this http://www.soundsolutionsaudio.com/forum/i...?showtopic=3704 It's stickied right above your post
  5. johnecon2001
    300C Bagged on 24s, tear down and build log! Vid, P.6
    Hack job
  6. johnecon2001
    FI vs DD
    x2 +1 you beat me too it. but on a serious note didnt your mom ever teach you that everything with bigger cooling/magnet units (idfk what they really are, the big donut looking things with wire rapped around it) on the right are always better then the exact same thing just mirror'd? geez, people nowadays! no common sense. Are you referring to the Toroids?
  7. johnecon2001
    sub reccomendation
    2 cubes before port and woofer displacement is NOT enough for two woofers ported. With that space, you're pretty much limited to 2 10" woofers sealed or 1 12" ported.
  8. johnecon2001
    Wall socket'd my 12ssd thats going for recone
    Damn FiTards can't even pronounce their own company boner correctly. LOL
  9. johnecon2001
    So did you just turn the knobs to where you thought they should be? Or did you use a tutorial to set the gain properly?
  10. johnecon2001
    12" SSD
    You could add the BP Power and Flatwind coil if you want to upgrade your amp later on down the road. You'll want DVC 1ohm coils if you buy two subs.
  11. johnecon2001
    kicker subs??
    Picking up the "lows" depends on your box. What exactly is your "price range"?
  12. johnecon2001
    You'd need a clamp meter to accurately figure out how much power (in wattage) was actually going to the subs. That number you pulled off of your meter isn't the normal wattage you've grown accustomed to. Edit: ahahahah your wife sounded PISSED
  13. johnecon2001
    12" Fi SSD
    If you go with the SSD, add the Copper Coil and the BP Power options.
  14. johnecon2001
    Powerful microspeakers
    Try looking on Madisound.com. They have a very large variety of all kinds of speakers. Make sure whatever you pick is compatible with the internal amplifier though.
  15. johnecon2001
    eD19ov.2 vs. Fi Q and Bl 18s
    Bassman... finish asking your questions in a civilized manner. Or else.
  16. johnecon2001
    Diffraction, a serious issue in car audio?
    Its probably more apparent in Car audio than anywhere else, to be honest. Smaller space, you'll notice it more. Most general users won't know what it is/hear it though.
  17. johnecon2001
    BTL BOX DESIGN
    Here you go. Directly from Fi. http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153
  18. johnecon2001
    FiQ10 - questions
    Not true. You don't need to power the Q to it's thermal limit for it to sound good. 600w/sub will be more than enough. You'll want the DVC 1 ohm subs though..
  19. johnecon2001
    SPL 12s
  20. johnecon2001
    Stealth SSD 10 install in my BMW
    If you want even sound, then yes sealing the box would be the best option
  21. johnecon2001
    10 inch Fi Q series box designs
    Look right above your post in the sticky section
  22. johnecon2001
    Get the Q, the BP power is free on it right now. If you don't like it, it'll be easy to sell and then you can buy the BL. Seriously... it'll be more than enough volume in the recommended box and it'll sound great. Just follow the recommended specs that Fi has laid out.
  23. johnecon2001
    Anyway to identify a fully loaded btl???
    Unless you can see the bare motor... no.
