johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. You can use the Kicker KX3 http://www.kicker.com/crossovers Or this: http://store.xmfanstore.com/linedriver.html
  2. Use the same size (or larger) wire as your power wire, for your grounds.
  3. I'd rather have the Crunch GP3000D
  4. johnecon2001
    xcon or dc level 4xl
    That's just an uneducated opinion since you haven't compared both head to head yet.
  5. johnecon2001
    2 SAE-1200D
    You can't "wire" each coil. It's one ohm regardless. In the proper box, the NS should handle those amps just fine.
  6. johnecon2001
    amp questions
    The Audioque is a one channel amp. It doesn't matter what terminals you use as long as you use one positive, and one negative. Do you have your user manual for the kicker? It outlines bridging it there. You can also get it off of Kicker's site.
  7. johnecon2001
    New Setup, From Kicker to FI
    The 10-18" have the same power handling. You'll want the DVC1 option, wire it like this:
  8. johnecon2001
    15" BTL Woofer Box Question(s)
    Air displacement comes from the cone moving. You need a close space to resonate the air in.
  9. johnecon2001
    Your amp isn't too powerful for the CVX, you probably just clipped it to death with an improper setting.
  10. johnecon2001
    Why wouldn't you be able to invert mount the BTL? The only sub off the top of my head that would be difficult to invert would be the W7, but it could still be done.
  11. johnecon2001
    Speaker wire help
    That's a two wire cable..
  12. johnecon2001
    very good amp
    no i have not they are solid amps from what I have read also they make this new thing on keyboards called punctuation i highly recommend that you use it so as to not sound illiterate but its too late for that now really since youve already been made fun of in this post
  13. You can't see clipping without an Oscilloscope
  14. johnecon2001
    Fi BL electrical
    Without anymore information than what you just gave us... it's impossible to say whether you'll need to upgrade or not.
  15. johnecon2001
    question about shade 18 and 18z in general
    You should rebuild your box if you're not hitting certain notes.
  16. johnecon2001
    2003 XXX T/S Spec's
    Should be the same.
  17. johnecon2001
    RCA's... does it matter?
    Incorrect. The better your grounding system, the better luck not getting "road" (commonly referred to as Alt wine) noise.
  18. johnecon2001
    need some help on my new fi sub
    http://www.soundsolutionsaudio.com/forum/i...?showtopic=7153 Have a read.
  19. johnecon2001
    why has no one ever?
    There's a competitor that has a Chevy Express and Ascendant Audio subs powered by Sundown SAZ-3000D's
  20. johnecon2001
    XCON 18" Production Photos
    Mark doesn't have a lawn. Offer to be his cabana boy and I bet he takes you up on your offer.
  21. johnecon2001
    Icon or Xcon
    You shouldn't be looking at your subwoofer to play 70-125hz. You should be looking at your midbass speakers.
  22. johnecon2001
    ports
    You did? I couldn't tell
  23. johnecon2001
    Thumppers Ford Windstar Ground Pounder
    I think your username says it all.
  24. johnecon2001
    Head Unit on 16V?
    You'd have to check your user manual on the particular head unit you have.
