johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    Sony XM-5046
    there's one on ebay for $200 plus $20 shipping. That's a little inflated in my opinion.
  2. hm....... i might do this to my car. would a thread rod lets say 2ft long hammered 1.5ft into the ground work?? The deeper the better. Usually grounding rods are at a minimum of 4ft. You could try it though.
  3. johnecon2001
    Amp draw @ 4 ohm and 2 ohm
    1000w is going to draw more current than 600w dude. That's pretty easy to understand. Unless it's two separate amps. Then there might be a difference.
  4. johnecon2001
    Trouble finding alternator
    a 180-200a alternator should be plenty for you with room to upgrade in the future if you so decide. You should try emailing Nate at Excessive Amperage, or the nice people at Powermaster.
  5. It's just a built up charge in the frame of the car. I've seen it happen often before. If you really want to get rid of it you're going to need to discharge the car. Disconnect the battery from the car (negative and positive). Bolt a 4 gauge or thicker cable to the car. Connect the other end to a metal rod (preferably copper). Bury the rod 3/4 of the way under ground. Let the car sit over night (about 8 hours). Most of the charge should be gone, if not all of it.
  6. johnecon2001
    need 400w x 4 @ 2 ohm
    There it is. Told you I'd seen one before.
  7. johnecon2001
    Six Digital Designs 3518's 4th Order
    Woah, what will that be tuned to after the final build?
  8. johnecon2001
    I swear I've seen one. But I can't find it now.
  9. johnecon2001
    SSD18 power questins
    I really doubt if you send the SSD 1600w that i'll last very long. And I'm sure it'll void the warranty. Try the BL.
  10. johnecon2001
    order question??
    Come on guys. It's probably been quite a blur for those guys through christmas, new years and now right in the middle of CES. The Fi Shop is only so big, you'll have to be patient until they get back into town/work.
  11. johnecon2001
    Dual .7 subs (2)Saz-1500 or 3000
    1500w total or to each sub?
  12. johnecon2001
    order question??
    Do they not teach Punctuation in school anymore? Jeez..
  13. johnecon2001
    Fi BL, SSA Icon, or DD 9500??
    Only 12's atm. And the price difference is quite large between the two as well.
  14. Maybe you should have done more research on what could be done with the damage that was done to the board.
  15. johnecon2001
    LFB-2K Batterys
    He hasn't been on since the 3rd and this was his last post. I'd guess Rusty is at CES.
  16. johnecon2001
    1st Place trophy for SSA ICON's
    Depends on the tune of your box and the resonant frequency of your car, and and and and and. Too many variables. You have a good chance at 140. Execution needs to be damn near perfect though.
  17. I'm guessing (not having looked this up) that the Audio comes through the 880 via the Aux input.
  18. johnecon2001
    Which Subs to buy?
    He'll need more than just the big three if he goes with two BTL's and wants to power them to the flexing point of his car.
  19. johnecon2001
    Which Subs to buy?
    4 18's would definitely be loud with the right box, right amp and good electrical. Perhaps you should start with the supporting gear. Have you done any upgrading so far?
  20. johnecon2001
    Which subs to buy?
    one thread in one place.. is all you need.
  21. johnecon2001
    Bored with icon
    Either a sealed box or one that has an extremely low port. 29hz or so.
  22. johnecon2001
    Cool New Forum.
    Umm yeah enough of that. Don't post in this thread if all you want to do is fite. bish.
  23. johnecon2001
    Megalo Finally Finished Build(for now atleast)
    Looks great. Good job man.
  24. johnecon2001
    Bridging an SAX100.4
    The amount of power each driver gets is entirely dependent on how the manufacturer of your crossover splits the power in that passive set. I highly doubt its a 50/50 split though. Probably closer to 20/80.
  25. johnecon2001
    kinetik battery hookup ?
    you only need one thread bud. We'll delete this one
