johnecon2001
SSA Regular
    5,305
  • Days Won
    6
Everything posted by johnecon2001
  1. johnecon2001
    1 sub 149.0db
    Any voltage drop?
  2. johnecon2001
    Diving into home audio
    Nevermind, I Found it. I knew Krell had one. 7.1 processor http://www.krellonline.com/new_pdfs/kavS_1...229_053_BRO.pdf 8.4 processor http://www.krellonline.com/new_pdfs/EVO_707/0190_025_BRO.pdf
  3. johnecon2001
    I'm wondering how HDMI will be handled in the separates market. I don't know much about it, but I would assume you could swap out the processor for something HDMI-capable without changing amplification? I'm just curious because everyone I've talked to running HDMI in some form is running a receiver, which is just blah to me. There are HDMI switchers available.. but I haven't seen something that takes the video and splits it from the audio (so that the audio would go to the separates). I'm sure someone big like Krell will have or does have something that will do it eventually. I'll ask around though, I'm sure you're not the first person to question HDMI integration with separate pre-amps and Surround amplifiers.
  4. johnecon2001
    Adire Shiva MK IV (I think)
    Yeah go ahead and post a picture or two. I have one Shiva here and two DPL's, so I can compare. It sounds like a burned or frayed tinsel lead just under the spider if you can't see anything wrong above it. Having the sub free-airing it won't excurt as much as in the box. Its probably shorting the tinsel on and off when its in the box.
  5. johnecon2001
    Cranking amps test!
    Why do you need to load test your battery 30-40 times a month??
  6. johnecon2001
    SSA teaser pics of 8" driver
    Lul triple stack motor. Can we call it the MiniICON? or the MEECON?
  7. johnecon2001
    10" Q ported enclosure...
    That tuning and capacity are right in the money range of the Q10. That should sound awesome.
  8. johnecon2001
    Should I Buy 2 12" BTLs for SPL
    The BXi2607 doesn't put out anywhere near 2600w. Probably shy of 2kW as well.
  9. Cerwin Vega is a famous subwoofer maker. Meaning, they made/make good subs. Not amps.
  10. johnecon2001
    Are you positive its not the amp? Just because it has 14.4v at the leads because "you have a Cap" doesn't mean the amp isn't cutting in and out. Swap a new amp in if you can and see what happens. You should also retrace all of your connections and make sure everything is solid and connected to the right places. And finally, if you do find out the sub is bad.. I might be able to help with a replacement
  11. johnecon2001
    Finally installed my 2 ICONS!
    ^ bwahahahahaa
  12. You and your crazy boxes. They always look great tho.
  13. johnecon2001
    TC Sounds TC3k 15 install pics
    I like inverted sub installs. You win the prize.
  14. johnecon2001
    Dude, SEC.... Your car looks like its about to fall apart hahahahaha
  15. johnecon2001
    Pics**18"BTL/KX2500-no56k**
    Holy cow! Someone from CA.com that actually did more than just a HU, Amp and subs!? What is this world coming to? Looks good man, your door pods look great.
  16. I thought you were walling it off? All the suggested box sizes are listed on Fi's website.
  17. johnecon2001
    The you'll want two Sundown SAZ-3000D's if you plan on going that route. One for each BTL. Start thinking about Dual Alternators, or one HUGE one. Which batteries do you have? 4 runs of 1/0awg from the alternator to the Batteries. Then put a buss bar over the top of them in Parallel. Run the grounds from the rear batteries to the front battery with 4 more runs of 1/0awg. Pray that it's enough.
  18. johnecon2001
    lights dimming
    Ever heard of the Yellow Pages? Or Google?
  19. Ala the SSA store! Alpine PDX-4.100 Kenwood KAC-8403 Rockford Fosgate P450.4
  20. johnecon2001
    Are you competing? Or do you just want to be the loudest guy on the block? Other than amps and subs, you'll need to upgrade your electrical if you even want the system to play for decent periods of time and at a loudness you want. You'll need a High Output alternator and at least one large battery.
  21. johnecon2001
    door components
    Running new speaker wire will certainly bypass the amp As far as the speakers go, I don't have experience with either of those two.
  22. johnecon2001
    door components
    If you're getting a new amp along with the components what's the problem? Take out all the factory gear, replace with new gear. You'll need a line out converter (LOC) to go from your Head unit to the new amplifier. Oh, and it would be helpful to know what equipment you're talking about when you post in the future.
