4,457 -
Content Type
Profiles
Forums
Gallery
Everything posted by ANeonRider
Willing to bet it has a copper coil...
Umm, all I meant was you need to hook up whatever you are powering with the amp, then measure with the scope to set the gains with it.
Need the load connected to the amp to properly set gains with a scope.
Likely not set in stone until the final revision is completed. Remember people, this is the first version aka prototype.
Very nice! Your attention to detail is awesome.
Mach5ness... unless you have stuff already kicking around. Updated the build log yet again.
2003 Nissan Sentra SE-R Spec V: Project Spec-SQ
ANeonRider replied to ANeonRider's topic in Build Logs
More pics... Just need to do some finishing & adjust the gapping with the doorpanel. I have also cut a hole in the rear of the pod for it to be IB into the door as well. FYI. Finishing the door pods in black fake suede & the bottom of the doors in black vinyl. The top of the doors are already done in black vinyl from factory. -
Progress from yesterday & this morning... Tolerances are tight around the protrusion for the woofer, so it has be 'glassed from the inside. -
They do, but not sure if they are available at the moment.
Ya, he used a tuning fork & adjusted the strings to suit.
If it is a 3-way front end, you can do both. My 8" midbass is going to be running only up to 300-400Hz anyways, and likely will be diggigg down to 20Hz at times & being my subwoofer.
That's not an Infinity driver, it is a DIYMA 12. I don't see any problem with it. You may be looking at a lower output vs. your TL enclosure, but you might even be able to port the Rl-i in that space.
Received it yesterday. Good packing, can't wait to install.
No, IT DOES NOT WORK. HAVING TWO DRIVERS PLAY THE SAME FREQUENCY RANGE DOES NOT WORK.
two different subwoofer wave cancellation true??
ANeonRider replied to caddyon20s's topic in General Fi
No, IT DOES NOT WORK. HAVING TWO DIFFERENT DRIVERS PLAY THE SAME FREQUENCY RANGE DOES NOT WORK. -
Well, yes. It was quite obvious from the start. But, at least he fits in with the majority of people that fill this world.
Asshole mode, activated.
Stupid is, as stupid is. That is all. -
It's terrible, start over.
Women are going to turn me into an asshole.... maybe then I'll get some respect. Bitches.
what do you have up front?
here http://www.soundsolutionsaudio.com/shop
Don't mix & match please.
