ANeonRider
SSA Regular
    4,457
Everything posted by ANeonRider
  1. Turn it down... exceeding thermal limitations.
  2. ANeonRider
    sub positioning
    Echo echo echo echo echo echo echo. Neil (DevilDriver) has a write up on how to tune aeroports in the technical/how-to section.
  3. ANeonRider
    High Wattage Passive Components
    It is a tweeter, I barely need 25W on mine.
  4. ANeonRider
    ??? Myspace ???
    myspace sucks.
  5. ANeonRider
    is this normal.
    unserviceable. I am pretty sure Alpine's repair costs are pretty decent though. Might be a good idea if sonic doesn't warranty it, to contact Alpine directly.
  6. ANeonRider
    is this normal.
    I think it is u/s... better see how well the warranty works.
  7. ANeonRider
    is this normal.
    What protection is it going into? If you read the manual, you'll see that the power light will change to red & flash depending on the error.
  8. ANeonRider
    Box Size For IXL 18
    That "kick" is midbass, which a subwoofer has no business reproducing IMO.
  9. ANeonRider
    Box Size For IXL 18
    Nooo, didn't say that at all. You don't want to port ANY sub lower than 25Hz in car. While this sub is a very good subwoofer to port tuned very low in the home, that doesn't mean it is a good idea in car, due to cabin gain. I'd venture to guess 5-5.5ft^3 tuned to 35Hz would be fine.
  10. ANeonRider
    Bridging Minilith
    You aren't trying to bridge.. you are trying to strap them. Follow the instructions in the manual.
  11. ANeonRider
    Box Size For IXL 18
    Tuning to 20Hz in a car is pretty much pointless, might as well seal it up in the car. That's home audio territory.
  12. ANeonRider
    tech support #?
    Nope. They have this forum for that.
  13. ANeonRider
    active or not
    CA18RLY + 27TFFNC/G or whatever the silk dome pn is.
  14. ANeonRider
    Welcome to the IHoP
    Or, you can always have a small piece of MDF glassed into place & use larger washers & bolts.
  15. ANeonRider
    Welcome to the IHoP
    This winter I'm going to build some rear loaded horns with some 4" Fostex FR drivers.
  16. ANeonRider
    Looking for a good DIY woofer/midrange...
    Not bad at all, actually using 8 ohm speakers is a good thing IMO. What active crossover are you planning to use?
  17. ANeonRider
    Nextel ftw. And read the write up about efficiency in the technical section.
  18. ANeonRider
    Scott im gonna call u
    how about now
  19. ANeonRider
    Need help with slot port
    umm, port velocity, therefore causing port noise... that's why. I would not go with less than 30.
  20. You need a channel for every speaker.
  21. ANeonRider
    Welcome to the IHoP
    Sinus headache has eff'd off finally, yes!
  22. ANeonRider
    break in
    Just listen to the sub at low volume levels... if no bad sounds come from it, let it wang. No need to baby it.
  23. ANeonRider
    2 15 dual 1ohms.... i need to be at 1ohms at the amp
    dcr, sure, but unless you are running them at 0hz, that won't happen. Run them in series/parallel, which is what you described.
