ANeonRider
SSA Regular
    4,457
Everything posted by ANeonRider
  1. ANeonRider
    spl subs
    Don't buy from ebay... pm mrray13. Drop the cap and do the big 3.
  2. ANeonRider
    spl subs
    pssst, your sub isnt the reason your amp clips That last statement makes a whole lot of no sense. Power compression maybe?
  3. ANeonRider
    15 rl-p and nex box
    Nope.
  4. ANeonRider
    What type of port is better?
    Actually, aeroports will have to be ~1" longer... Never have heard of any reason to have the port not near a wall, etc, unless it is because there is not enough room left between a wall, and the opening of the port. End correction only applies to slot ports using one of the outsides of the box as one side of the port in a slotted configuration. Port area is the outside dimensions, but has no relation to the length. Length determines the port tuning. Port area of a round port is pi*r^2 Port area of a square port is WxL Round ports require less port area because of the reduced surface area of the port.
  5. ANeonRider
    More port area.
  6. ANeonRider
    Welcome to the IHoP
    Sooo glad I got out of that steaming pile when I did. Good work Steve. I wonder what would happen if everyone's posts became zero, poof.
  7. ANeonRider
    15" RL-p in a teensy car
    go sealed, using those dimensions you listed. If you mount the sub normally: 2.04ft^3 - 0.21ft^3 (driver displacement) = 1.83 ft^3 If inverted: 2.04ft^3
  8. ANeonRider
    Have to remember that ports displace space as well
  9. ANeonRider
    Those dimensions allow for a good sized box... If you use 3/4" MDF... 2.04ft^3 becfore displacements. I would go sealed.
  10. ANeonRider
    http://www.mapsexoffenders.com/
    Might be hard around there
  11. ANeonRider
    Welcome to the IHoP
    I feel like a squished bug today... had a beer night last night. I don't remember how I got home
  12. ANeonRider
    Got an odd shaped enclosure
    I dunno, but he ended up dropping the recessed area for the amp.
  13. ANeonRider
    Welcome to the IHoP
    That's never a good thing ... have fun with that <{POST_SNAPBACK}> Turned out to be the downstream 02 wiring... and since I don't need it (PCM does not read the downstream 02). Cap it and tape it, GTG. But.. while I was down there, figured out where my tranny fluid and oil and leaking from... oil pressure sending unit and tranny pan gasket. Total cost of parts = $26CDN + tranny oil.
  14. ANeonRider
    OK, Just thought of this... He has probably displaced another 0.75" of depth for the recessed area to build it So... I need a pic of how its installed Kevin
  15. ANeonRider
    That recessed area only displaces 0.132ft^3 Kent, since it will be mounted onto the 3/4" MDF to lower it 1.5" into the enclosure. For this enclosure: I already gave Kevin a length of 21.817, which will tune the enclosure to 30.5Hz @ 1.638ft^3. For other tuning frequencies: 28Hz: 27.402" (1.593ft^3) 29Hz: 24.982" (1.613ft^3) 30Hz: 22.867" (1.63ft^3) 31Hz: 20.997" (1.645ft^3) 32Hz: 19.323" (1.659ft^3)
  16. ANeonRider
    Welcome to the IHoP
    328 miles. I have nothing to do on the wkds while I am there, so I will be travelling around, seeing friends in the general area Will see.
  17. ANeonRider
    Welcome to the IHoP
    Hey Nick... I am gonna be in Cornwall, Ontario for 4 weeks in Oct/Nov... should meet up
  18. ANeonRider
    Welcome to the IHoP
    Ugh ... PITA ... hope your roommate decides to get off his ass and phone the tow truck ASAP. <{POST_SNAPBACK}> I guess he noticed I was a little rattled... got on the phone not 10 seconds after I posted that , it's home, in the garage. Fun night of wire tracing ahead. <{POST_SNAPBACK}> Found a chunk of wiring wrapped around the passenger side axle, this is going to be SOOOOOO much fun. Waiting for the sun to come back before I continue on.
  19. ANeonRider
    Welcome to the IHoP
    Is there any way we could send him a little anthrax in the mail?
  20. ANeonRider
    Welcome to the IHoP
  21. ANeonRider
    Well, could have told me... thanks.
  22. ANeonRider
    I'm still working on the design. You changed the dimensions though
  23. ANeonRider
    Welcome to the IHoP
    Car died today... short in the fuel pump/02/PCM wiring somewhere (common problem). Roommate offers to call a tow truck for me (he has coverage = free). Been waiting almost 2 hours now for him to go through with the offer... me = annoyed
  24. ANeonRider
    gogole earth + paint
  25. ANeonRider
    NEXT 10" sub..
    For both, have to remember to include displacements to the volume I listed.
