joshtazz
Members
    158
Everything posted by joshtazz
  1. joshtazz
    2-18 bl's in a sealed box?
    See if u can use aero ports to make it fit
  2. joshtazz
    do i have room....
    Sweet now I just going to need a builder im going to try my local shop but there expensive and it prob be better to get argent again cause he does awesome work
  3. joshtazz
    do i have room....
    ok so im wanting to upgrade from a 12 btl to a 15 btl..and my question is do i have enough room. i have this to work with......24 tall 42 wide 19 deep..thanks for the help
  4. joshtazz
    do i have room....
    K if I have that much would it be possible to through a 18 in
  5. joshtazz
    some help needed
    Thats for sure idk thought I had it set right never once heard or saw a sign of bottoming out but im no expert so idk jus have to send it in and get a recone.
  6. joshtazz
    some help needed
    ok so today i was on my way home and my sub just quit working. i checked the ohms for the coils and its 1.25 . i checked the wire running from the box (there wired to one ohm). So i thought that it was ok. so i then checked the voltage of the speaker wiring coming from the amp and the volts were jumping up and down. so i then hooked up a ten and it played fine. So my question is what is wrong thanks for the help. my amp is sundown audio 2000d my sub is fi btl12 MY HEADUNIT IS pioneer avic n4
  7. joshtazz
    some help needed
    neever mind found out one coil is blown
  8. joshtazz
    need some new tweeters
    No I mean I was looking and I found that I could get tweets that come with crossovers themselfs
  9. hi i currently blew my diamond audio hex tweeters and am now looking for a new set of tweets.\ i want to stay under 150. i can supply a total of 300 rms if necessary. i want ones that come with crossovers too. thanks
  10. joshtazz
  11. joshtazz
    old three stack vs 1 stack
    okay so i have an old three stack magnet btl twelve if i bought a new single stack btl 12 would it be worth it thanks.
  12. joshtazz
    no i was just going to replace it
  13. joshtazz
    Need some helkp on tweeters
    Thank you for the explanation on how they work. I figured it was something along those lines but wasn't completely sure. I must say the only time I've ever noticed them begining to light is when the volume is just shy of the shuttle launching setpoint. The strangest part is that in my van there WAS a Hifonics ZXi6006 running the components with a rated 150 watts per channel, but in a friend's car with the exact same bulbs on a Powerbass 700.5 which is only 50 watts per channel, in both vehicles the lights would only begin to light at the very top of the volume level. This has led me to believe for quite some time that they responded to distortion more than the total power running through the circuit. It could have more to do with the frequencies the passive crossover's crossed at since he does have PG RSD's where I have the Hifonics Atlas components. At any rate, I'm glad someone has the knowledge of what these really are doing in the circuit. I can't help you any with those particular tweeters, never played with them, sorry. However, on the light bulbs, it doesn't matter where they are in the wire. They could be next to the crossover, next to the tweeter, or anywhere in between. Just whatever point is easiest to install them in. I installed them so that they would be hidden up under the dash where if they did flash it wouldn't be very noticeable. The only time's I've ever blown them has been after I got my KDC-X991 HU, the volume on it has a tendency to increase or decrease at an extremely fast rate when you hold the button on the remote control. Each time the bulbs have blown was when it went from the teens to 35 in the blink of an eye. k thanks is there any u would reconend id like to sta ubder 100 without shippingand i can supply up too 400 rms if neccasary
  14. i have a pair of diamond audio s600 hex 6.5 speakers and recently the tweeters blew....i am using the supplied crossover.....i have tried to find replacement tweets but have had no luck......so my question is does any one know where i could get some or can i use a dif brand thanks.
  15. joshtazz
    k thanks for all the help....... IM REALLY LOOKING INTO A SET OF TWEETS THAT come with a crossover... are these any good...........http://cgi.ebay.com/NEW-PAIR-ROCKFORD-FOSGATE-P1T-S-1-CAR-TWEETERS-P1TS-/350373394185?cmd=ViewItem&pt=Car_Speakers&hash=item5193e1b709 and when i do the lightbulb thing does it have to be near tweeter caus ei dont have a whole lot of room to work with..
  16. So i recently bought a pioneer avic n4 and i hooked it all up and all the unit does is open up with a black screen and when car is the screen will go down...there is no illumination or nothing...although i do here the headunit making some noises....so i know its working...and i have tried a new 30 pin plug and that didnt help.
  17. ohh ya i got that i thought you were talking about on the hideaway...its f ing weird everything is connected and when i turn the key over monitor pops out and the head unit makes a little noise(i think its a fan in it) and gives me a black screen????? im stumped
  18. yes all the wiring is hooked up right i tripled checked and what do you mean a second power wire?
  19. joshtazz
    some help on upgrading
    Ok I'm so confused ha I currently have a fi btl twelve in a 2.5 encl at 32 hertz and its loud as hell...but its just not enolugh for me. So I have decided to go bigger but my confusion sets in.... So this is my question is it worth getting a 15 btl (I'm having argent audio see if they can fit a 18 in my space....if I can then I know its worth it) Also I was wondering if the q would be something to look into.......honestly I have never heard a sq sub.....thnks for the help
  20. joshtazz
    Prob all especially since if I order soon cooling is free cause there backordered
  21. joshtazz
    Ya but honestly that's mor money than I'm willing to put out another ammp two new suubs and new enclosure...
  22. joshtazz
    2002 jeep liberty
  23. joshtazz
    Yep
  24. joshtazz
    Ha well I gues a btl for sure but is the 3 inches extra worth it
  25. joshtazz
    I was going to get anither twelve but I have the older one so I couldent do that... and I was wondering about the q because I've heard it hots pretty loud .
