TLOTIS
New Members
    3
Everything posted by TLOTIS
  1. Try using a battery isolator. It will keep the engines battery separate from the audio batteries and allows the alternator to charge you audio batteries without reverse draw
  2. The DS18 pro 3k is around $300 or so. Williston Audio bench tests show it makes true power certified.
  3. I’m looking to build a ported enclosure for (6) Ampere Audio AA-2.5 6.5” D2 subs. They will be run on a 5k/1 ohm stable amp wired at a 1.33 ohm load. There will be plenty of power as they are 500 rms and 800 max. I can’t seem to get anything from Ampere Audio on the port size I need. With sub displacement my box needs to be 2.48 CF (+) port displacement. Does anyone have suggestions or know how to calculate the port size? Square inch and length is what’s needed. Hopefully someone can help on this
