39 -
Content Type
Profiles
Forums
Gallery
Everything posted by Tyrell Wilson
How Much Do You Throw At Your XCONs? (Daily)
Tyrell Wilson replied to Tyrell Wilson's topic in Subwoofers / Speakers
bahhh, sorry it came out like that...it showed a list when i copied it over. -
Thanks for the feedback. As I mentioned, I am no "bass guru" or anything like that. I come from a long line of daily setups that consisted of prefab boxes and kicker/mtx subs. This is my 1st "big boy" build so I am just trying to do it right. I will list below all of the stuff I have already ordered/received to give you guys a better idea of what I am working with and maybe you can better advise. I hope I did not waste a lot of money on my setup that was unnecessary. Unfortunately, I already purchased the 2nd 2500d recently. The good thing is that I got a deal on the 1st one for only $120 (local) in mint condition and the 2nd one was only $325 (shipped) via ebay. So all in all, $445 for 5000 wrms on tap does not seem to be to bad of a deal to me. Here is a list of everything I have picked up thus far... 1x Singer Alternator - 240A - 160A idle (260A peak) 1x Kinetic HC1200 - 40AH - 1200W 2x Kinetic HC3800 - 135AH - 3800W 2x Kolossus Fleks 0 Gauge Dual Amp Power Kit 1x 50' - Kord Ultra Flex 12 Gauge Speaker Wire 1x 50' - Kord Ultra Flex 14 Gauge Speaker Wire 4x KonFUSED 2 Way Fuse Distribution Block 1x Voltage Meter 10x Sky High Audio 1/0 Copper Lugs 1x KnuKoncetpz - Ultimate Negative Battery Terminal 1x KnuKoncetpz - Ultimate Positive Battery Terminal 8" Aeroport (trying to find flares) 6x 10' rca cables 6x 4" PC fans 2x SSA XCON D1 12" - 1750 Watts RMS each 8x Dayton Audio ND140-8 5-1/4" 8x Vifa NE25VTS-04 1" Silk Dome Tweeter 2x Orion 2500d - 2500 WRMS @ 1 ohm 2x Orion 4002 - 200 WRMS x 2 @ 2 ohm 1x PAC LC-1 Remote Amplifier Level Controller 2x 12V 5M IP65 Waterproof 300 LED Strip Light 5050 SMD 1x Clear Acrylic Plexiglass Sheet 3/4" x 23.875" x 11.875" 2xClear Acrylic Plexiglass Sheet (4002) 2x Clear Acrylic Plexiglass Sheet (2500) 1x Q Logic Honda Accord 5 1/4" Custom Speaker Kick Panel 1x Metra 95-7862 Double Din Dash Kit 1x Pioneer AVH-X4700BS Let me know if you all have any other questions or recommendations. -
Port flares for sale, 8" and 10" diameter pipe
Tyrell Wilson replied to Adrian_D's topic in For Sale/Wanted
Hey Adrian, If these are still available I would be interested in picking up a set of 8" ports. Can you please shoot me a email as I am not that active on this forum since i am member of several others as well. I can be reached at [email protected] Thanks and I look forward to hearing from you. -
He knows what he is doing and no it is not made up. He does multiple "high profile" builds all of the time and has been doing this stuff for years and competes regularly. I am just looking to get a 2nd opinion on my particular setup. -
Also, I am sorry but this is not my daily vehicle at all. This is going in my "show" car that I only drive during the summer on nice weekends and occasionally on road trips to shows. -
I think it may be "wiser" since I am not as experience as most to just wire each sub in series at a 2 ohm load and push 1700 rms to each. That is still a shit ton of power and should be plenty loud. -
how did you manage that? Sealed box so I never smelled the coil smoking and I wasn't paying attention. Was clipping the hell out of the signal. Yikes! -
Well, I originally had just 1 2500d but the person whom is helping me with the install said that I should get another. He informed me that is better to have more power on tap than is needed and typically better to have double the power that is needed for the subs in any particular amp so that the amp does not have to work as hard. I personally don't care what they are ran at as long as it is loud and clean (I think he advised running them down at .5 b/c thats the only way i could wire them in which each amp would support.) I think i can also wire each sub to each amp at 2 ohms as well (which is 1700wrms). They are going in my 2006 Honda Accord EXL Coupe v6 We are planning on building a box that is around 5 cu ft w/ a 8" aero port Electrical: Under hood - Kinetik 1200 (40ah) Big 3 (All 0 Gauge OFC - 400 amp fuse) Singer 240 Amp HO Alt 2 Runs of 0 Gauge OFC + Back - 2 Kinetik 3800 (270ah) fyi - also running 16 speakers (8 mids, 8 tweets) off of 2 Orion 4002 amps Hope that helps to clarify a few things. Now we are getting somewhere. Electrical seems pretty decent for what you would like to run. Building a box on the larger side of the recommended size would allow you to use one amp and still let the subs stretch their legs. Both amps at half ohm would be hard on the alt and batteries and probably a little silly, but that's just me. Could i potentially make the box smaller if I ran both amps? The box will be in the trunk and forward facing (i would prefer to make it smaller if possible to keep room for a spare tire) -
I personally would not mind if I could just push 1700 rms to each sub...I don't necessarily care about it being that loud (i just like nice hard hitting bass) but also like SQ as well. I tested just 1 2500d on 2 orions xcon's and it was plenty loud enough for me but my friend pushed getting the 2nd 1 so i did. He told me that you also have to account for box rise, etc. -
how did you manage that? -
Well, I originally had just 1 2500d but the person whom is helping me with the install said that I should get another. He informed me that is better to have more power on tap than is needed and typically better to have double the power that is needed for the subs in any particular amp so that the amp does not have to work as hard. I personally don't care what they are ran at as long as it is loud and clean (I think he advised running them down at .5 b/c thats the only way i could wire them in which each amp would support.) I think i can also wire each sub to each amp at 2 ohms as well (which is 1700wrms). They are going in my 2006 Honda Accord EXL Coupe v6 We are planning on building a box that is around 5 cu ft w/ a 8" aero port Electrical: Under hood - Kinetik 1200 (40ah) Big 3 (All 0 Gauge OFC - 400 amp fuse) Singer 240 Amp HO Alt 2 Runs of 0 Gauge OFC + Back - 2 Kinetik 3800 (270ah) fyi - also running 16 speakers (8 mids, 8 tweets) off of 2 Orion 4002 amps Hope that helps to clarify a few things. -
Did you ever end up selling this amp?
CRESCENDO BC3500D / XS POWER XP3000 / 2/0 FUSED WELDING WIRE
Tyrell Wilson replied to DedicatedEnthusiast's topic in For Sale/Wanted
Do you still have the battery? fyi - easiest to reach me at [email protected] as I do not frequent this forum often. -
CUSTOM SSA XCON's and BOX (if wanted) FOR SALE
Still have your amp for sale?
